[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2290
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2290/changes&gt;
Changes:
[afabiani] - Improving WCS1.0 tests with ND requests also
[aaime] Have ajax debug disabled by default, it is only useful on occasion (and it can be turned on using the dev toolbar in that case)
[aaime] Allow dialog to be resized, set ok as the default form button
[...truncated 335 lines...]
[INFO] [compiler:compile]
[INFO] Compiling 79 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes&gt;
[INFO] [resources:testResources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] Compiling 16 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports&gt;
T E S T S
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.context.support.FileSystemXmlApplicationContext).
log4j:WARN Please initialize the log4j system properly.
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.298 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.247 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.103 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Results :
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target&gt;
[INFO] [resources:resources]
[INFO] snapshot org.geotools:gt-cql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 231 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes&gt;
[INFO] snapshot org.geoserver:ows:2.1-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:ows:2.1-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 51 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.decorators.ReadOnlyDataAccessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.975 sec
Running org.geoserver.catalog.impl.CascadeDeleteVisitorTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 11.979 sec
Running org.geoserver.catalog.impl.InfoObjectProxyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Running org.geoserver.config.GeoServerPersisterTest
Tests run: 26, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.089 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.4 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Jan 7, 2010 10:36:20 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.409 sec
Running org.geoserver.vfny.global.TolerantStartupTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
07 Jan 10:36:20 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Jan 07 10:36:20 EST 2010]; root of context hierarchy
07 Jan 10:36:20 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
07 Jan 10:36:20 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
07 Jan 10:36:20 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock54629data&gt;
07 Jan 10:36:20 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
07 Jan 10:36:20 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
07 Jan 10:36:20 INFO [geoserver.catalog] - Default namespace: 'gs'
07 Jan 10:36:20 INFO [geoserver.catalog] - Loaded style 'Default'
07 Jan 10:36:20 INFO [geoserver.catalog] - Loaded style 'Buildings'
07 Jan 10:36:20 INFO [geoserver.catalog] - Processed data store 'cite', enabled
07 Jan 10:36:20 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
07 Jan 10:36:20 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
07 Jan 10:36:20 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Jan 07 10:36:20 EST 2010]; root of context hierarchy
07 Jan 10:36:20 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl-417bf663:126096d9636:-74a1'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.067 sec
Running org.geoserver.catalog.impl.util.LegacyCatalogImporterTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.184 sec
Running org.geoserver.config.util.XStreamPersisterTest
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.11 sec
Running org.geoserver.config.LegacyConfigurationImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.security.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.template.FeatureWrapperTest
Jan 7, 2010 10:36:21 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.401 sec
Running org.geoserver.ows.CustomManglerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.442 sec
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.182 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.logging.LegacyLoggingImporterTest
Running org.geoserver.security.decorators.ReadOnlyFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.185 sec
Running org.geoserver.security.SecureCatalogImplTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.305 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
07 Jan 10:36:23 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
07 Jan 10:36:23 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
07 Jan 10:36:23 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.367 sec
Running org.vfny.geoserver.crs.OvverideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.327 sec
Running org.geoserver.security.DataAccessRuleDAOTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.116 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.16 sec
Running org.geoserver.catalog.SchemaMappingTest
07 Jan 10:36:25 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
07 Jan 10:36:25 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
07 Jan 10:36:25 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.04 sec
Running org.geoserver.catalog.ResourcePoolTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.5 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.59 sec <<< FAILURE!
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.DataAccessRuleTest
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.01 sec <<< FAILURE!
Running org.geoserver.security.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0 sec <<< FAILURE!
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.051 sec <<< FAILURE!
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 50, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.06 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.009 sec <<< FAILURE!
Results :
Tests in error:
  testForce(org.vfny.geoserver.ProjectionPolicyTest)
  testReproject(org.vfny.geoserver.ProjectionPolicyTest)
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest)
  testFullAccess(org.geoserver.security.SecureCatalogIntegrationTest)
  testCannotRead(org.geoserver.security.SecureCatalogIntegrationTest)
  testCannotWrite(org.geoserver.security.SecureCatalogIntegrationTest)
  testBasic(org.geoserver.ows.URLManglersTest)
  testKVP(org.geoserver.ows.URLManglersTest)
  testProxyBase(org.geoserver.ows.URLManglersTest)
  testCascadeLayer(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeStore(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeWorkspace(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeStyle(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
Tests run: 227, Failures: 0, Errors: 14, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 33 seconds
[INFO] Finished at: Thu Jan 07 10:36:29 EST 2010
[INFO] Final Memory: 35M/109M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2291/changes&gt;
Changes:
[bmmpxf] (New) new Windows installer (replacing the previous two)
[...truncated 329 lines...]
