See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/18/changes
Changes:
[jdeolive] added datastore factory iniitaliser for h2
[jdeolive] added extension point for iniitalizing data store factories after they are created
[...truncated 2683 lines...]
[INFO] Building Test Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest
Mar 27, 2008 3:39:27 PM org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest testUserSpecifiedRule
INFO: testing single rule dirt_road from style Default Styler
Mar 27, 2008 3:39:28 PM org.vfny.geoserver.testdata.AbstractCiteDataTest assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.764 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest
Mar 27, 2008 3:39:28 PM org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest testSimpleGetMapQuery
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[-2.0 : 2.0, -1.0 : 6.0]
Mar 27, 2008 3:39:28 PM org.geotools.map.DefaultMapContext setAreaOfInterest
INFO: USing a deprecated method!
INFO: testSimpleGetMapQuery: pixel count=90000 non bg pixels: 90000
INFO: testDefaultStyle Bridges: pixel count=91600 non bg pixels: 49
INFO: testDefaultStyle NamedPlaces: pixel count=91600 non bg pixels: 5608
INFO: testDefaultStyle Streams: pixel count=91600 non bg pixels: 812
INFO: testDefaultStyle Lakes: pixel count=91600 non bg pixels: 2589
INFO: testDefaultStyle RoadSegments: pixel count=91600 non bg pixels: 918
INFO: testDefaultStyle BasicPolygons: pixel count=280000 non bg pixels: 101880
INFO: testDefaultStyle MapNeatline: pixel count=91600 non bg pixels: 43645
INFO: testDefaultStyle Buildings: pixel count=91600 non bg pixels: 210
INFO: testDefaultStyle DividedRoutes: pixel count=91600 non bg pixels: 374
INFO: testDefaultStyle Forests: pixel count=91600 non bg pixels: 20832
INFO: testDefaultStyle Ponds: pixel count=91600 non bg pixels: 148
Mar 27, 2008 3:39:29 PM org.vfny.geoserver.testdata.AbstractCiteDataTest assertNotBlank
INFO: testBlueLake: pixel count=108400 non bg pixels: 107836
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.34 sec
Running org.vfny.geoserver.wms.responses.map.SVGMapProducerTest
Mar 27, 2008 3:39:29 PM org.geotools.map.DefaultMapContext setAreaOfInterest
Mar 27, 2008 3:39:29 PM org.vfny.geoserver.wms.responses.map.svg.EncodeSVG encode
INFO: SVG generated in 4 ms
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Running org.vfny.geoserver.wms.responses.GetMapResponseTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReaderTest
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/test-classes/org/vfny/geoserver/testdata/test-data
Mar 27, 2008 3:39:29 PM org.vfny.geoserver.global.Data loadFeatureTypes
INFO: Loading feature type 'cite:::BasicPolygons' (layer 1/11)
SEVERE: FeatureTypeInfo cite:::BasicPolygons ignored - as DataStore cite is disabled!
INFO: Loading feature type 'cite:::Bridges' (layer 2/11)
SEVERE: FeatureTypeInfo cite:::Bridges ignored - as DataStore cite is disabled!
INFO: Loading feature type 'cite:::Buildings' (layer 3/11)
SEVERE: FeatureTypeInfo cite:::Buildings ignored - as DataStore cite is disabled!
INFO: Loading feature type 'cite:::DividedRoutes' (layer 4/11)
SEVERE: FeatureTypeInfo cite:::DividedRoutes ignored - as DataStore cite is disabled!
INFO: Loading feature type 'cite:::Forests' (layer 5/11)
SEVERE: FeatureTypeInfo cite:::Forests ignored - as DataStore cite is disabled!
INFO: Loading feature type 'cite:::Lakes' (layer 6/11)
SEVERE: FeatureTypeInfo cite:::Lakes ignored - as DataStore cite is disabled!
INFO: Loading feature type 'cite:::MapNeatline' (layer 7/11)
SEVERE: FeatureTypeInfo cite:::MapNeatline ignored - as DataStore cite is disabled!
INFO: Loading feature type 'cite:::NamedPlaces' (layer 8/11)
SEVERE: FeatureTypeInfo cite:::NamedPlaces ignored - as DataStore cite is disabled!
INFO: Loading feature type 'cite:::Ponds' (layer 9/11)
SEVERE: FeatureTypeInfo cite:::Ponds ignored - as DataStore cite is disabled!
INFO: Loading feature type 'cite:::RoadSegments' (layer 10/11)
SEVERE: FeatureTypeInfo cite:::RoadSegments ignored - as DataStore cite is disabled!
INFO: Loading feature type 'cite:::Streams' (layer 11/11)
SEVERE: FeatureTypeInfo cite:::Streams ignored - as DataStore cite is disabled!
Mar 27, 2008 3:39:30 PM org.vfny.geoserver.global.Data loadFeatureTypes
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.464 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.GIFMapProducerTest
Mar 27, 2008 3:39:30 PM org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest testSimpleGetMapQuery
Mar 27, 2008 3:39:30 PM org.geotools.map.DefaultMapContext setAreaOfInterest
width=300, height=300
width=400, height=229
width=400, height=700
Mar 27, 2008 3:39:31 PM org.geotools.map.DefaultMapContext setAreaOfInterest
width=400, height=271
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.46 sec
Results :
Tests in error:
testRemoteSLDMultipleStyles(org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReaderTest)
Tests run: 15, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 54 seconds
[INFO] Finished at: Thu Mar 27 15:39:31 EDT 2008
[INFO] Final Memory: 36M/63M
