[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2677
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2677/&gt;
[...truncated 20040 lines...]
org.geotools.referencing.operation.projection.ProjectionException: The transform result may be 200,566.547 meters away from the expected position. Are you sure that the input coordinates are inside this map projection area of validity? The point is located 53°23.4'W away from the central meridian and 21687°36.2'S away from the latitude of origin. The projection is "Transverse_Mercator".
  at org.geotools.referencing.operation.projection.MapProjection.checkReciprocal(MapProjection.java:677)
  at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:869)
  at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:904)
  at org.geotools.referencing.operation.transform.AbstractMathTransform.transform(AbstractMathTransform.java:235)
  at org.geotools.referencing.CRS.transform(CRS.java:1178)
  at org.geotools.referencing.CRS.transform(CRS.java:1244)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:630)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:585)
  at org.geoserver.wms.DefaultWebMapService.autoSetBoundsAndSize(DefaultWebMapService.java:463)
  at org.geoserver.web.demo.PreviewLayer.getRequest(PreviewLayer.java:134)
  at org.geoserver.web.demo.PreviewLayer.getWmsLink(PreviewLayer.java:172)
  at org.geoserver.web.demo.MapPreviewPage$1.getComponentForProperty(MapPreviewPage.java:76)
  at org.geoserver.web.wicket.GeoServerTablePanel$1$1.populateItem(GeoServerTablePanel.java:136)
  at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:573)
  at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:127)
  at org.apache.wicket.Component.internalBeforeRender(Component.java:1009)
  at org.apache.wicket.Component.beforeRender(Component.java:1041)
  at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590)
  at org.apache.wicket.Component.onBeforeRender(Component.java:3727)
  at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:147)
  at org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:109)
  at org.apache.wicket.Page.onBeforeRender(Page.java:1458)
  at org.apache.wicket.Component.prepareForRender(Component.java:2167)
  at org.apache.wicket.Page.renderPage(Page.java:892)
  at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:240)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:104)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1245)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1316)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:578)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:469)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:378)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:289)
  at org.geoserver.web.demo.MapPreviewPageTest.testValues(MapPreviewPageTest.java:7)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:126)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.479 sec
Running org.geoserver.web.demo.DemoRequestsPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.247 sec
Running org.geoserver.web.demo.SRSListPageTest
May 5, 2010 11:49:42 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.089 sec
Results :
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target&gt;
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.security.user.NewUserPageTest
May 5, 2010 11:49:53 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 8.121 sec <<< FAILURE!
Running org.geoserver.web.security.user.UserListPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.429 sec
Running org.geoserver.web.security.data.DataAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.423 sec
Running org.geoserver.web.security.data.NewRulePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.286 sec
Running org.geoserver.web.security.ConfirmRemovalUserPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.45 sec
Running org.geoserver.web.security.user.EditUserPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.371 sec
Running org.geoserver.web.security.ConfirmRemovalServicePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.299 sec
Running org.geoserver.web.security.ConfirmRemovalDataAccessRulePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.278 sec
Running org.geoserver.web.security.service.ServiceAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.207 sec
Running org.geoserver.web.security.catalog.CatalogModePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.871 sec
Results :
Tests in error:
  testFill(org.geoserver.web.security.user.NewUserPageTest)
Tests run: 18, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 7 minutes 18 seconds
[INFO] Finished at: Wed May 05 11:50:06 EDT 2010
[INFO] Final Memory: 47M/115M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2678/&gt;