T E S T S
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.037 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.154 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.08 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.12 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.795 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.074 sec
Tests run: 26, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.069 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.415 sec
Jan 7, 2010 12:34:27 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.326 sec
07 Jan 12:34:27 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Jan 07 12:34:27 EST 2010]; root of context hierarchy
07 Jan 12:34:27 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
07 Jan 12:34:27 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
07 Jan 12:34:27 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock62225data&gt;
07 Jan 12:34:27 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
07 Jan 12:34:27 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
07 Jan 12:34:27 INFO [geoserver.catalog] - Default namespace: 'gs'
07 Jan 12:34:27 INFO [geoserver.catalog] - Loaded style 'Default'
07 Jan 12:34:27 INFO [geoserver.catalog] - Loaded style 'Buildings'
07 Jan 12:34:27 INFO [geoserver.catalog] - Processed data store 'cite', enabled
07 Jan 12:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
07 Jan 12:34:27 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
07 Jan 12:34:27 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Jan 07 12:34:27 EST 2010]; root of context hierarchy
07 Jan 12:34:27 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl--7642a8b1:12609d9cb88:-74a1'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.07 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.163 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.149 sec
Jan 7, 2010 12:34:27 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Jan 7, 2010 12:34:28 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.21 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.521 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.466 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.08 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.04 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.7 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.48 sec
07 Jan 12:34:35 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
07 Jan 12:34:35 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
07 Jan 12:34:35 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.15 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.318 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.063 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.08 sec
07 Jan 12:34:38 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
07 Jan 12:34:38 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
07 Jan 12:34:38 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.969 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.641 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.58 sec <<< FAILURE!
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.028 sec <<< FAILURE!
Tests run: 50, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.065 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.008 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 1 minute 38 seconds
[INFO] Finished at: Thu Jan 07 12:34:41 EST 2010
[INFO] Final Memory: 36M/114M
Failed to send e-mail to bmmpxf because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2292/changes&gt;
Changes:
[bmmpxf] Fixed typo in Windows installer filename output.
[...truncated 318 lines...]
T E S T S
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.08 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.16 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.026 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.889 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.082 sec
Tests run: 26, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.57 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.385 sec
Jan 7, 2010 1:36:14 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.373 sec
07 Jan 13:36:14 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Jan 07 13:36:14 EST 2010]; root of context hierarchy
07 Jan 13:36:14 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
07 Jan 13:36:14 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
07 Jan 13:36:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock12881data&gt;
07 Jan 13:36:14 INFO [geoserver.catalog] - Loaded namespace 'gs' (http://geoserver.org)
07 Jan 13:36:14 INFO [geoserver.catalog] - Loaded namespace 'cite' (http://www.opengis.net/cite)
07 Jan 13:36:14 INFO [geoserver.catalog] - Default namespace: 'gs'
07 Jan 13:36:14 INFO [geoserver.catalog] - Loaded style 'Default'
07 Jan 13:36:14 INFO [geoserver.catalog] - Loaded style 'Buildings'
07 Jan 13:36:14 INFO [geoserver.catalog] - Processed data store 'cite', enabled
07 Jan 13:36:14 INFO [geoserver.catalog] - Loaded feature type 'cite:BasicPolygons'
07 Jan 13:36:14 INFO [geoserver.catalog] - Loaded feature type 'cite:Buildings'
07 Jan 13:36:14 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Jan 07 13:36:14 EST 2010]; root of context hierarchy
07 Jan 13:36:14 INFO [geoserver.catalog] - Disposing datastore 'DataStoreInfoImpl-62426f2e:1260a125ec4:-74a1'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.091 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.194 sec
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.139 sec
Jan 7, 2010 1:36:15 PM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.215 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.386 sec
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.141 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.035 sec
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.137 sec
07 Jan 13:36:16 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
07 Jan 13:36:16 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
07 Jan 13:36:16 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.347 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.187 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.332 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.09 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.116 sec
07 Jan 13:36:19 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
07 Jan 13:36:19 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
07 Jan 13:36:19 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.238 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.411 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.454 sec <<< FAILURE!
