[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2273
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2273/changes&gt;
Changes:
[dgricci] Updates of French properties
[...truncated 21844 lines...]
  PARAMETER["scale_factor", 0.9996],
  PARAMETER["false_easting", 500000.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["Easting", EAST],
  AXIS["Northing", NORTH],
  AUTHORITY["EPSG","32615"]]-->
        <LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <Style>
          <Name>Default</Name>
          <Title>Default Styler</Title>
          <Abstract/>
          <LegendURL height="20" width="20">
            <Format>image/png</Format>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Polygons&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
      <Layer queryable="1">
        <Name>cite:Ponds</Name>
        <Title>Ponds</Title>
        <Abstract>abstract about Ponds</Abstract>
        <KeywordList>
          <Keyword>Ponds</Keyword>
        </KeywordList>
        <SRS>EPSG:4326</SRS>
        <!--WKT definition of this CRS:
GEOGCS["WGS 84",
  DATUM["World Geodetic System 1984",
    SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
    AUTHORITY["EPSG","6326"]],
  PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
  UNIT["degree", 0.017453292519943295],
  AXIS["Geodetic longitude", EAST],
  AXIS["Geodetic latitude", NORTH],
  AUTHORITY["EPSG","4326"]]-->
        <BoundingBox SRS="EPSG:4326" maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <Style>
          <Name>Ponds</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Ponds&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>sf:PrimitiveGeoFeature</Name>
        <Title>PrimitiveGeoFeature</Title>
        <Abstract>abstract about PrimitiveGeoFeature</Abstract>
        <KeywordList>
          <Keyword>PrimitiveGeoFeature</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=PrimitiveGeoFeature&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cite:RoadSegments</Name>
        <Title>RoadSegments</Title>
        <Abstract>abstract about RoadSegments</Abstract>
        <KeywordList>
          <Keyword>RoadSegments</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>RoadSegments</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=RoadSegments&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cdf:Seven</Name>
        <Title>Seven</Title>
        <Abstract>abstract about Seven</Abstract>
        <KeywordList>
          <Keyword>Seven</Keyword>
        </KeywordList>
        <SRS>EPSG:32615</SRS>
PROJCS["WGS 84 / UTM zone 15N",
  GEOGCS["WGS 84",
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]],
  PARAMETER["central_meridian", -93.0],
  PARAMETER["latitude_of_origin", 0.0],
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Seven&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cite:Streams</Name>
        <Title>Streams</Title>
        <Abstract>abstract about Streams</Abstract>
        <KeywordList>
          <Keyword>Streams</Keyword>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Name>Streams</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Streams&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cdf:Updates</Name>
        <Title>Updates</Title>
        <Abstract>abstract about Updates</Abstract>
        <KeywordList>
          <Keyword>Updates</Keyword>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Updates&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
</WMT_MS_Capabilities>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.391 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.301 sec
Results :
Failed tests:
  testVectorWithRemoteLayer(org.vfny.geoserver.wms.responses.map.kml.KMLTest)
  testRemoteOWSGet(org.vfny.geoserver.wms.responses.map.png.GetMapTest)
Tests run: 167, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 4 minutes 29 seconds
[INFO] Finished at: Mon Dec 28 07:40:34 EST 2009
[INFO] Final Memory: 43M/112M
Failed to send e-mail to dgricci because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2274/changes&gt;
Changes:
[simboss] minor improvement to the tiff writer
[...truncated 21812 lines...]
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.464 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.309 sec
Results :
Tests run: 167, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target&gt;
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geowebcache:geowebcache:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:geowebcache:1.2-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/surefire-reports&gt;
T E S T S
Running org.geoserver.gwc.GWCCatalogListenerTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.477 sec <<< FAILURE!
Results :
Tests in error:
  testInit(org.geoserver.gwc.GWCCatalogListenerTest)
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 4 minutes 14 seconds
[INFO] Finished at: Tue Dec 29 07:40:03 EST 2009
[INFO] Final Memory: 44M/123M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2275/&gt;
[...truncated 21810 lines...]
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.48 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.581 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.679 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Finished at: Tue Dec 29 13:46:53 EST 2009
[INFO] Final Memory: 44M/116M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2276/&gt;
[...truncated 21813 lines...]
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.771 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.282 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.788 sec <<< FAILURE!
Results :
Tests in error:
30 Dec 22:28:23 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
30 Dec 22:28:23 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources&gt; contained no layers.
30 Dec 22:28:23 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources&gt;: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources/geowebcache\.xml&gt;
[INFO] Total time: 4 minutes 33 seconds
[INFO] Finished at: Wed Dec 30 22:28:24 EST 2009
[INFO] Final Memory: 44M/115M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2277/changes&gt;
Changes:
[jdeolive] GEOS-3748, null check when listing directory contents
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.701 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.831 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 4 minutes 22 seconds
[INFO] Finished at: Fri Jan 01 19:39:47 EST 2010
[INFO] Final Memory: 44M/113M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2278/changes&gt;
Changes:
[jdeolive] setting svn:ignore
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.485 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.278 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.947 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 4 minutes 38 seconds
[INFO] Finished at: Mon Jan 04 10:44:46 EST 2010
[INFO] Final Memory: 44M/112M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2279/&gt;
[...truncated 21639 lines...]
