[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2431
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2431/&gt;
[...truncated 24478 lines...]
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/surefire-reports&gt;
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/gwc/target/web-gwc-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.1-SNAPSHOT/web-gwc-2.1-SNAPSHOT-sources.jar
[INFO] Building WFS UI Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target&gt;
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/classes&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.web.WFSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.001 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wfs/target/web-wfs-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.1-SNAPSHOT/web-wfs-2.1-SNAPSHOT-sources.jar
[INFO] Building WCS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target&gt;
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/classes&gt;
[INFO] snapshot org.geoserver:wcs1_1:2.1-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_1:2.1-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wcs.web.data.WCSLayerConfigTest
Feb 26, 2010 5:27:48 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Feb 26, 2010 5:27:49 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Feb 26, 2010 5:27:50 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/./target/mock40994data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.935 sec
Running org.geoserver.wcs.web.WCSAdminPageTest
Feb 26, 2010 5:27:54 PM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/./target/mock40996data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.077 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wcs/target/web-wcs-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.1-SNAPSHOT/web-wcs-2.1-SNAPSHOT-sources.jar
[INFO] Building Demoes Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target&gt;
[INFO] snapshot org.geotools:gt-sample-data:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sample-data:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/classes&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.demo.MapPreviewPageTest
Feb 26, 2010 5:28:04 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.553 sec
Running org.geoserver.web.demo.DemoRequestsPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.623 sec
Running org.geoserver.web.demo.SRSListPageTest
Feb 26, 2010 5:28:11 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.059 sec
Results :
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target&gt;
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/classes&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.security.user.NewUserPageTest
Feb 26, 2010 5:28:22 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 12.114 sec <<< FAILURE!
Running org.geoserver.web.security.user.UserListPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.678 sec
Running org.geoserver.web.security.data.DataAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.355 sec
Running org.geoserver.web.security.data.NewRulePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.608 sec
Running org.geoserver.web.security.ConfirmRemovalUserPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.433 sec
Running org.geoserver.web.security.user.EditUserPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.656 sec
Running org.geoserver.web.security.ConfirmRemovalServicePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.305 sec
Running org.geoserver.web.security.ConfirmRemovalDataAccessRulePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.29 sec
Running org.geoserver.web.security.service.ServiceAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.909 sec
Running org.geoserver.web.security.catalog.CatalogModePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.148 sec
Results :
Tests in error:
  testFill(org.geoserver.web.security.user.NewUserPageTest)
Tests run: 18, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 6 minutes 54 seconds
[INFO] Finished at: Fri Feb 26 17:28:40 EST 2010
[INFO] Final Memory: 47M/119M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2432/changes&gt;
Changes:
[groldan] GEOS-3832, style preview in wms layer config
[groldan] sensible title to the wms settings section
[...truncated 24234 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.387 sec
Running org.geoserver.rest.format.ReflectiveHTMLFormatTest
<html>
  <body>
  This is a generic template for Foo.
  <br>
  Properties:
  <ul>
    <li>prop3: 3.0
    <li>prop1: one
    <li>prop2: 2
  </ul>
  </body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.249 sec
Running org.geoserver.rest.MapResourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Running org.geoserver.rest.IndexRestletTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.528 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/rest/2.1-SNAPSHOT/rest-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/rest/2.1-SNAPSHOT/rest-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/rest/2.1-SNAPSHOT/rest-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Web Modules
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target&gt;
[INFO] [site:attach-descriptor]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/web/2.1-SNAPSHOT/web-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/2.1-SNAPSHOT/web-2.1-SNAPSHOT-tests.jar
[INFO] Building Core UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 135 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/classes&gt;
[INFO] Compiling 45 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.admin.ContactPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.422 sec
Running org.geoserver.web.data.store.StorePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.092 sec
Running org.geoserver.web.data.store.CoverageStoreEditPageTest
Feb 26, 2010 5:43:55 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.281 sec
Running org.geoserver.web.wicket.KeywordsEditorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.085 sec
Running org.geoserver.web.data.workspace.WorkspacePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.496 sec
Running org.geoserver.web.wicket.CRSPanelTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.229 sec
Running org.geoserver.web.data.layergroup.LayerGroupEditPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.822 sec
Running org.geoserver.web.admin.StatusPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.679 sec
Running org.geoserver.web.data.table.NewLayerProviderTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.982 sec
Running org.geoserver.web.wicket.GeoServerPagingNavigatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.193 sec
Running org.geoserver.web.data.workspace.WorkspaceEditPageTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.861 sec
Running org.geoserver.web.data.workspace.WorkspaceNewPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.478 sec
Running org.geoserver.web.data.layergroup.LayerGroupNewPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.83 sec
Running org.geoserver.web.wicket.browser.FileBreadcrumsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Running org.geoserver.web.GeoServerHomePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.302 sec
Running org.geoserver.web.admin.GlobalSettingsPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.243 sec
Running org.geoserver.web.GeoServerSecuredPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.707 sec
Running org.geoserver.web.data.layergroup.LayerGroupPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.226 sec
Running org.geoserver.web.admin.JAIPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.253 sec
Running org.geoserver.web.data.store.NewDataPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.794 sec
Running org.geoserver.web.wicket.EnvelopePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.142 sec
Running org.geoserver.web.publish.HTTPLayerConfigTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.475 sec
Running org.geoserver.web.ConverterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.166 sec
Running org.geoserver.web.data.ConfirmRemovalPanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.498 sec
Running org.geoserver.web.data.store.CoverageStoreNewPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.857 sec
Running org.geoserver.web.data.layer.NewLayerPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.377 sec
Running org.geoserver.web.wicket.browser.GeoServerFileChooserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.72 sec
Running org.geoserver.web.data.store.DataAccessEditPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.548 sec
Running org.geoserver.web.data.resource.ResourceConfigurationPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.564 sec
Running org.geoserver.web.wicket.FileExistsValidatorTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.161 sec
Running org.geoserver.web.wicket.GeoServerTablePanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.125 sec
Running org.geoserver.web.wicket.SRSPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.494 sec
Running org.geoserver.web.wicket.WKTToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.029 sec
Running org.geoserver.web.wicket.browser.FileDataViewTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.449 sec
Running org.geoserver.web.wicket.SRSToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.web.GeoServerBasePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.381 sec
Running org.geoserver.web.data.resource.ResourceNameValidatorTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.web.data.store.DataAccessNewPageTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.433 sec
Results :
Tests run: 100, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.1-SNAPSHOT/web-core-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.1-SNAPSHOT/web-core-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.1-SNAPSHOT/web-core-2.1-SNAPSHOT-sources.jar
[INFO] Building WMS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target&gt;
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/classes&gt;
[INFO] snapshot org.geoserver.web:web-core:2.1-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-core:2.1-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 6 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wms.web.data.WMSAdminPageTest
Feb 26, 2010 5:44:30 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.586 sec
Running org.geoserver.wms.web.publish.AttributionLayerConfigTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.588 sec
Running org.geoserver.wms.web.data.StylePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.812 sec
Running org.geoserver.wms.web.data.publish.WMSLayerConfigTest
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.33 sec <<< FAILURE!
Running org.geoserver.wms.web.data.StyleEditPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.694 sec
Running org.geoserver.wms.web.data.StyleNewPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.631 sec
Results :
Tests in error:
  testNew(org.geoserver.wms.web.data.publish.WMSLayerConfigTest)
Tests run: 13, Failures: 0, Errors: 1, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 5 minutes 7 seconds
[INFO] Finished at: Fri Feb 26 17:44:45 EST 2010
[INFO] Final Memory: 45M/114M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2433/changes&gt;