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.006 sec <<< FAILURE!
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.007 sec <<< FAILURE!
Tests run: 50, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Results :
Tests in error:
[INFO] Total time: 26 seconds
[INFO] Finished at: Thu Jan 07 13:36:22 EST 2010
[INFO] Final Memory: 36M/110M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2293/changes&gt;
Changes:
[afabiani] - fixing build
[...truncated 1672 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.geoserver.wcs.response.Wcs10GetCapabilitiesResponse.write(Wcs10GetCapabilitiesResponse.java:45)
  ... 49 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at org.geoserver.wcs.response.Wcs10CapsTransformer$WCS100CapsTranslator.encode(Wcs10CapsTransformer.java:141)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 51 more
07 Jan 14:35:39 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: Could not find section 'Bogus'
  at org.geoserver.wcs.kvp.SectionKvpParser.parse(SectionKvpParser.java:29)
  at org.geoserver.ows.util.KvpUtils.parse(KvpUtils.java:489)
  at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:1095)
  at org.geoserver.ows.Dispatcher.init(Dispatcher.java:263)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1054)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1021)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:463)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:444)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:718)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:680)
  at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:116)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:126)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
<wcs:WCS_Capabilities xmlns:wcs="http://www.opengis.net/wcs&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:ows="http://www.opengis.net/ows/1.1&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; updateSequence="0" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/wcs http://localhost:80/geoserver/schemas/wcs/1.0.0/wcsCapabilities.xsd&quot;&gt;
<wcs:Service version="1.0.0">
<wcs:metadataLink about="http://geoserver.sourceforge.net/html/index.php&quot; metadataType="other"/>
<wcs:description>
This is a description of your Web Coverage Server.
     </wcs:description>
<wcs:name>My GeoServer WCS</wcs:name>
<wcs:label>My GeoServer WCS</wcs:label>
<wcs:keywords>
<wcs:keyword>WCS</wcs:keyword>
<wcs:keyword>WMS</wcs:keyword>
<wcs:keyword>GEOSERVER</wcs:keyword>
</wcs:keywords>
<wcs:responsibleParty>
<wcs:individualName>Andrea Aime</wcs:individualName>
<wcs:contactInfo>
<wcs:phone/>
<wcs:address/>
</wcs:contactInfo>
</wcs:responsibleParty>
<wcs:fees>NONE</wcs:fees>
<wcs:accessConstraints>NONE</wcs:accessConstraints>
</wcs:Service>
<wcs:Capability>
<wcs:Request>
<wcs:GetCapabilities>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
<wcs:OnlineResource xlink:href="wcs?"/>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
</wcs:GetCapabilities>
<wcs:DescribeCoverage>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
</wcs:DescribeCoverage>
<wcs:GetCoverage>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
</wcs:GetCoverage>
</wcs:Request>
<wcs:Exception>
<wcs:Format>application/vnd.ogc.se_xml</wcs:Format>
</wcs:Exception>
</wcs:Capability>
<wcs:ContentMetadata version="1.0.0">
<wcs:CoverageOfferingBrief>
<wcs:description>BlueMarble description</wcs:description>
<wcs:name>wcs:BlueMarble</wcs:name>
<wcs:label>BlueMarble</wcs:label>
<wcs:lonLatEnvelope srsName="urn:ogc:def:crs:OGC:1.3:CRS84">
<gml:pos>146.49999999999477 -44.49999999999785</gml:pos>
<gml:pos>147.99999999999474 -42.99999999999787</gml:pos>
</wcs:lonLatEnvelope>
<wcs:keywords>
<wcs:keyword>BlueMarble</wcs:keyword>
</wcs:keywords>
</wcs:CoverageOfferingBrief>
<wcs:description>DEM description</wcs:description>
<wcs:name>wcs:DEM</wcs:name>
<wcs:label>DEM</wcs:label>
<gml:pos>144.999999999998 -42.999999999986805</gml:pos>
<gml:pos>145.9999999999976 -40.99999999998761</gml:pos>
<wcs:keywords>
<wcs:keyword>DEM</wcs:keyword>
</wcs:keywords>
<wcs:description>RotatedCad description</wcs:description>
<wcs:name>wcs:RotatedCad</wcs:name>
<wcs:label>RotatedCad</wcs:label>
<gml:pos>-4.356399966874192 0.001739899399003904</gml:pos>