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.39 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.084 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.24 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.864 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 4 minutes 9 seconds
[INFO] Finished at: Mon Jan 04 14:52:23 EST 2010
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2280/changes&gt;
Changes:
[simboss] GEOS-3753
[simboss] GEOS-3753
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.514 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.37 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.61 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 4 minutes 32 seconds
[INFO] Finished at: Tue Jan 05 11:40:31 EST 2010
[INFO] Final Memory: 43M/120M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2281/changes&gt;
Changes:
[simboss] GEOS-3754
[...truncated 21823 lines...]
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.49 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.31 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 2.888 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 3 minutes 4 seconds
[INFO] Finished at: Tue Jan 05 12:39:03 EST 2010
[INFO] Final Memory: 43M/109M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2282/changes&gt;
Changes:
[simboss] GEOS-3754
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.423 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.294 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.809 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 3 minutes 11 seconds
[INFO] Finished at: Tue Jan 05 13:39:19 EST 2010
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2283/&gt;
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.723 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.323 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 9.68 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 3 minutes 21 seconds
[INFO] Finished at: Tue Jan 05 23:51:15 EST 2010
[INFO] Final Memory: 43M/108M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2284/changes&gt;
Changes:
[afabiani] - WCS 1.0.0 ELEVATION as Band
[...truncated 1244 lines...]
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:126)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.geoserver.wcs.response.Wcs10GetCapabilitiesResponse.write(Wcs10GetCapabilitiesResponse.java:45)
  ... 49 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at org.geoserver.wcs.response.Wcs10CapsTransformer$WCS100CapsTranslator.encode(Wcs10CapsTransformer.java:141)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 51 more
06 Jan 09:38:08 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: Could not find section 'Bogus'
  at org.geoserver.wcs.kvp.SectionKvpParser.parse(SectionKvpParser.java:29)
  at org.geoserver.ows.util.KvpUtils.parse(KvpUtils.java:489)
  at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:1095)
  at org.geoserver.ows.Dispatcher.init(Dispatcher.java:263)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1054)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1021)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:463)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:444)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:718)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:680)
  at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:116)
<wcs:WCS_Capabilities xmlns:wcs="http://www.opengis.net/wcs&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; updateSequence="0" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/wcs http://localhost:80/geoserver/schemas/wcs/1.0.0/wcsCapabilities.xsd&quot;&gt;
<wcs:Service version="1.0.0">
<wcs:metadataLink about="http://geoserver.sourceforge.net/html/index.php&quot; metadataType="other"/>
<wcs:description>
This is a description of your Web Coverage Server.
     </wcs:description>
<wcs:name>My GeoServer WCS</wcs:name>
<wcs:label>My GeoServer WCS</wcs:label>
<wcs:keywords>
<wcs:keyword>WCS</wcs:keyword>
<wcs:keyword>WMS</wcs:keyword>
<wcs:keyword>GEOSERVER</wcs:keyword>
</wcs:keywords>
<wcs:responsibleParty>
<wcs:individualName>Andrea Aime</wcs:individualName>
<wcs:contactInfo>
<wcs:phone/>
<wcs:address/>
</wcs:contactInfo>
</wcs:responsibleParty>
<wcs:fees>NONE</wcs:fees>
<wcs:accessConstraints>NONE</wcs:accessConstraints>
</wcs:Service>
<wcs:Capability>
<wcs:Request>
<wcs:GetCapabilities>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
<wcs:OnlineResource xlink:href="wcs?"/>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
</wcs:GetCapabilities>
<wcs:DescribeCoverage>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
</wcs:DescribeCoverage>
<wcs:GetCoverage>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
</wcs:GetCoverage>
</wcs:Request>
<wcs:Exception>
<wcs:Format>application/vnd.ogc.se_xml</wcs:Format>
</wcs:Exception>
</wcs:Capability>
<wcs:ContentMetadata version="1.0.0">
<wcs:CoverageOfferingBrief>
<wcs:description>BlueMarble description</wcs:description>
<wcs:name>wcs:BlueMarble</wcs:name>
<wcs:label>BlueMarble</wcs:label>
<wcs:lonLatEnvelope srsName="urn:ogc:def:crs:OGC:1.3:CRS84">
