[Geoserver-devel] Build failed in Hudson: geoserver-trunk #241
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/241/changes
Changes:
[dwinslow] Moved datastore configuration to {datastore}/config; created index page to take its place.
[...truncated 1388 lines...]
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.7.0-SNAPSHOT/wfs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.7.0-SNAPSHOT/wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Versioning Web Feature Service Model
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 28 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfsv/1.7.0-SNAPSHOT/net.opengis.wfsv-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfsv/1.7.0-SNAPSHOT/net.opengis.wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target
[INFO] snapshot org.geotools:gt2-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 43 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/classes
[INFO] Nothing to compile - all classes are up to date
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target
[INFO] snapshot org.geotools:gt2-shapefile-renderer:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 128 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/classes
[INFO] Compiling 17 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.565 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.936 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.648 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.9 sec
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.276 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.336 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.288 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.548 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
org.vfny.geoserver.wms.WmsException: No such style: ThisStyleDoesNotExists
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.136 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<table border='1'>
<tr>
  <th colspan='4' scope='col'>testType</th>
</tr>
<tr>
  <td>string</td>
  <td>int</td>
  <td>double</td>
  <td>geom</td>
</tr>
<tr>
  <td>
three
  </td>
  <td>
3
  </td>
  <td>
3.3
  </td>
  <td>
[GEOMETRY]
  </td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.252 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.132 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.492 sec
Results :
Tests run: 48, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.0-SNAPSHOT/wms-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.0-SNAPSHOT/wms-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Application Module
[INFO] artifact org.geoserver.maven:config: checking for updates from mortbay-repo
[INFO] artifact org.geoserver.maven:config: checking for updates from central
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from mortbay-repo
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] Compiling 108 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/classes
[INFO] Compiling 4 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.16 sec
Running org.vfny.geoserver.jetty.SpringContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.276 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.236 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT-tests.jar
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
     [copy] Copying 14 files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
     [copy] Copied 12 empty directories to 9 empty directories under http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.0-SNAPSHOT/web-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.0-SNAPSHOT/web-1.7.0-SNAPSHOT-tests.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web] in [http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[724 msecs]
[INFO] Building war: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver.war
[INFO] Building Test Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/surefire-reports
Failed to load Main-Class manifest attribute from
/tmp/surefirebooter41477.jar
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 41 seconds
[INFO] Finished at: Tue Feb 05 17:34:41 EST 2008
[INFO] Final Memory: 31M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/242/changes
[...truncated 4 lines...]
          community/community-schemas/web-c/minimal
At revision 8352
Fetching external item into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/img
External at revision -1
At revision 6002
Fetching external item into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/lib
At revision 6002
Fetching external item into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
          web/minimal
At revision 8352
At revision 8352
no change for https://svn.codehaus.org/geoserver/trunk/geoserver since the previous build
no change for http://svn.codehaus.org/geoserver/trunk/configuration/minimal since the previous build
no change for http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/img since the previous build
no change for http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/lib since the previous build
[geoserver] $ /opt/maven2/bin/mvn -U clean install -Djava.awt.headless=true
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Plugins configuration files
[INFO] Configuration Deployment PlugIn
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Open Web Service Model
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Open Web Service Model v1.1.0
[INFO] Web Coverage Service Model v1.1.1
[INFO] Web Coverage Service 1.1.1 Module
[INFO] Validation Module
[INFO] Web Feature Service Model
[INFO] Web Feature Service Module
[INFO] Versioning Web Feature Service Model
[INFO] Versioned Web Feature Service Module
[INFO] Web Map Service Module
[INFO] Web Application Module
[INFO] Test Module
[INFO] Building GeoServer
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from central
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from central
[INFO] [site:attach-descriptor]
[INFO] snapshot org.geotools:gt2-api:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-library:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-modules:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-referencing:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-metadata:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.opengis:geoapi:2.2-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.opengis:parent:2.2-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-main:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.0-SNAPSHOT/geoserver-1.7.0-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.0-SNAPSHOT/geoserver-1.7.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.0-SNAPSHOT/maven-1.7.0-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.0-SNAPSHOT/maven-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Plugins configuration files
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from central
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT-tests.jar
[INFO] [plugin:updateRegistry]
[INFO] Building Core Platform Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target
[INFO] Compiling 9 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/surefire-reports
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Data Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target
[INFO] snapshot org.geotools:gt2-coverage:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-unsupported:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-data:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-jdbc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.h2database:h2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.openplans:spatialdbbox:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo-property:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-repository:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-plugin:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wms:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-xsd:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-extension:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-filter:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-graph:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-gml2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-gml3:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-ows:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-render:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 17 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/classes
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingFeatureSource.java :[27,7] org.geoserver.feature.retype.RetypingFeatureSource is not abstract and does not override abstract method getInfo() in org.geotools.data.FeatureSource
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingFeatureStore.java :[25,7] org.geoserver.feature.retype.RetypingFeatureStore is not abstract and does not override abstract method getInfo() in org.geotools.data.FeatureSource
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingDataStore.java :[33,7] org.geoserver.feature.retype.RetypingDataStore is not abstract and does not override abstract method getInfo() in org.geotools.data.DataStore
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingFeatureLocking.java :[18,0] org.geoserver.feature.retype.RetypingFeatureLocking is not abstract and does not override abstract method getInfo() in org.geotools.data.FeatureSource
[INFO] Total time: 21 seconds
[INFO] Finished at: Tue Feb 05 20:13:16 EST 2008
[INFO] Final Memory: 22M/39M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/243/changes