<gml:pos>-4.356399958827462 0.0017399037939527457</gml:pos>
<wcs:keywords>
<wcs:keyword>RotatedCad</wcs:keyword>
</wcs:keywords>
<wcs:description>World description</wcs:description>
<wcs:name>wcs:World</wcs:name>
<wcs:label>World</wcs:label>
<gml:pos>-180.0 -90.0</gml:pos>
<gml:pos>180.0 90.0</gml:pos>
<wcs:keywords>
<wcs:keyword>World</wcs:keyword>
</wcs:keywords>
<wcs:description>watertemp description</wcs:description>
<wcs:name>wcs:watertemp</wcs:name>
<wcs:label>watertemp</wcs:label>
<gml:pos>0.23722068851276978 40.562080748421806</gml:pos>
<gml:pos>14.592757149389236 44.55808294568743</gml:pos>
<wcs:keywords>
<wcs:keyword>watertemp</wcs:keyword>
</wcs:keywords>
</wcs:ContentMetadata>
</wcs:WCS_Capabilities>
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.212 sec
Results :
Failed tests:
  testWrongElevationRangeSubset(org.geoserver.wcs.GetCoverageTest)
  testNDRequest(org.geoserver.wcs.xml.GetCoverageXmlParserTest)
Tests run: 46, Failures: 2, Errors: 0, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_0/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 2 minutes 13 seconds
[INFO] Finished at: Thu Jan 07 14:35:40 EST 2010
[INFO] Final Memory: 38M/113M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2294/changes&gt;
Changes:
[simboss] commenting out tests that require feature not yet committed to the mosaic gt plugin
[...truncated 1665 lines...]
  ... 49 more
  ... 51 more
07 Jan 19:36:58 ERROR [geoserver.ows] -
<wcs:description>
     </wcs:description>
<wcs:keywords>
</wcs:keywords>
<wcs:contactInfo>
<wcs:phone/>
<wcs:address/>
</wcs:contactInfo>
</wcs:Service>
<wcs:Capability>
<wcs:Request>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
<wcs:GetCoverage>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Get>
</wcs:Get>
</wcs:HTTP>
</wcs:DCPType>
<wcs:DCPType>
<wcs:HTTP>
<wcs:Post>
</wcs:Post>
</wcs:HTTP>
</wcs:DCPType>
</wcs:GetCoverage>
</wcs:Request>
<wcs:Exception>
</wcs:Exception>
</wcs:Capability>
<wcs:keywords>
</wcs:keywords>
<wcs:keywords>
</wcs:keywords>
<wcs:keywords>
</wcs:keywords>
<wcs:keywords>
</wcs:keywords>
<wcs:keywords>
</wcs:keywords>
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.397 sec
Results :
Failed tests:
Tests run: 42, Failures: 1, Errors: 0, Skipped: 0
[INFO] Total time: 1 minute 2 seconds
[INFO] Finished at: Thu Jan 07 19:36:58 EST 2010
[INFO] Final Memory: 38M/107M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2295/changes&gt;
Changes:
[...truncated 22855 lines...]
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/rest/2.1-SNAPSHOT/rest-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/rest/2.1-SNAPSHOT/rest-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/rest/2.1-SNAPSHOT/rest-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Web Modules
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target&gt;
[INFO] [site:attach-descriptor]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/web/2.1-SNAPSHOT/web-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/2.1-SNAPSHOT/web-2.1-SNAPSHOT-tests.jar
[INFO] Building Core UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 134 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/classes&gt;
[INFO] Compiling 45 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.admin.ContactPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.02 sec
Running org.geoserver.web.data.store.StorePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.05 sec
Running org.geoserver.web.data.store.CoverageStoreEditPageTest
Jan 7, 2010 8:40:03 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 1.67 sec <<< FAILURE!
Running org.geoserver.web.wicket.KeywordsEditorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.24 sec
Running org.geoserver.web.data.workspace.WorkspacePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.009 sec
Running org.geoserver.web.wicket.CRSPanelTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.242 sec
Running org.geoserver.web.data.layergroup.LayerGroupEditPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.891 sec
Running org.geoserver.web.admin.StatusPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.603 sec
Running org.geoserver.web.data.table.NewLayerProviderTest
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.793 sec <<< FAILURE!
