[Geoserver-devel] Build failed in Hudson: geoserver-trunk #182
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/182/changes
[...truncated 1448 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:334)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:980)
Caused by: org.geotools.data.FeatureLockException: Transaction does not have authorization for Locks:Locks.0
  at org.geotools.data.InProcessLockingManager.assertAccess(InProcessLockingManager.java:284)
  at org.geotools.data.InProcessLockingManager$1.write(InProcessLockingManager.java:327)
  at org.geotools.data.FilteringFeatureWriter.write(FilteringFeatureWriter.java:105)
  at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:155)
  at org.geotools.data.AbstractFeatureStore.modifyFeatures(AbstractFeatureStore.java:97)
  at org.vfny.geoserver.global.GeoServerFeatureStore.modifyFeatures(GeoServerFeatureStore.java:124)
  at org.geoserver.wfs.UpdateElementHandler.execute(UpdateElementHandler.java:225)
  ... 53 more
27 Jan 19:14:26 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
27 Jan 19:14:26 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.86 sec
Running org.geoserver.wfs.ReprojectingFilterVisitorTest
Tests run: 8, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec <<< FAILURE!
Running org.geoserver.wfs.kvp.FilterKvpParserTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.wfs.v1_1.GetFeatureTest
27 Jan 19:14:30 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not locate {http://cite.opengeospatial.org/gmlsf\}new in catalog.
  at org.geoserver.wfs.GetFeature.featureTypeInfo(GetFeature.java:529)
  at org.geoserver.wfs.GetFeature.run(GetFeature.java:158)
  at org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:109)
  at sun.reflect.GeneratedMethodAccessor88.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
  at $Proxy6.getFeature(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor87.invoke(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:599)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:277)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:258)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:352)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:334)
  at org.geoserver.wfs.v1_1.GetFeatureTest.testAfterFeatureTypeAdded(GetFeatureTest.java:331)
  at junit.framework.TestCase.runTest(TestCase.java:154)
  at junit.framework.TestCase.runBare(TestCase.java:127)
  at junit.framework.TestCase.run(TestCase.java:118)
  at junit.framework.TestSuite.runTest(TestSuite.java:208)
  at junit.framework.TestSuite.run(TestSuite.java:203)
Tests run: 17, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 4.244 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.TransactionTest
27 Jan 19:14:33 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: No such property: {http://www.opengis.net/wfs\}INVALID
  at org.geoserver.wfs.UpdateElementHandler.checkValidity(UpdateElementHandler.java:110)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:225)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:104)
  at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:157)
  at sun.reflect.GeneratedMethodAccessor93.invoke(Unknown Source)
  at $Proxy6.transaction(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor92.invoke(Unknown Source)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:318)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:419)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:402)
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdateWithInvalidProperty(TransactionTest.java:532)
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.68 sec
Running org.geoserver.wfs.v1_1.GetFeatureWithLockTest
27 Jan 19:14:33 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
27 Jan 19:14:33 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Running org.geoserver.wfs.xml.GML3FeatureProducerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.636 sec
Running org.geoserver.wfs.response.WfsXmlWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.104 sec
Running org.geoserver.wfs.TransactionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.788 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.46 sec
Running org.geoserver.wfs.v1_1.WFSReprojectionTest
Tests run: 13, Failures: 6, Errors: 0, Skipped: 0, Time elapsed: 3.04 sec <<< FAILURE!
Running org.geoserver.wfs.ReprojectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.337 sec
Running org.geoserver.wfs.TransactionListenerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.58 sec
Running org.geoserver.wfs.DescribeFeatureTest
27 Jan 19:14:41 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:97)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:92)
  at $Proxy6.describeFeatureType(Unknown Source)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:29)
  at sun.reflect.GeneratedMethodAccessor95.invoke(Unknown Source)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.484 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.412 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.108 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.26 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.16 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.428 sec
Results :
Failed tests:
  testWfs11(org.geoserver.wfs.SrsNameTest)
  testBboxReproject(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testIntersectsReproject(org.geoserver.wfs.ReprojectingFilterVisitorTest)
  testPostWithFailingUrnBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
  testPostWithMatchingUrnBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
  testUpdateReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testUpdateReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testDeleteReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testDeleteReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testLockReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
  testLockReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
Tests run: 126, Failures: 11, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 51 seconds
[INFO] Finished at: Sun Jan 27 19:14:47 EST 2008
[INFO] Final Memory: 33M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/183/changes
Changes:
[jdeolive] setting name to emptry string to force default geometry to be determined by the feature and not the feature type
[jdeolive] added projection check for cite testing
[jdeolive] exception handling in update features operation
[jdeolive] hanlding whitespace in requests
[jdeolive] logging exception on failure
[...truncated 1479 lines...]
  ... 53 more
27 Jan 21:33:28 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
27 Jan 21:33:28 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.856 sec
27 Jan 21:33:32 ERROR [geoserver.ows] -
  at org.geoserver.wfs.GetFeature.featureTypeInfo(GetFeature.java:598)
  at org.geoserver.wfs.GetFeature.run(GetFeature.java:168)
Tests run: 17, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 4.228 sec <<< FAILURE!
27 Jan 21:33:35 ERROR [geoserver.ows] -
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.665 sec
27 Jan 21:33:35 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
27 Jan 21:33:35 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.22 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.66 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.1 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.856 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.456 sec
Tests run: 13, Failures: 6, Errors: 0, Skipped: 0, Time elapsed: 3.052 sec <<< FAILURE!
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.432 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.532 sec
27 Jan 21:33:43 ERROR [geoserver.ows] -
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.44 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.384 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.284 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.176 sec
Results :
Failed tests:
[INFO] Finished at: Sun Jan 27 21:33:49 EST 2008
[INFO] Final Memory: 32M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/184/changes
