See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2727/changes>
Changes:
[aaime] [GEOS-3965] KML Icon back references to the styles directory do not work properly when GeoServer is being proxied
[...truncated 1346 lines...]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
May 17, 2010 9:38:13 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock64982data>
May 17, 2010 9:38:13 AM org.geotools.referencing.operation.projection.TransverseMercator.Inverse transform
WARNING: Possible use of "Transverse_Mercator (Inverse transform)" projection outside its valid area.
Latitude 2541°05.9'N is out of range (±90°).
May 17, 2010 9:38:13 AM org.geoserver.test.RemoteOWSTestSupport isRemoteWMSStatesAvailable
WARNING: Skipping remote OWS test because they were not enabled via -DremoteOwsTests=true
May 17, 2010 9:38:13 AM org.geoserver.catalog.impl.CatalogBuilderTest testWMS
WARNING: Remote OWS tests disabled, skipping catalog builder wms tests
May 17, 2010 9:38:13 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6a77'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6a78'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6a75'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6a76'
May 17, 2010 9:38:13 AM org.geoserver.catalog.ResourcePool$CoverageReaderCache dispose
INFO: Disposing grid coverage reader 'DEM'
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.66 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.security.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.vfny.geoserver.ProjectionPolicyTest
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock64984data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6a22'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6a21'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock64986data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6a0d'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6a0c'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock64988data>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.279 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-69f7'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-69f8'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock64990data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-69d3'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-69d5'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-69d6'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-69d4'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock64993data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-697c'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-697d'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-697e'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-697b'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock64995data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6923'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6924'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6926'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6925'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.316 sec
Running org.geoserver.ows.URLManglersTest
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock64997data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-68cb'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-68cc'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-68cd'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-68ce'
May 17, 2010 9:38:14 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock64999data>
May 17, 2010 9:38:14 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6873'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6874'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6875'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6876'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock65001data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-681b'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-681c'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-681d'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-681e'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.322 sec
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 55, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.048 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock65003data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6772'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6773'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6774'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6771'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock65005data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6719'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-671a'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-671b'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6718'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock65007data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-66c0'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-66c1'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-66c2'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-66bf'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock65009data>
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6667'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6668'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6669'
INFO: Disposing datastore 'DataStoreInfoImpl-7d806c6b:128a67c2950:-6666'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.523 sec
Results :
Tests run: 253, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.1-SNAPSHOT-sources.jar>
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/main/2.1-SNAPSHOT/main-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/main/2.1-SNAPSHOT/main-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/main/2.1-SNAPSHOT/main-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target>
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs/src/main/java/org/vfny/geoserver/util/WCSUtils.java>:\[61,43\] cannot find symbol
symbol : constructor DefaultProcessor(org.geotools.factory.Hints)
location: class org.geotools.coverage.processing.DefaultProcessor
[INFO] Total time: 1 minute 30 seconds
[INFO] Finished at: Mon May 17 09:38:18 EDT 2010
[INFO] Final Memory: 39M/116M