Running org.geoserver.web.wicket.GeoServerPagingNavigatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.28 sec
Running org.geoserver.web.data.workspace.WorkspaceEditPageTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.45 sec
Running org.geoserver.web.data.workspace.WorkspaceNewPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.318 sec
Running org.geoserver.web.data.layergroup.LayerGroupNewPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.262 sec
Running org.geoserver.web.wicket.browser.FileBreadcrumsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.111 sec
Running org.geoserver.web.GeoServerHomePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.379 sec
Running org.geoserver.web.admin.GlobalSettingsPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.32 sec
Running org.geoserver.web.GeoServerSecuredPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.721 sec
Running org.geoserver.web.data.layergroup.LayerGroupPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.468 sec
Running org.geoserver.web.admin.JAIPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.41 sec
Running org.geoserver.web.data.store.NewDataPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.765 sec
Running org.geoserver.web.wicket.EnvelopePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.383 sec
Running org.geoserver.web.publish.HTTPLayerConfigTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.591 sec
Running org.geoserver.web.ConverterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.178 sec
Running org.geoserver.web.data.ConfirmRemovalPanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.682 sec
Running org.geoserver.web.data.store.CoverageStoreNewPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.32 sec
Running org.geoserver.web.data.layer.NewLayerPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.837 sec
Running org.geoserver.web.wicket.browser.GeoServerFileChooserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.964 sec
Running org.geoserver.web.data.store.DataAccessEditPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.828 sec
Running org.geoserver.web.data.resource.ResourceConfigurationPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.455 sec
Running org.geoserver.web.wicket.FileExistsValidatorTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.099 sec <<< FAILURE!
Running org.geoserver.web.wicket.GeoServerTablePanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.144 sec
Running org.geoserver.web.wicket.SRSPanelTest
07 Jan 20:40:37 ERROR [wicket.RequestCycle] - there was an error detaching the request from the session org.geoserver.web.acegi.GeoServerSession@anonymised.com
java.lang.ClassCastException: org.apache.wicket.protocol.http.HttpSessionStore
  at org.apache.wicket.protocol.http.SecondLevelCacheSessionStore$SecondLevelCachePageMap.getStore(SecondLevelCacheSessionStore.java:371)
  at org.apache.wicket.protocol.http.SecondLevelCacheSessionStore$SecondLevelCachePageMap.put(SecondLevelCacheSessionStore.java:337)
  at org.apache.wicket.Session.requestDetached(Session.java:1371)
  at org.apache.wicket.RequestCycle.detach(RequestCycle.java:1149)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1437)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:578)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:469)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:378)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:289)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:229)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:277)
  at org.geoserver.web.wicket.SRSPanelTest.setUpInternal(SRSPanelTest.java:15)
  at org.geoserver.test.OneTimeSetupTest.setUp(OneTimeSetupTest.java:94)
  at junit.framework.TestCase.runBare(TestCase.java:128)
  at sun.reflect.GeneratedMethodAccessor165.invoke(Unknown Source)
07 Jan 20:40:37 ERROR [wicket.RequestCycle] - org.apache.wicket.protocol.http.HttpSessionStore
  at org.apache.wicket.protocol.http.SecondLevelCacheSessionStore$SecondLevelCachePageMap.get(SecondLevelCacheSessionStore.java:316)
  at org.apache.wicket.Session.getPage(Session.java:750)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.resolveRenderedPage(AbstractRequestCycleProcessor.java:448)
  at org.apache.wicket.protocol.http.WebRequestCycleProcessor.resolve(WebRequestCycleProcessor.java:139)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1297)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:532)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:495)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:483)
  at org.apache.wicket.util.tester.BaseWicketTester.executeListener(BaseWicketTester.java:248)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:233)
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.301 sec <<< FAILURE!
Running org.geoserver.web.wicket.WKTToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.web.wicket.browser.FileDataViewTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.55 sec
Running org.geoserver.web.wicket.SRSToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.web.GeoServerBasePageTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0 sec <<< FAILURE!
Running org.geoserver.web.data.resource.ResourceNameValidatorTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.web.data.store.DataAccessNewPageTest
Tests run: 6, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 0.07 sec <<< FAILURE!
