[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2371
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2371/changes&gt;
Changes:
[ang05a] GEOT-2927: Filtering app-schema features from denormalised view only display the first property in multi-valued properties
[...truncated 27569 lines...]
            <gml:name>GUNTHORPE FORMATION</gml:name>
            <gsml:observationMethod>
                <gsml:CGI_TermValue>
                    <gsml:value codeSpace="http://urn.opengis.net">urn:ogc:def:nil:OGC::missing</gsml:value>
                </gsml:CGI_TermValue>
            </gsml:observationMethod>
            <gsml:shape>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </gsml:shape>
            <gsml:specification>
                <gsml:GeologicUnit gml:id="gu.25699">
                    <gml:description>Olivine basalt, tuff, microgabbro, minor sedimentary rocks</gml:description>
                    <gml:name codeSpace="urn:ietf:rfc:2141">Yaugher Volcanic Group</gml:name>
                    <gml:name>-Py</gml:name>
                    <gsml:occurence xlink:href="urn:cgi:feature:MappedFeature:mf1"/>
                    <gsml:exposureColor>
                            <gsml:value codeSpace="some:uri">Blue</gsml:value>
                    </gsml:exposureColor>
                    <gsml:outcropCharacter>
                            <gsml:value codeSpace="some:uri">x</gsml:value>
                    </gsml:outcropCharacter>
                    <gsml:composition>
                        <gsml:CompositionPart>
                            <gsml:proportion>
                                    <gsml:value codeSpace="some:uri">significant</gsml:value>
                            </gsml:proportion>
                            <gsml:role>interbedded component</gsml:role>
                        </gsml:CompositionPart>
                    </gsml:composition>
                </gsml:GeologicUnit>
            </gsml:specification>
        </gsml:MappedFeature>
    </gml:featureMembers>
</wfs:FeatureCollection>
Feb 5, 2010 5:33:02 AM org.geoserver.test.XYGeomTest testDescribeFeatureType
INFO: WFS DescribeFeatureType response:
<xsd:schema elementFormDefault="qualified" targetNamespace="http://test"
    xmlns:test="http://test" xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot;&gt;
    <xsd:include schemaLocation="<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock24145data/featureTypes/test_PointFeature/GeometrylessTest.xsd&quot;/&gt;&gt;
</xsd:schema>
Feb 5, 2010 5:33:02 AM org.geoserver.test.XYGeomTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2"
    timeStamp="2010-02-05T05:33:02.547-05:00"
    xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:ogc="http://www.opengis.net/ogc&quot;
    xmlns:ows="http://www.opengis.net/ows&quot; xmlns:test="http://test"
    xmlns:wfs="http://www.opengis.net/wfs&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://test <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock24145data/featureTypes/test_PointFeature/GeometrylessTest.xsd&gt; http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMembers>
        <test:PointFeature gml:id="mf1">
            <test:loc/>
        </test:PointFeature>
        <test:PointFeature gml:id="mf2">
            <test:loc/>
Tests run: 10, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 9.003 sec <<< FAILURE!
Running org.geoserver.test.XYGeomTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.231 sec
Running org.geoserver.test.SRSWfsTest
Feb 5, 2010 5:33:03 AM org.geoserver.test.SRSWfsTest testGetFeatureContent
INFO: WFS GetFeature&typename=ex:geomContainer response:
    timeStamp="2010-02-05T05:33:03.519-05:00"
    xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock24147data/featureTypes/ex_geomContainer/NestedGeometry.xsd&gt; http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd&quot;&gt;
        <ex:geomContainer gml:id="1">
            <ex:geom>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                <ex:nestedGeom gml:id="nested.2">
                    <ex:geom>
                        <gml:Point>
                            <gml:pos>42.58 31.29</gml:pos>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
        <ex:geomContainer gml:id="2">
            <ex:geom>
                <gml:Point>
                </gml:Point>
            </ex:geom>
            <ex:nestedFeature>
                <ex:nestedGeom gml:id="nested.1">
                    <ex:geom>
                        <gml:Polygon>
                            <gml:exterior>
                                <gml:LinearRing>
                                </gml:LinearRing>
                            </gml:exterior>
                        </gml:Polygon>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Feb 5, 2010 5:33:04 AM org.geoserver.test.SRSWfsTest testReproject
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326 response:
    timeStamp="2010-02-05T05:33:04.091-05:00"
            <ex:geom>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        <gml:Point>
                            <gml:pos>42.58000004047607 31.29</gml:pos>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
            <ex:geom>
                <gml:Point>
                </gml:Point>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        <gml:Polygon>
                            <gml:exterior>
                                <gml:LinearRing>
                                </gml:LinearRing>
                            </gml:exterior>
                        </gml:Polygon>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Feb 5, 2010 5:33:04 AM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<wfs:FeatureCollection numberOfFeatures="1"
    timeStamp="2010-02-05T05:33:04.126-05:00"
            <ex:geom>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        <gml:Point>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.588 sec
Results :
Failed tests:
  testGetFeatureContent(org.geoserver.test.FeatureChainingWfsTest)
  testFilteringXlinkHref(org.geoserver.test.FeatureChainingWfsTest)
Tests run: 24, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 8 minutes 15 seconds
[INFO] Finished at: Fri Feb 05 05:33:04 EST 2010
[INFO] Final Memory: 51M/144M
Failed to send e-mail to ang05a because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2372/changes&gt;
