See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/173/changes
Changes:
[aaime] Make sure proper ows 1.1 exceptions are thrown
[...truncated 362 lines...]
[INFO] [compiler:compile]
[INFO] Compiling 116 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[INFO] [resources:testResources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geoserver:data:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:testCompile]
[INFO] Compiling 6 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports
T E S T S
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.412 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Jan 25, 2008 9:32:35 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: /tmp/test40218template
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.06 sec
Results :
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Web Coverage Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target
[INFO] [resources:resources]
[INFO] snapshot org.geotools:gt2-arcgrid:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-geotiff:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-gtopo30:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-image:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-imagemosaic:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 35 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Open Web Service Model v1.1.0
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target
[INFO] Compiling 149 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows.1_1/1.7.0-SNAPSHOT/net.opengis.ows.1_1-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows.1_1/1.7.0-SNAPSHOT/net.opengis.ows.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Coverage Service Model v1.1.1
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target
[INFO] Compiling 94 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wcs.1_1/1.7.0-SNAPSHOT/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wcs.1_1/1.7.0-SNAPSHOT/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Coverage Service 1.1.1 Module
[INFO] snapshot org.codehaus.mojo:javacc-maven-plugin:2.3-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:javacc-maven-plugin:2.3-SNAPSHOT: checking for updates from refractions-plugins
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset" does not exist. Creating the directory.
Reading from file http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java" does not exist. Will create one.
Annotated grammar generated successfully in http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] Compiling 49 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/classes
[INFO] snapshot org.geoserver:main:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 11 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports
T E S T S
Running org.geoserver.wcs.DescribeCoverageTest
Tests run: 7, Failures: 0, Errors: 7, Skipped: 0, Time elapsed: 2.816 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.GetCoverageReaderTest
Tests run: 10, Failures: 0, Errors: 10, Skipped: 0, Time elapsed: 0.552 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.BoundingBoxKvpParserTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.068 sec
Running org.geoserver.wcs.GetCoverageTest
Tests run: 11, Failures: 0, Errors: 11, Skipped: 0, Time elapsed: 0.616 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCapabilitiesXmlParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.48 sec
Running org.geoserver.wcs.xml.GetCoverageXmlParserTest
class [Ljava.lang.Double;: [Ljava.lang.Double;@6245a4
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.957 sec
Running org.geoserver.wcs.kvp.RangeSubsetKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.wcs.xml.DescribeCoverageXmlParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.152 sec
Running org.geoserver.wcs.GetCapabilitiesTest
Tests run: 7, Failures: 0, Errors: 7, Skipped: 0, Time elapsed: 0.26 sec <<< FAILURE!
Running org.geoserver.wcs.GetCoverageEncodingTest
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.276 sec <<< FAILURE!
Results :
Tests in error:
testDescribeNoIdentifiers(org.geoserver.wcs.DescribeCoverageTest)
testDescribeUnknownCoverageKvp(org.geoserver.wcs.DescribeCoverageTest)
testDescribeUnknownCoverageXml(org.geoserver.wcs.DescribeCoverageTest)
testDescribeDemCoverageKvp(org.geoserver.wcs.DescribeCoverageTest)
testDescribeDemCoverageXml(org.geoserver.wcs.DescribeCoverageTest)
testDescribeRotatedCoverage(org.geoserver.wcs.DescribeCoverageTest)
testDescribeImageCoverage(org.geoserver.wcs.DescribeCoverageTest)
testMissingParams(org.geoserver.wcs.kvp.GetCoverageReaderTest)
testUnknownCoverageParams(org.geoserver.wcs.kvp.GetCoverageReaderTest)
testBasic(org.geoserver.wcs.kvp.GetCoverageReaderTest)
testStoreUnsupported(org.geoserver.wcs.kvp.GetCoverageReaderTest)
testUnsupportedCRS(org.geoserver.wcs.kvp.GetCoverageReaderTest)
testGridTypes(org.geoserver.wcs.kvp.GetCoverageReaderTest)
testGridCS(org.geoserver.wcs.kvp.GetCoverageReaderTest)
testGridOrigin(org.geoserver.wcs.kvp.GetCoverageReaderTest)
testGridOffsets(org.geoserver.wcs.kvp.GetCoverageReaderTest)
testRangeSubset(org.geoserver.wcs.kvp.GetCoverageReaderTest)
testKvpBasic(org.geoserver.wcs.GetCoverageTest)
testWrongFormatParams(org.geoserver.wcs.GetCoverageTest)
testDefaultGridOrigin(org.geoserver.wcs.GetCoverageTest)
testWrongGridOrigin(org.geoserver.wcs.GetCoverageTest)
testWrongGridOffsets(org.geoserver.wcs.GetCoverageTest)
testNoGridOffsets(org.geoserver.wcs.GetCoverageTest)
testInvalidRangeSubset(org.geoserver.wcs.GetCoverageTest)
testRangeSubsetSingle(org.geoserver.wcs.GetCoverageTest)
testRangeSubsetMulti(org.geoserver.wcs.GetCoverageTest)
testRangeSubsetSwap(org.geoserver.wcs.GetCoverageTest)
testNullGridOrigin(org.geoserver.wcs.GetCoverageTest)
testGetBasic(org.geoserver.wcs.GetCapabilitiesTest)
testNoServiceContactInfo(org.geoserver.wcs.GetCapabilitiesTest)
testPostBasic(org.geoserver.wcs.GetCapabilitiesTest)
testUnsupportedVersionPost(org.geoserver.wcs.GetCapabilitiesTest)
testUnsupportedVersionGet(org.geoserver.wcs.GetCapabilitiesTest)
testSupportedVersionGet(org.geoserver.wcs.GetCapabilitiesTest)
testSupportedVersionPost(org.geoserver.wcs.GetCapabilitiesTest)
testKvpBasic(org.geoserver.wcs.GetCoverageEncodingTest)
testTiffOutput(org.geoserver.wcs.GetCoverageEncodingTest)
testPngOutput(org.geoserver.wcs.GetCoverageEncodingTest)
testGeotiffNamesGalore(org.geoserver.wcs.GetCoverageEncodingTest)
Tests run: 58, Failures: 0, Errors: 39, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 6 seconds
[INFO] Finished at: Fri Jan 25 09:33:03 EST 2008
[INFO] Final Memory: 34M/63M
