See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/257/changes
Changes:
[jdeolive] handling requests with spring dispatcher instead of assuming ows dispatcher
[...truncated 809 lines...]
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
at $Proxy6.getCapabilities(Unknown Source)
at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:712)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:394)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:518)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:501)
at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionPost(GetCapabilitiesTest.java:78)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
08 Feb 17:32:41 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find any matching version
at org.geoserver.ows.util.RequestUtils.getVersionOws11(RequestUtils.java:220)
at org.geoserver.wcs.DefaultWebCoverageService111.getCapabilities(DefaultWebCoverageService111.java:92)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:288)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:269)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:451)
at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionGet(GetCapabilitiesTest.java:87)
08 Feb 17:32:43 ERROR [geoserver.ows] -
java.io.IOException
at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:71)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:615)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorGet(GetCapabilitiesTest.java:160)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:132)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:107)
at org.geoserver.wcs.response.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:69)
... 41 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
at org.geoserver.wcs.response.WCSCapsTransformer$WCS111CapsTranslator.encode(WCSCapsTransformer.java:119)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
... 43 more
java.io.IOException
at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:173)
... 41 more
... 43 more
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.876 sec
Running org.geoserver.wcs.GetCoverageEncodingTest
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.336 sec <<< FAILURE!
Results :
Tests in error:
testKvpBasic(org.geoserver.wcs.GetCoverageEncodingTest)
testTiffOutput(org.geoserver.wcs.GetCoverageEncodingTest)
testPngOutput(org.geoserver.wcs.GetCoverageEncodingTest)
testGeotiffNamesGalore(org.geoserver.wcs.GetCoverageEncodingTest)
Tests run: 69, Failures: 0, Errors: 4, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 17 seconds
[INFO] Finished at: Fri Feb 08 17:32:44 EST 2008
[INFO] Final Memory: 31M/63M