Results :
Tests in error:
  testLoad(org.geoserver.web.data.store.CoverageStoreEditPageTest)
  testNameRequired(org.geoserver.web.data.store.CoverageStoreEditPageTest)
  testChangeName(org.geoserver.web.data.store.CoverageStoreEditPageTest)
  testWorkspaceSyncsUpWithNamespace(org.geoserver.web.data.store.CoverageStoreEditPageTest)
  testEmpty(org.geoserver.web.data.table.NewLayerProviderTest)
  testFeatureType(org.geoserver.web.data.table.NewLayerProviderTest)
  testCoverages(org.geoserver.web.data.table.NewLayerProviderTest)
  testPublishedUnpublishedWithChangedResourceName(org.geoserver.web.data.table.NewLayerProviderTest)
  testLoad(org.geoserver.web.wicket.SRSPanelTest)
  testLoginFormShowsWhenLoggedOut(org.geoserver.web.GeoServerBasePageTest)
  testLogoutFormShowsWhenLoggedIn(org.geoserver.web.GeoServerBasePageTest)
  testPageRendersOnLoad(org.geoserver.web.data.store.DataAccessNewPageTest)
  testInitCreateNewDataStoreInvalidDataStoreFactoryName(org.geoserver.web.data.store.DataAccessNewPageTest)
  testDefaultWorkspace(org.geoserver.web.data.store.DataAccessNewPageTest)
  testDefaultNamespace(org.geoserver.web.data.store.DataAccessNewPageTest)
  testDataStoreParametersAreCreated(org.geoserver.web.data.store.DataAccessNewPageTest)
  testInitCreateNewDataStoreSetsNamespaceParam(org.geoserver.web.data.store.DataAccessNewPageTest)
Tests run: 98, Failures: 0, Errors: 18, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 4 minutes 43 seconds
[INFO] Finished at: Thu Jan 07 20:40:38 EST 2010
[INFO] Final Memory: 45M/109M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2296/changes&gt;
Changes:
[aaime] GEOS-3757, Request logging filter + log bodies option breaks Wicket AJAX requests
[...truncated 22857 lines...]
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.46 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.251 sec
Jan 8, 2010 9:46:30 AM java.util.prefs.FileSystemPreferences$7 run
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 1.198 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.148 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.372 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.308 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.185 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.756 sec
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.64 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.293 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.997 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.17 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.233 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.03 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.349 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.508 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.644 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.355 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.62 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.149 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.311 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.69 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.25 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.96 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.398 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.618 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.684 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.838 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.515 sec
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.098 sec <<< FAILURE!
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.106 sec
08 Jan 09:46:59 ERROR [wicket.RequestCycle] - there was an error detaching the request from the session org.geoserver.web.acegi.GeoServerSession@anonymised.com
08 Jan 09:46:59 ERROR [wicket.RequestCycle] - org.apache.wicket.protocol.http.HttpSessionStore
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.69 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.226 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.006 sec <<< FAILURE!
Tests run: 6, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 0.011 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 4 minutes 58 seconds
[INFO] Finished at: Fri Jan 08 09:47:00 EST 2010
[INFO] Final Memory: 44M/109M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2297/changes&gt;
Changes:
[aaime] GEOS-3752, Avoid using File.deleteOnExit in production code
[aaime] Tone down redundant log message
[...truncated 22858 lines...]
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.002 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.948 sec
Jan 8, 2010 10:40:16 AM java.util.prefs.FileSystemPreferences$7 run
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 1.5 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.98 sec
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.747 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.176 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.617 sec
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.556 sec <<< FAILURE!
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.234 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.74 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.94 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.213 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.037 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.33 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.6 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.669 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.529 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.322 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.587 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.191 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.88 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.3 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.623 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.366 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.52 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.73 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.81 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.49 sec
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.09 sec <<< FAILURE!
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.135 sec
08 Jan 10:40:43 ERROR [wicket.RequestCycle] - there was an error detaching the request from the session org.geoserver.web.acegi.GeoServerSession@anonymised.com
08 Jan 10:40:43 ERROR [wicket.RequestCycle] - org.apache.wicket.protocol.http.HttpSessionStore
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.325 sec <<< FAILURE!
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.069 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.623 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.005 sec <<< FAILURE!
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Tests run: 6, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 0.01 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 5 minutes 15 seconds
[INFO] Finished at: Fri Jan 08 10:40:44 EST 2010
[INFO] Final Memory: 45M/115M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2298/changes&gt;
