See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2374/changes>
Changes:
[simboss] GEOS-3754
[...truncated 123 lines...]
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target>
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT.jar>
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.1-SNAPSHOT/config-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.1-SNAPSHOT/config-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/config/2.1-SNAPSHOT/config-2.1-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building GeoServer Maven Archetypes
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target>
[INFO] [site:attach-descriptor]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.1-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.1-SNAPSHOT/archetype-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/target/archetype-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/archetype/2.1-SNAPSHOT/archetype-2.1-SNAPSHOT-tests.jar
[INFO] Building GeoServer Web Plugin Archetype
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.1-SNAPSHOT/geoserver-archetype-webplugin-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.1-SNAPSHOT/geoserver-archetype-webplugin-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.1-SNAPSHOT/geoserver-archetype-webplugin-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer WFS Output Format Archetype
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target>
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.1-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.1-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.1-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.1-SNAPSHOT-sources.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target>
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/surefire-reports>
T E S T S
Running org.geoserver.platform.GeoServerExtensionsTest
Feb 5, 2010 9:36:44 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.201 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/platform/2.1-SNAPSHOT/platform-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/platform/2.1-SNAPSHOT/platform-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/platform/2.1-SNAPSHOT/platform-2.1-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target>
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:ogc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:ogc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:xsd:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:xsd:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:extension:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:extension:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-coverage:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-coverage:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-graph:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-graph:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 79 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes>
[INFO] Compiling 16 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports>
T E S T S
Running org.geoserver.ows.DispatcherTest
Feb 5, 2010 9:36:52 AM org.geoserver.platform.GeoServerExtensions checkContext
log4j:WARN No appenders could be found for logger (org.springframework.context.support.FileSystemXmlApplicationContext).
log4j:WARN Please initialize the log4j system properly.
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.734 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.555 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec <<< FAILURE!
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.077 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Results :
Failed tests:
testInterval(org.geoserver.ows.kvp.TimeKvpParserTest)
Tests run: 24, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports> for the individual test results.
[INFO] Total time: 25 seconds
[INFO] Finished at: Fri Feb 05 09:36:54 EST 2010
[INFO] Final Memory: 32M/117M
