[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2356
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2356/changes&gt;
Changes:
[aaime] GEOS-3792 Use full vector rendering for SVG graphics and marks in PDF and SVG
[...truncated 22147 lines...]
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/surefire-reports&gt;
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT-sources.jar
[INFO] Building WFS UI Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target&gt;
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/classes&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.web.WFSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.738 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT-sources.jar
[INFO] Building WCS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target&gt;
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/classes&gt;
[INFO] snapshot org.geoserver:wcs1_1:2.1-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_1:2.1-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wcs.web.data.WCSLayerConfigTest
Jan 29, 2010 12:43:27 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Jan 29, 2010 12:43:29 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Jan 29, 2010 12:43:31 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/./target/mock64188data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.368 sec
Running org.geoserver.wcs.web.WCSAdminPageTest
Jan 29, 2010 12:43:35 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/./target/mock64190data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.37 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT-sources.jar
[INFO] Building Demoes Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target&gt;
[INFO] snapshot org.geotools:gt-sample-data:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sample-data:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/classes&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.demo.MapPreviewPageTest
Jan 29, 2010 12:43:49 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.034 sec
Running org.geoserver.web.demo.DemoRequestsPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.476 sec
Running org.geoserver.web.demo.SRSListPageTest
Jan 29, 2010 12:44:01 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.498 sec
Results :
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target&gt;
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/classes&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.security.user.NewUserPageTest
Jan 29, 2010 12:44:15 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 10.399 sec <<< FAILURE!
Running org.geoserver.web.security.user.UserListPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.386 sec
Running org.geoserver.web.security.data.DataAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.043 sec
Running org.geoserver.web.security.data.NewRulePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.521 sec
Running org.geoserver.web.security.ConfirmRemovalUserPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.325 sec
Running org.geoserver.web.security.user.EditUserPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.613 sec
Running org.geoserver.web.security.ConfirmRemovalServicePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.64 sec
Running org.geoserver.web.security.ConfirmRemovalDataAccessRulePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.518 sec
Running org.geoserver.web.security.service.ServiceAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.992 sec
Running org.geoserver.web.security.catalog.CatalogModePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.539 sec
Results :
Tests in error:
  testFill(org.geoserver.web.security.user.NewUserPageTest)
Tests run: 18, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 6 minutes 49 seconds
[INFO] Finished at: Fri Jan 29 12:44:33 EST 2010
[INFO] Final Memory: 46M/112M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2357/changes&gt;
