[Geoserver-devel] Build failed in Hudson: geoserver-trunk #272
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/272/changes
[...truncated 1471 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
14 Feb 04:12:59 ERROR [geoserver.ows] -
java.lang.NoClassDefFoundError: org/geotools/filter/text/cql2/CQL
  at org.geoserver.wfs.kvp.CQLFilterKvpParser.parse(CQLFilterKvpParser.java:26)
  at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:1009)
  at org.geoserver.ows.Dispatcher.init(Dispatcher.java:212)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:168)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:347)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:700)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:295)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:276)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:443)
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdate(TransactionTest.java:500)
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdateNoSRS(TransactionTest.java:462)
14 Feb 04:13:00 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: No such property: {http://www.opengis.net/wfs\}INVALID
  at org.geoserver.wfs.UpdateElementHandler.checkValidity(UpdateElementHandler.java:110)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:225)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:104)
  at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:157)
  at sun.reflect.GeneratedMethodAccessor95.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
  at $Proxy6.transaction(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor94.invoke(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:401)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:510)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:493)
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdateWithInvalidProperty(TransactionTest.java:532)
Tests run: 10, Failures: 3, Errors: 0, Skipped: 0, Time elapsed: 2.756 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.GetFeatureWithLockTest
14 Feb 04:13:00 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
14 Feb 04:13:00 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.344 sec
Running org.geoserver.wfs.xml.GML3FeatureProducerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.844 sec
Running org.geoserver.wfs.response.WfsXmlWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.116 sec
Running org.geoserver.wfs.TransactionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.872 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.496 sec
Running org.geoserver.wfs.v1_1.WFSReprojectionTest
14 Feb 04:13:05 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
14 Feb 04:13:05 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
14 Feb 04:13:06 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
14 Feb 04:13:06 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.529 sec
Running org.geoserver.wfs.ReprojectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.848 sec
Running org.geoserver.wfs.TransactionListenerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.636 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.804 sec
Running org.geoserver.wfs.DescribeFeatureTest
14 Feb 04:13:10 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:97)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:92)
  at $Proxy6.describeFeatureType(Unknown Source)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:29)
  at sun.reflect.GeneratedMethodAccessor93.invoke(Unknown Source)
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.772 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.648 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.312 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.452 sec
Results :
Failed tests:
  testInsert2(org.geoserver.wfs.v1_1.TransactionTest)
  testUpdateForcedSRS(org.geoserver.wfs.v1_1.TransactionTest)
  testUpdateNoSRS(org.geoserver.wfs.v1_1.TransactionTest)
Tests run: 135, Failures: 3, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 11 seconds
[INFO] Finished at: Thu Feb 14 04:13:17 EST 2008
[INFO] Final Memory: 32M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/273/changes
