See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2621/>
[...truncated 24071 lines...]
AUTHORITY["EPSG","4326"]]-->
<LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
<BoundingBox SRS="EPSG:4326" maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
<Style>
<Name>RoadSegments</Name>
<Title>Default Styler</Title>
<Abstract/>
<LegendURL height="20" width="20">
<Format>image/png</Format>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&height=20&layer=RoadSegments" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
<Layer queryable="1">
<Name>cdf:Seven</Name>
<Title>Seven</Title>
<Abstract>abstract about Seven</Abstract>
<KeywordList>
<Keyword>Seven</Keyword>
</KeywordList>
<SRS>EPSG:32615</SRS>
<!--WKT definition of this CRS:
PROJCS["WGS 84 / UTM zone 15N",
GEOGCS["WGS 84",
DATUM["World Geodetic System 1984",
SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree", 0.017453292519943295],
AXIS["Geodetic longitude", EAST],
AXIS["Geodetic latitude", NORTH],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]],
PARAMETER["central_meridian", -93.0],
PARAMETER["latitude_of_origin", 0.0],
PARAMETER["scale_factor", 0.9996],
PARAMETER["false_easting", 500000.0],
PARAMETER["false_northing", 0.0],
UNIT["m", 1.0],
AXIS["Easting", EAST],
AXIS["Northing", NORTH],
AUTHORITY["EPSG","32615"]]-->
<Style>
<Name>Default</Name>
<Abstract/>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&height=20&layer=Seven" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
<Name>cite:Streams</Name>
<Title>Streams</Title>
<Abstract>abstract about Streams</Abstract>
<KeywordList>
<Keyword>Streams</Keyword>
</KeywordList>
<SRS>EPSG:4326</SRS>
GEOGCS["WGS 84",
<Style>
<Name>Streams</Name>
<Abstract/>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&height=20&layer=Streams" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
<Name>cdf:Updates</Name>
<Title>Updates</Title>
<Abstract>abstract about Updates</Abstract>
<KeywordList>
<Keyword>Updates</Keyword>
</KeywordList>
GEOGCS["WGS 84",
UNIT["m", 1.0],
<Style>
<Abstract/>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&format=image%2Fpng&width=20&height=20&layer=Updates" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.38 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.237 sec
Results :
Tests run: 177, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target>
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/classes>
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/test-classes>
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/surefire-reports>
T E S T S
Running org.geoserver.gwc.GWCCatalogListenerTest
Apr 20, 2010 2:27:31 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
20 Apr 02:27:33 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
20 Apr 02:27:33 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources> contained no layers.
20 Apr 02:27:33 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources>: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources/geowebcache\.xml>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.692 sec
Running org.geoserver.gwc.GWCIntegrationTest
20 Apr 02:27:35 ERROR [geowebcache.GeoWebCacheDispatcher] - null http://localhost/geoserver/gwc/service/wmts?request=GetTile&layer=cite:BasicPolygons&format=image/png&tilematrixset=EPSG:4326&tilematrix=EPSG:4326:0&tilerow=0&tilecol=0
java.lang.NullPointerException
at org.geowebcache.layer.TileLayerDispatcher.getTileLayer(TileLayerDispatcher.java:69)
at org.geowebcache.service.wmts.WMTSService.getTile(WMTSService.java:108)
at org.geowebcache.service.wmts.WMTSService.getConveyor(WMTSService.java:79)
at org.geowebcache.GeoWebCacheDispatcher.handleServiceRequest(GeoWebCacheDispatcher.java:333)
at org.geowebcache.GeoWebCacheDispatcher.handleRequestInternal(GeoWebCacheDispatcher.java:252)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1091)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1058)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:465)
at org.geoserver.gwc.GWCIntegrationTest.testPngIntegration(GWCIntegrationTest.java:12)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:128)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
20 Apr 02:27:37 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
20 Apr 02:27:37 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources> contained no layers.
20 Apr 02:27:37 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources>: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources/geowebcache\.xml>
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 3.077 sec <<< FAILURE!
Results :
Failed tests:
testPngIntegration(org.geoserver.gwc.GWCIntegrationTest)
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/surefire-reports> for the individual test results.
[INFO] Total time: 4 minutes 23 seconds
[INFO] Finished at: Tue Apr 20 02:27:38 EDT 2010
[INFO] Final Memory: 44M/116M
