[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2262
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2262/changes&gt;
Changes:
[afabiani] - GEOS-3740
- GEOS-3741
[...truncated 1245 lines...]
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.geoserver.wcs.response.Wcs10GetCapabilitiesResponse.write(Wcs10GetCapabilitiesResponse.java:45)
  ... 49 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at org.geoserver.wcs.response.Wcs10CapsTransformer$WCS100CapsTranslator.encode(Wcs10CapsTransformer.java:141)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 51 more
22 Dec 12:37:28 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: Could not find section 'Bogus'
  at org.geoserver.wcs.kvp.SectionKvpParser.parse(SectionKvpParser.java:29)
  at org.geoserver.ows.util.KvpUtils.parse(KvpUtils.java:489)
  at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:1095)
  at org.geoserver.ows.Dispatcher.init(Dispatcher.java:263)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1054)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1021)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:463)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:444)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:718)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:680)
  at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:116)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:126)
<wcs:WCS_Capabilities xmlns:wcs="http://www.opengis.net/wcs&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; updateSequence="0" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/wcs http://localhost:80/geoserver/schemas/wcs/1.0.0/wcsCapabilities.xsd&quot;&gt;
<wcs:Service version="1.0.0">
<wcs:metadataLink about="http://geoserver.sourceforge.net/html/index.php&quot; metadataType="other"/>
<wcs:description>
This is a description of your Web Coverage Server.
     </wcs:description>
<wcs:name>My GeoServer WCS</wcs:name>
<wcs:label>My GeoServer WCS</wcs:label>
<wcs:keywords>
<wcs:keyword>WCS</wcs:keyword>
<wcs:keyword>WMS</wcs:keyword>
<wcs:keyword>GEOSERVER</wcs:keyword>
</wcs:keywords>
<wcs:responsibleParty>
<wcs:individualName>Andrea Aime</wcs:individualName>
<wcs:contactInfo>
<wcs:phone/>
<wcs:address/>
</wcs:contactInfo>
</wcs:responsibleParty>
<wcs:fees>NONE</wcs:fees>
<wcs:accessConstraints>NONE</wcs:accessConstraints>
</wcs:Service>
<wcs:Capability>
<wcs:Request>
<wcs:GetCapabilities>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
<wcs:OnlineResource xlink:href="wcs?"/>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
</wcs:GetCapabilities>
<wcs:DescribeCoverage>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
</wcs:DescribeCoverage>
<wcs:GetCoverage>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
</wcs:GetCoverage>
</wcs:Request>
<wcs:Exception>
<wcs:Format>application/vnd.ogc.se_xml</wcs:Format>
</wcs:Exception>
</wcs:Capability>
<wcs:ContentMetadata version="1.0.0">
<wcs:CoverageOfferingBrief>
<wcs:description>BlueMarble description</wcs:description>
<wcs:name>wcs:BlueMarble</wcs:name>
<wcs:label>BlueMarble</wcs:label>
<wcs:lonLatEnvelope srsName="urn:ogc:def:crs:OGC:1.3:CRS84">
<gml:pos>146.49999999999477 -44.49999999999785</gml:pos>
<gml:pos>147.99999999999474 -42.99999999999787</gml:pos>
</wcs:lonLatEnvelope>
<wcs:keywords>
<wcs:keyword>BlueMarble</wcs:keyword>
</wcs:keywords>
</wcs:CoverageOfferingBrief>
<wcs:description>DEM description</wcs:description>
<wcs:name>wcs:DEM</wcs:name>
<wcs:label>DEM</wcs:label>
<gml:pos>144.999999999998 -42.999999999986805</gml:pos>
<gml:pos>145.9999999999976 -40.99999999998761</gml:pos>
<wcs:keywords>
<wcs:keyword>DEM</wcs:keyword>
</wcs:keywords>
<wcs:description>RotatedCad description</wcs:description>
<wcs:name>wcs:RotatedCad</wcs:name>
<wcs:label>RotatedCad</wcs:label>
<gml:pos>-4.356399966874192 0.001739899399003904</gml:pos>
<gml:pos>-4.356399958827462 0.0017399037939527457</gml:pos>
<wcs:keywords>
<wcs:keyword>RotatedCad</wcs:keyword>
</wcs:keywords>
<wcs:description>World description</wcs:description>
<wcs:name>wcs:World</wcs:name>
<wcs:label>World</wcs:label>
<gml:pos>-180.0 -90.0</gml:pos>
<gml:pos>180.0 90.0</gml:pos>
<wcs:keywords>
<wcs:keyword>World</wcs:keyword>
</wcs:keywords>
</wcs:ContentMetadata>
</wcs:WCS_Capabilities>
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.022 sec
Results :
Failed tests:
  testDescribeDemCoverageKvp(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeDemCoverageXml(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeRotatedCoverage(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeImageCoverage(org.geoserver.wcs.DescribeCoverageTest)
Tests run: 38, Failures: 4, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_0/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 1 minute 45 seconds
[INFO] Finished at: Tue Dec 22 12:37:28 EST 2009
[INFO] Final Memory: 39M/115M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2263/changes&gt;
