See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2168/>
[...truncated 27415 lines...]
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
30 Nov 13:49:01 ERROR [geoserver.rest] - No such workspace: foo
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.WorkspaceFinder.findTarget(WorkspaceFinder.java:33)
at org.restlet.Finder.handle(Finder.java:268)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1058)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1025)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:467)
at org.geoserver.catalog.rest.WorkspaceTest.testDelete(WorkspaceTest.java:152)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:125)
30 Nov 13:49:01 ERROR [geoserver.rest] - Workspace not empty
at org.geoserver.catalog.rest.WorkspaceResource.handleObjectDelete(WorkspaceResource.java:150)
at org.geoserver.rest.ReflectiveResource.handleDelete(ReflectiveResource.java:219)
at org.restlet.Finder.handle(Finder.java:300)
at org.springframework.web.servlet.FrameworkServlet.doDelete(FrameworkServlet.java:531)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
at org.geoserver.test.GeoServerAbstractTestSupport.deleteAsServletResponse(GeoServerAbstractTestSupport.java:666)
at org.geoserver.catalog.rest.WorkspaceTest.testDeleteNonEmptyForbidden(WorkspaceTest.java:156)
30 Nov 13:49:01 ERROR [geoserver.rest] - Can't change the name of a workspace.
at org.geoserver.catalog.rest.WorkspaceResource.handleObjectPut(WorkspaceResource.java:129)
at org.geoserver.rest.ReflectiveResource.handlePut(ReflectiveResource.java:188)
at org.restlet.Finder.handle(Finder.java:298)
at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:521)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:712)
at org.geoserver.test.GeoServerAbstractTestSupport.putAsServletResponse(GeoServerAbstractTestSupport.java:563)
at org.geoserver.test.GeoServerAbstractTestSupport.putAsServletResponse(GeoServerAbstractTestSupport.java:551)
at org.geoserver.catalog.rest.WorkspaceTest.testPutNameChangeForbidden(WorkspaceTest.java:189)
30 Nov 13:49:02 ERROR [geoserver.rest] - No such workspace: nonExistant
at org.geoserver.catalog.rest.WorkspaceTest.testPutNonExistant(WorkspaceTest.java:205)
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.399 sec
Results :
Failed tests:
testCreateFeatureType(org.geoserver.catalog.rest.JDBCTest)
Tests in error:
testCreateDataStore(org.geoserver.catalog.rest.JDBCTest)
testCreateGeometrylessFeatureType(org.geoserver.catalog.rest.JDBCTest)
Tests run: 143, Failures: 1, Errors: 2, Skipped: 0
30 Nov 13:49:02 ERROR [geotools.jdbc] - There's code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/restconfig/target/surefire-reports> for the individual test results.
[INFO] Total time: 10 minutes 2 seconds
[INFO] Finished at: Mon Nov 30 13:49:02 EST 2009
[INFO] Final Memory: 54M/147M
