[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2178
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2178/changes&gt;
Changes:
[jdeolive] changed group id of sql server dependency
[...truncated 25306 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
03 Dec 10:47:20 ERROR [geoserver.rest] - Indexing is disabled for this layer (NamespaceInfoImpl[cite:http://www.opengis.net/cite\]:BasicPolygons) false
org.geoserver.rest.RestletException
  at org.geoserver.geosearch.AbstractFeatureDescription.findFeature(AbstractFeatureDescription.java:71)
  at org.geoserver.geosearch.HTMLFeatureDescription.doGet(HTMLFeatureDescription.java:38)
  at org.geoserver.geosearch.HTMLFeatureDescription.handle(HTMLFeatureDescription.java:30)
  at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
  at org.restlet.Filter.doHandle(Filter.java:105)
  at org.restlet.Filter.handle(Filter.java:134)
  at org.restlet.Router.handle(Router.java:444)
  at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
  at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1058)
  at org.geoserver.test.GeoServerAbstractTestSupport.assertStatusCodeForRequest(GeoServerAbstractTestSupport.java:1123)
  at org.geoserver.test.GeoServerAbstractTestSupport.assertStatusCodeForGet(GeoServerAbstractTestSupport.java:1076)
  at org.geoserver.geosearch.SiteMapIndexRestletTest.assertProtectedEndpoint(SiteMapIndexRestletTest.java:34)
  at org.geoserver.geosearch.SiteMapIndexRestletTest.testFeatureHTML(SiteMapIndexRestletTest.java:95)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:125)
03 Dec 10:47:21 ERROR [geoserver.rest] - Layer indexing disabled
  at org.geoserver.geosearch.LayerAboutPage.getContext(LayerAboutPage.java:75)
  at org.geoserver.geosearch.LayerAboutPage.doGet(LayerAboutPage.java:68)
  at org.geoserver.geosearch.LayerAboutPage.handle(LayerAboutPage.java:60)
  at org.geoserver.geosearch.SiteMapIndexRestletTest.testLayerHTML(SiteMapIndexRestletTest.java:104)
Dec 3, 2009 10:47:21 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.284 sec
Running org.geoserver.geosearch.FeatureRestletTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.889 sec
Running org.geoserver.geosearch.LayerAboutPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.3 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/geosearch/2.1-SNAPSHOT/geosearch-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/geosearch/2.1-SNAPSHOT/geosearch-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/geosearch/2.1-SNAPSHOT/geosearch-2.1-SNAPSHOT-sources.jar
[INFO] Building H2 DataStore Extension
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target&gt;
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/surefire-reports&gt;
T E S T S
Running org.geoserver.h2.H2DataStoreInitializerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.536 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.1-SNAPSHOT/h2-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.1-SNAPSHOT/h2-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.1-SNAPSHOT/h2-2.1-SNAPSHOT-sources.jar
[INFO] Building SQL Server DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/sqlserver/target&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-sqlserver:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-sqlserver:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/jdbc/gt-jdbc-sqlserver/2.7-SNAPSHOT/gt-jdbc-sqlserver-2.7-SNAPSHOT.pom
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/jdbc/gt-jdbc-sqlserver/2.7-SNAPSHOT/gt-jdbc-sqlserver-2.7-SNAPSHOT.pom
Downloading: http://repo.opengeo.org//org/geotools/jdbc/gt-jdbc-sqlserver/2.7-SNAPSHOT/gt-jdbc-sqlserver-2.7-SNAPSHOT.jar
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/jdbc/gt-jdbc-sqlserver/2.7-SNAPSHOT/gt-jdbc-sqlserver-2.7-SNAPSHOT.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geotools.jdbc:gt-jdbc-sqlserver:jar:2.7-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geotools.jdbc -DartifactId=gt-jdbc-sqlserver -Dversion=2.7-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geotools.jdbc -DartifactId=gt-jdbc-sqlserver -Dversion=2.7-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.extension:sqlserver:jar:2.1-SNAPSHOT
    2) org.geotools.jdbc:gt-jdbc-sqlserver:jar:2.7-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  maven-restlet (http://maven.restlet.org),
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  opengeo (http://repo.opengeo.org/)
[INFO] Total time: 10 minutes 31 seconds
[INFO] Finished at: Thu Dec 03 10:47:32 EST 2009
[INFO] Final Memory: 52M/144M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2179/&gt;
