See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/175/changes
Changes:
[jdeolive] removed old dispatcher
[jdeolive] added new wfs config classes, and ported WFS config to them
[jdeolive] ported to platform.ServiceException
[jdeolive] modified assertions to do numeric comparison
[jdeolive] changed srs assertions to reflect actual srs
[jdeolive] added new wcs configuration classes, ported old WCS class to them
[jdeolive] removed old exception handler
[jdeolive] removed old exception handler and dispatcher
[jdeolive] added new wms configuration classes, ported old WMS class to them
[jdeolive] moved switch statement to if else due to configuration api changes
[jdeolive] removed old style exception handler
[jdeolive] moved to platform.ServiceException
[jdeolive] added an online check to test case
[jdeolive] Removed old wms exception handler
[jdeolive] added new configuration and catalog core classes, and ported old/global classes to them
[jdeolive] deprecated org.vfny...ServiceException in favor of org.geoserver.platform.ServiceException
[jdeolive] made OWS an interface and deprecated in place of ServiceInfo
[jdeolive] added srs info for mock data
[jdeolive] added extension prioritizing and method for looking up a singleton bean by its type
[jdeolive] added methods for copying resources from classpath, and find method taking variable argument array
[...truncated 1320 lines...]
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:808)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:523)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:453)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:869)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:419)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:400)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:612)
at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionGet(GetCapabilitiesTest.java:86)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:115)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
28 May 03:38:05 ERROR [geoserver.ows] -
java.io.IOException
at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:71)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:617)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:194)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:874)
at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorGet(GetCapabilitiesTest.java:154)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:132)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:107)
at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:69)
... 46 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:125)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
... 48 more
java.io.IOException
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:463)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:545)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:520)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:679)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:662)
at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:166)
... 47 more
... 49 more
java.io.IOException
at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:173)
... 46 more
Caused by: org.vfny.geoserver.wcs.WcsException: Unknown section Bogus
at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:172)
... 48 more
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.12 sec
Results :
Tests in error:
testRangeSubsetSingle(org.geoserver.wcs.GetCoverageTest)
testRangeSubsetMulti(org.geoserver.wcs.GetCoverageTest)
testRangeSubsetSwap(org.geoserver.wcs.GetCoverageTest)
Tests run: 76, Failures: 0, Errors: 3, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 11 seconds
[INFO] Finished at: Wed May 28 03:38:06 EDT 2008
[INFO] Final Memory: 30M/62M