<gml:pos>146.49999999999477 -44.49999999999785</gml:pos>
<gml:pos>147.99999999999474 -42.99999999999787</gml:pos>
</wcs:lonLatEnvelope>
<wcs:keywords>
<wcs:keyword>BlueMarble</wcs:keyword>
</wcs:keywords>
</wcs:CoverageOfferingBrief>
<wcs:description>DEM description</wcs:description>
<wcs:name>wcs:DEM</wcs:name>
<wcs:label>DEM</wcs:label>
<gml:pos>144.999999999998 -42.999999999986805</gml:pos>
<gml:pos>145.9999999999976 -40.99999999998761</gml:pos>
<wcs:keywords>
<wcs:keyword>DEM</wcs:keyword>
</wcs:keywords>
<wcs:description>RotatedCad description</wcs:description>
<wcs:name>wcs:RotatedCad</wcs:name>
<wcs:label>RotatedCad</wcs:label>
<gml:pos>-4.356399966874192 0.001739899399003904</gml:pos>
<gml:pos>-4.356399958827462 0.0017399037939527457</gml:pos>
<wcs:keywords>
<wcs:keyword>RotatedCad</wcs:keyword>
</wcs:keywords>
<wcs:description>World description</wcs:description>
<wcs:name>wcs:World</wcs:name>
<wcs:label>World</wcs:label>
<gml:pos>-180.0 -90.0</gml:pos>
<gml:pos>180.0 90.0</gml:pos>
<wcs:keywords>
<wcs:keyword>World</wcs:keyword>
</wcs:keywords>
</wcs:ContentMetadata>
</wcs:WCS_Capabilities>
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.261 sec
Results :
Failed tests:
  testRangeSubsetKeys(org.geoserver.wcs.xml.GetCoverageXmlParserTest)
Tests run: 38, Failures: 1, Errors: 0, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_0/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 2 minutes 14 seconds
[INFO] Finished at: Wed Jan 06 09:38:09 EST 2010
[INFO] Final Memory: 38M/116M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2285/&gt;
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.503 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.317 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.976 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 4 minutes 11 seconds
[INFO] Finished at: Wed Jan 06 10:25:09 EST 2010
[INFO] Final Memory: 44M/114M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2286/changes&gt;
Changes:
[mbarto] dxf community module: fixed a bug in JulianDate month calculation
[...truncated 21811 lines...]
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.443 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.32 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 6.1 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 4 minutes 20 seconds
[INFO] Finished at: Thu Jan 07 04:39:59 EST 2010
Failed to send e-mail to mbarto because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2287/changes&gt;
Changes:
[dany111] GEOS-3744
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
GEOGCS["WGS 84",
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
        <KeywordList>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.452 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.435 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 5.869 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 4 minutes 36 seconds
[INFO] Finished at: Thu Jan 07 06:40:36 EST 2010
[INFO] Final Memory: 43M/117M
Failed to send e-mail to dany111 because no e-mail address is known, and no default e-mail domain is configured
Ciao Arne,
do you anything about these test failures :slight_smile: ?
Simone.
Ing. Simone Giannecchini
Founder - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
Changes:
[dany111] GEOS-3744
</LegendURL>
</Style>
</Layer>
<KeywordList>
</KeywordList>
GEOGCS["WGS 84",
<Style>
<Abstract/>
</LegendURL>
</Style>
</Layer>
<KeywordList>
</KeywordList>
GEOGCS["WGS 84",
<Style>
<Abstract/>
</LegendURL>
</Style>
</Layer>
<KeywordList>
</KeywordList>
GEOGCS["WGS 84",
UNIT["m", 1.0],
<Style>
<Abstract/>
</LegendURL>
</Style>
</Layer>
<KeywordList>
</KeywordList>
GEOGCS["WGS 84",
<Style>
<Abstract/>
</LegendURL>
</Style>
</Layer>
<KeywordList>
</KeywordList>
GEOGCS["WGS 84",
UNIT["m", 1.0],
<Style>
<Abstract/>
</LegendURL>
</Style>
</Layer>
</Layer>
</Capability>
Results :
[INFO] [jar:jar]
T E S T S
Results :
Tests in error:
Apologies, I had only read the first failure and ignored the ones afterwards.
-Arne
Simone Giannecchini wrote:
Ciao Arne,
Simone.
Via Carignoni 51
55041 Camaiore (LU)
fax: +39 0584983027
Changes:
[dany111] GEOS-3744
         </LegendURL>
       </Style>
     </Layer>
       <KeywordList>
       </KeywordList>
GEOGCS["WGS 84",
       <Style>
         <Abstract/>
         </LegendURL>
       </Style>
     </Layer>
       <KeywordList>
       </KeywordList>
GEOGCS["WGS 84",
       <Style>
         <Abstract/>
         </LegendURL>
       </Style>
     </Layer>
       <KeywordList>
       </KeywordList>
GEOGCS["WGS 84",
UNIT["m", 1.0],
       <Style>
         <Abstract/>
         </LegendURL>
       </Style>
     </Layer>
       <KeywordList>
       </KeywordList>
GEOGCS["WGS 84",
       <Style>
         <Abstract/>
         </LegendURL>
       </Style>
     </Layer>
       <KeywordList>
       </KeywordList>
GEOGCS["WGS 84",
UNIT["m", 1.0],
       <Style>
         <Abstract/>
         </LegendURL>
       </Style>
     </Layer>
   </Layer>
</Capability>
Results :
[INFO] [jar:jar]
T E S T S
Results :
Tests in error:
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2288/changes&gt;
