[Geoserver-devel] Build failed in Hudson: geoserver-trunk #214
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/214/changes
Changes:
[aaime] GEOS-779, configuration changes to handle feature type aliases
[aaime] GEOS-779, infrastructure changes needed to get the retyping datastore up to speed on both read and write fronts
[...truncated 53 lines...]
Fetching external item into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/lib
External at revision -1
At revision 5950
Fetching external item into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
          web/minimal
At revision 8326
At revision 8324
no change for http://svn.codehaus.org/geoserver/trunk/configuration/minimal since the previous build
no change for http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/img since the previous build
no change for http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/lib since the previous build
[geoserver] $ /opt/maven2/bin/mvn -U clean install -Djava.awt.headless=true
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Plugins configuration files
[INFO] Configuration Deployment PlugIn
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Open Web Service Model
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Open Web Service Model v1.1.0
[INFO] Web Coverage Service Model v1.1.1
[INFO] Web Coverage Service 1.1.1 Module
[INFO] Validation Module
[INFO] Web Feature Service Model
[INFO] Web Feature Service Module
[INFO] Versioning Web Feature Service Model
[INFO] Versioned Web Feature Service Module
[INFO] Web Map Service Module
[INFO] Web Application Module
[INFO] Test Module
[INFO] ----------------------------------------------------------------------------
[INFO] Building GeoServer
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from central
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from central
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from central
[INFO] [site:attach-descriptor]
[INFO] snapshot org.geotools:gt2-api:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-library:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-modules:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-referencing:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-metadata:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.opengis:geoapi:2.2-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.opengis:parent:2.2-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-main:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-1.7.0-SNAPSHOT-tests.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.0-SNAPSHOT/geoserver-1.7.0-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.0-SNAPSHOT/geoserver-1.7.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.0-SNAPSHOT/maven-1.7.0-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.0-SNAPSHOT/maven-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Plugins configuration files
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from central
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT-tests.jar
[INFO] [plugin:updateRegistry]
[INFO] Building Core Platform Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target
[INFO] Compiling 9 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Data Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target
[INFO] snapshot org.geotools:gt2-coverage:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-unsupported:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-data:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-jdbc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.h2database:h2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.openplans:spatialdbbox:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo-property:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-repository:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-plugin:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wms:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-xsd:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-extension:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-filter:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-graph:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-gml2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-gml3:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-ows:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-render:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile:2.5-SNAPSHOT: checking for updates from refractions
Downloading: http://maven.geotools.fr/repository//org.easymock/poms/easymock-2.3.pom
Downloading: http://lists.refractions.net/m2//org/easymock/easymock/2.3/easymock-2.3.pom
Downloading: http://www.mortbay.org/maven2/release/org/easymock/easymock/2.3/easymock-2.3.pom
Downloading: http://repo1.maven.org/maven2/org/easymock/easymock/2.3/easymock-2.3.pom
2/2K
2K downloaded
[INFO] Compiling 17 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingFeatureStore.java :[66,37] cannot find symbol
symbol : method reTypeId(java.lang.String,org.opengis.feature.simple.SimpleFeatureType,org.opengis.feature.simple.SimpleFeatureType)
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/FidTransformerVisitor.java :[38,42] cannot find symbol
[INFO] Total time: 21 seconds
[INFO] Finished at: Thu Jan 31 12:16:05 EST 2008
[INFO] Final Memory: 22M/39M
Updating GEOS-779
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/215/changes
Changes:
[aaime] GEOS-779, wfs 1.1 changes to handle aliases and more tests
[aaime] GEOS-779, UI changes for aliases handling
[...truncated 43 lines...]
          community/community-schemas/web-c/minimal
At revision 8326
Fetching external item into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/img
At revision 5950
At revision 5950
          web/minimal
At revision 8326
At revision 8326
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO] [jar:jar]
[INFO] [jar:jar]
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Total time: 22 seconds
[INFO] Finished at: Thu Jan 31 12:32:22 EST 2008
[INFO] Final Memory: 22M/40M
Updating GEOS-779
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/216/changes
[...truncated 4 lines...]
At revision 8327
At revision 5950
At revision 5950
          web/minimal
At revision 8327
At revision 8326
no change for https://svn.codehaus.org/geoserver/trunk/geoserver since the previous build
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO] [jar:jar]
[INFO] [jar:jar]
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Total time: 20 seconds
[INFO] Finished at: Thu Jan 31 12:34:30 EST 2008
[INFO] Final Memory: 21M/43M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/217/changes
