See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2644/changes>
Changes:
[ang05a] Support for referential polymorphism
[riniangreani] Support for referential polymorphism
[...truncated 23872 lines...]
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-04-28T07:24:09.898-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="http://www.cgi-iugs.org/xml/GeoSciML/2" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0" xmlns:ows="http://www.opengis.net/ows"
xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:wfs="http://www.opengis.net/wfs"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd http://www.cgi-iugs.org/xml/GeoSciML/2 http://schemas.opengis.net/GeoSciML/geosciml.xsd">
<gml:featureMembers>
<gsml:MappedFeature gml:id="mf1">
<gml:name>GUNTHORPE FORMATION</gml:name>
<gsml:positionalAccuracy>
<gsml:CGI_NumericValue>
<gsml:principalValue uom="urn:ogc:def:uom:UCUM:m">200.0</gsml:principalValue>
</gsml:CGI_NumericValue>
</gsml:positionalAccuracy>
<gsml:observationMethod>
<gsml:CGI_TermValue>
<gsml:value codeSpace="http://urn.opengis.net">urn:ogc:def:nil:OGC::missing</gsml:value>
</gsml:CGI_TermValue>
</gsml:observationMethod>
<gsml:shape>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
<gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</gsml:shape>
<gsml:specification>
<gsml:GeologicUnit gml:id="gu.25699">
<gml:description>Olivine basalt, tuff, microgabbro, minor sedimentary rocks</gml:description>
<gml:name codeSpace="urn:ietf:rfc:2141">Yaugher Volcanic Group</gml:name>
<gml:name>-Py</gml:name>
<gsml:occurence xlink:href="urn:cgi:feature:MappedFeature:mf1"/>
<gsml:exposureColor>
<gsml:value codeSpace="some:uri">Blue</gsml:value>
</gsml:exposureColor>
<gsml:outcropCharacter>
<gsml:value codeSpace="some:uri">x</gsml:value>
</gsml:outcropCharacter>
<gsml:composition>
<gsml:CompositionPart>
<gsml:proportion>
<gsml:value codeSpace="some:uri">significant</gsml:value>
</gsml:proportion>
<gsml:role>interbedded component</gsml:role>
</gsml:CompositionPart>
</gsml:composition>
</gsml:GeologicUnit>
</gsml:specification>
</gsml:MappedFeature>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.41 sec
Running org.geoserver.test.XYGeomTest
Apr 28, 2010 7:24:10 AM org.geoserver.test.XYGeomTest testDescribeFeatureType
INFO: WFS DescribeFeatureType response:
<xsd:schema elementFormDefault="qualified" targetNamespace="http://test" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="http://www.cgi-iugs.org/xml/GeoSciML/2" xmlns:om="http://www.opengis.net/om/1.0" xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1"
xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:test="http://test" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:include schemaLocation="<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock47345data/featureTypes/test_PointFeature/GeometrylessTest.xsd"/>>
</xsd:schema>
Apr 28, 2010 7:24:10 AM org.geoserver.test.XYGeomTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-04-28T07:24:10.297-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:gml="http://www.opengis.net/gml"
xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:test="http://test"
xmlns:wfs="http://www.opengis.net/wfs" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://test <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock47345data/featureTypes/test_PointFeature/GeometrylessTest.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<test:PointFeature gml:id="mf1">
<test:loc/>
</test:PointFeature>
<test:PointFeature gml:id="mf2">
<test:loc/>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.371 sec
Running org.geoserver.test.SRSWfsTest
Apr 28, 2010 7:24:11 AM org.geoserver.test.SRSWfsTest testGetFeatureContent
INFO: WFS GetFeature&typename=ex:geomContainer response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-04-28T07:24:11.024-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock47347data/featureTypes/ex_geomContainer/NestedGeometry.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<ex:geomContainer gml:id="1">
<ex:geom>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.2">
<ex:geom>
<gml:Point>
<gml:pos>42.58 31.29</gml:pos>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
<ex:geomContainer gml:id="2">
<ex:geom>
<gml:Point>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.1">
<ex:geom>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
Apr 28, 2010 7:24:11 AM org.geoserver.test.SRSWfsTest testReproject
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326 response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-04-28T07:24:11.510-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
<ex:geom>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
<gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
<gml:Point>
<gml:pos>42.58000004047607 31.29</gml:pos>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
<ex:geom>
<gml:Point>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.282 sec
Results :
Failed tests:
testPolymorphism(org.geoserver.test.PolymorphismWfsTest)
testFirstValueFilters(org.geoserver.test.PolymorphismWfsTest)
testSecondValueFilters(org.geoserver.test.PolymorphismWfsTest)
testAnyTypeFilters(org.geoserver.test.PolymorphismWfsTest)
testMappingNameFilters(org.geoserver.test.PolymorphismWfsTest)
Tests run: 31, Failures: 5, Errors: 0, Skipped: 0
Apr 28, 2010 7:24:11 AM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-04-28T07:24:11.583-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
<ex:geom>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
<gml:Point>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 8 minutes 38 seconds
[INFO] Finished at: Wed Apr 28 07:24:12 EDT 2010
[INFO] Final Memory: 51M/137M
Failed to send e-mail to ang05a because no e-mail address is known, and no default e-mail domain is configured
Failed to send e-mail to riniangreani because no e-mail address is known, and no default e-mail domain is configured
