See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/249/changes
Changes:
[aaime] Added xmlunit dependency, upgraded junit to 3.8.2 to avoid conflicts (xmlunit wants 3.8.2)
[aaime] Added another exception cause
[aaime] Added a "sections" kvp parser to avoid class cast exceptions in kvp parsing
[...truncated 1315 lines...]
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
... 36 more
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.664 sec
Running org.geoserver.wcs.GetCoverageEncodingTest
06 Feb 11:33:13 ERROR [geoserver.ows] -
org.vfny.geoserver.wcs.WcsException: CRS urn:ogc:def:crs:EPSG:4326 is not among the supported ones for coverage wcs:BlueMarble
at org.geoserver.wcs.DefaultWebCoverageService111.checkOutput(DefaultWebCoverageService111.java:375)
at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:125)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
at $Proxy6.getCoverage(Unknown Source)
at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:599)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:277)
at org.geoserver.wcs.GetCoverageEncodingTest.testKvpBasic(GetCoverageEncodingTest.java:42)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
at org.geoserver.wcs.GetCoverageEncodingTest.testTiffOutput(GetCoverageEncodingTest.java:110)
at org.geoserver.wcs.GetCoverageEncodingTest.testPngOutput(GetCoverageEncodingTest.java:132)
at org.geoserver.wcs.GetCoverageEncodingTest.testGeotiffNamesGalore(GetCoverageEncodingTest.java:154)
Tests run: 4, Failures: 2, Errors: 2, Skipped: 0, Time elapsed: 0.38 sec <<< FAILURE!
Results :
Failed tests:
testDescribeDemCoverageKvp(org.geoserver.wcs.DescribeCoverageTest)
testDescribeDemCoverageXml(org.geoserver.wcs.DescribeCoverageTest)
testDescribeRotatedCoverage(org.geoserver.wcs.DescribeCoverageTest)
testDescribeImageCoverage(org.geoserver.wcs.DescribeCoverageTest)
testWrongGridOffsets(org.geoserver.wcs.GetCoverageTest)
testKvpBasic(org.geoserver.wcs.GetCoverageEncodingTest)
testGeotiffNamesGalore(org.geoserver.wcs.GetCoverageEncodingTest)
Tests in error:
testKvpBasic(org.geoserver.wcs.GetCoverageTest)
testNoGridOffsets(org.geoserver.wcs.GetCoverageTest)
testGridOffsetsSubsample(org.geoserver.wcs.GetCoverageTest)
testNullGridOrigin(org.geoserver.wcs.GetCoverageTest)
testTiffOutput(org.geoserver.wcs.GetCoverageEncodingTest)
testPngOutput(org.geoserver.wcs.GetCoverageEncodingTest)
Tests run: 69, Failures: 7, Errors: 6, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 9 seconds
[INFO] Finished at: Wed Feb 06 11:33:14 EST 2008
[INFO] Final Memory: 32M/63M
