See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/1817/>
[...truncated 20228 lines...]
PARAMETER["central_meridian", -93.0],
PARAMETER["latitude_of_origin", 0.0],
PARAMETER["scale_factor", 0.9996],
PARAMETER["false_easting", 500000.0],
PARAMETER["false_northing", 0.0],
UNIT["m", 1.0],
AXIS["Easting", EAST],
AXIS["Northing", NORTH],
AUTHORITY["EPSG","32615"]]-->
<LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
<Style>
<Name>Default</Name>
<Title>Default Styler</Title>
<Abstract/>
<LegendURL height="20" width="20">
<Format>image/png</Format>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&heigth=20&layer=Polygons" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
<Layer queryable="1">
<Name>cite:Ponds</Name>
<Title>Ponds</Title>
<Abstract>abstract about Ponds</Abstract>
<KeywordList>
<Keyword>Ponds</Keyword>
</KeywordList>
<SRS>EPSG:4326</SRS>
<!--WKT definition of this CRS:
GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4326"]]-->
<BoundingBox SRS="EPSG:4326" maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
<Style>
<Name>Ponds</Name>
<Abstract/>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&heigth=20&layer=Ponds" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
<Name>sf:PrimitiveGeoFeature</Name>
<Title>PrimitiveGeoFeature</Title>
<Abstract>abstract about PrimitiveGeoFeature</Abstract>
<KeywordList>
<Keyword>PrimitiveGeoFeature</Keyword>
</KeywordList>
GEOGCS["WGS 84",
<Style>
<Abstract/>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&heigth=20&layer=PrimitiveGeoFeature" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
<Name>cite:RoadSegments</Name>
<Title>RoadSegments</Title>
<Abstract>abstract about RoadSegments</Abstract>
<KeywordList>
<Keyword>RoadSegments</Keyword>
</KeywordList>
GEOGCS["WGS 84",
<Style>
<Name>RoadSegments</Name>
<Abstract/>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&heigth=20&layer=RoadSegments" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
<Name>cdf:Seven</Name>
<Title>Seven</Title>
<Abstract>abstract about Seven</Abstract>
<KeywordList>
<Keyword>Seven</Keyword>
</KeywordList>
<SRS>EPSG:32615</SRS>
PROJCS["WGS 84 / UTM zone 15N",
GEOGCS["WGS 84",
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]],
UNIT["m", 1.0],
<Style>
<Abstract/>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&heigth=20&layer=Seven" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
<Name>cite:Streams</Name>
<Title>Streams</Title>
<Abstract>abstract about Streams</Abstract>
<KeywordList>
<Keyword>Streams</Keyword>
</KeywordList>
GEOGCS["WGS 84",
<Style>
<Name>Streams</Name>
<Abstract/>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&heigth=20&layer=Streams" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
<Name>cdf:Updates</Name>
<Title>Updates</Title>
<Abstract>abstract about Updates</Abstract>
<KeywordList>
<Keyword>Updates</Keyword>
</KeywordList>
GEOGCS["WGS 84",
UNIT["m", 1.0],
<Style>
<Abstract/>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&heigth=20&layer=Updates" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.448 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.274 sec
Results :
Failed tests:
testRemoteOWSUserStyleGet(org.vfny.geoserver.wms.responses.map.png.GetMapTest)
Tests run: 164, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 3 minutes 54 seconds
[INFO] Finished at: Mon Sep 21 13:26:31 EDT 2009
[INFO] Final Memory: 40M/117M
