See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2536/>
[...truncated 28727 lines...]
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1079)
at org.geoserver.test.GeoServerAbstractTestSupport.assertStatusCodeForRequest(GeoServerAbstractTestSupport.java:1144)
at org.geoserver.test.GeoServerAbstractTestSupport.assertStatusCodeForGet(GeoServerAbstractTestSupport.java:1097)
at org.geoserver.geosearch.SiteMapIndexRestletTest.assertProtectedEndpoint(SiteMapIndexRestletTest.java:34)
at org.geoserver.geosearch.SiteMapIndexRestletTest.testLayerHTML(SiteMapIndexRestletTest.java:104)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:128)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Mar 31, 2010 12:57:37 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.9 sec
Running org.geoserver.geosearch.FeatureRestletTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.427 sec
Running org.geoserver.geosearch.LayerAboutPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.266 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/geosearch/2.1-SNAPSHOT/geosearch-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/geosearch/2.1-SNAPSHOT/geosearch-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/geosearch-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/geosearch/2.1-SNAPSHOT/geosearch-2.1-SNAPSHOT-sources.jar
[INFO] Building H2 DataStore Extension
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target>
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-h2:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/classes>
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/test-classes>
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/surefire-reports>
T E S T S
Running org.geoserver.h2.H2DataStoreInitializerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.581 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.1-SNAPSHOT/h2-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.1-SNAPSHOT/h2-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/h2-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/h2/2.1-SNAPSHOT/h2-2.1-SNAPSHOT-sources.jar
[INFO] Building SQL Server DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/sqlserver/target>
[INFO] snapshot org.geotools.jdbc:gt-jdbc-sqlserver:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-sqlserver:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/2.1-SNAPSHOT/sqlserver-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/2.1-SNAPSHOT/sqlserver-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/sqlserver/target/sqlserver-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/sqlserver/2.1-SNAPSHOT/sqlserver-2.1-SNAPSHOT-sources.jar
[INFO] Building Oracle DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target>
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-oracle:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.1-SNAPSHOT/oracle-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.1-SNAPSHOT/oracle-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.1-SNAPSHOT/oracle-2.1-SNAPSHOT-sources.jar
[INFO] Building MySQL DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target>
[INFO] snapshot org.geotools.jdbc:gt-jdbc-mysql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-mysql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/mysql/2.1-SNAPSHOT/mysql-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/mysql/2.1-SNAPSHOT/mysql-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/mysql/2.1-SNAPSHOT/mysql-2.1-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target>
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-postgis-versioned:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-postgis-versioned:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-postgis:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-postgis:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 54 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureLocking.java>:\[29,7\] org.vfny.geoserver.global.GeoServerVersioningFeatureLocking is not abstract and does not override abstract method getVersion() in org.geotools.data.VersioningFeatureStore
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/java/org/geoserver/wfsv/security/ReadOnlyVersioningFeatureStore.java>:\[26,7\] org.geoserver.wfsv.security.ReadOnlyVersioningFeatureStore is not abstract and does not override abstract method getVersion() in org.geotools.data.VersioningFeatureStore
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/java/org/geoserver/wfsv/security/ReadOnlyVersioningFeatureLocking.java>:\[26,7\] org.geoserver.wfsv.security.ReadOnlyVersioningFeatureLocking is not abstract and does not override abstract method getVersion() in org.geotools.data.VersioningFeatureStore
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/java/org/vfny/geoserver/global/GeoServerVersioningFeatureStore.java>:\[21,7\] org.vfny.geoserver.global.GeoServerVersioningFeatureStore is not abstract and does not override abstract method getVersion() in org.geotools.data.VersioningFeatureStore
[INFO] Total time: 8 minutes 54 seconds
[INFO] Finished at: Wed Mar 31 12:57:50 EDT 2010
[INFO] Final Memory: 54M/145M
