See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/206/changes
Changes:
[aaime] More authentication tests
[...truncated 3972 lines...]
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:Polygon srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:exterior>
<gml:LinearRing>
<gml:posList>500000.0 500000.0 500000.0 500100.0 500100.0 500100.0 500100.0 500000.0 500000.0 500000.0</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
<gml:Point srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:pos>500050.0 500050.0</gml:pos>
</gml:Point>
</cdf:pointProperty>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.10">
<gml:boundedBy>
<gml:Envelope srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:lowerCorner>500000.0 500000.0</gml:lowerCorner>
<gml:upperCorner>500100.0 500100.0</gml:upperCorner>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.11">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.12">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.13">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.14">
<gml:boundedBy>
</gml:Envelope>
</gml:boundedBy>
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.144 sec
Running org.geoserver.wfs.DescribeFeatureTest
02 Jun 12:19:56 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:131)
at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:92)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy12.describeFeatureType(Unknown Source)
at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:497)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:190)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:874)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:808)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:523)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:463)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:882)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:558)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:533)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:692)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:675)
at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:38)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:117)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor148.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.276 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.14 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.32 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Feature type cite:InvalidTypeName unknown
Feature type gs:InvalidTypeName unknown
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.288 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.224 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.268 sec
Results :
Tests run: 135, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file
org.geotools:gt-validation:jar:2.5-SNAPSHOT
from the specified remote repositories:
central (http://repo1.maven.org/maven2),
maven-restlet (http://maven.restlet.org),
refractions (http://lists.refractions.net/m2/),
mortbay (http://www.mortbay.org/maven2/release),
geotools (http://maven.geotools.fr/repository/)
Path to dependency:
1) org.geoserver:wfs:jar:1.7.0-SNAPSHOT
2) org.geoserver:main:jar:1.7.0-SNAPSHOT
3) org.geotools:gt-validation:jar:2.5-SNAPSHOT
Caused by I/O exception: Connection refused
[INFO] Total time: 5 minutes 1 second
[INFO] Finished at: Mon Jun 02 12:21:41 EDT 2008
[INFO] Final Memory: 29M/63M
