[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2788
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2788/changes&gt;
Changes:
[riniangreani] Removing the static variable from PolymorphismWfsTest
[...truncated 20314 lines...]
  at org.geotools.referencing.operation.projection.MapProjection.checkReciprocal(MapProjection.java:677)
  at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:869)
  at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:904)
  at org.geotools.referencing.operation.transform.AbstractMathTransform.transform(AbstractMathTransform.java:235)
  at org.geotools.referencing.CRS.transform(CRS.java:1180)
  at org.geotools.referencing.CRS.transform(CRS.java:1246)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:630)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:585)
  at org.geoserver.wms.DefaultWebMapService.autoSetBoundsAndSize(DefaultWebMapService.java:463)
  at org.geoserver.web.demo.PreviewLayer.getRequest(PreviewLayer.java:134)
  at org.geoserver.web.demo.PreviewLayer.getWmsLink(PreviewLayer.java:172)
  at org.geoserver.web.demo.MapPreviewPage$1.getComponentForProperty(MapPreviewPage.java:76)
  at org.geoserver.web.wicket.GeoServerTablePanel$1$1.populateItem(GeoServerTablePanel.java:136)
  at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:573)
  at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:127)
  at org.apache.wicket.Component.internalBeforeRender(Component.java:1009)
  at org.apache.wicket.Component.beforeRender(Component.java:1041)
  at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590)
  at org.apache.wicket.Component.onBeforeRender(Component.java:3727)
  at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:147)
  at org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:109)
  at org.apache.wicket.Page.onBeforeRender(Page.java:1458)
  at org.apache.wicket.Component.prepareForRender(Component.java:2167)
  at org.apache.wicket.Page.renderPage(Page.java:892)
  at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:240)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:104)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1245)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1316)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:578)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:469)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:378)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:289)
  at org.geoserver.web.demo.MapPreviewPageTest.testValues(MapPreviewPageTest.java:7)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:126)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
org.geotools.referencing.operation.projection.ProjectionException: The transform result may be 200,566.547 meters away from the expected position. Are you sure that the input coordinates are inside this map projection area of validity? The point is located 53°23.4'W away from the central meridian and 21687°36.2'S away from the latitude of origin. The projection is "Transverse_Mercator".
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.325 sec
Running org.geoserver.web.demo.DemoRequestsPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.418 sec
Running org.geoserver.web.demo.SRSListPageTest
May 31, 2010 11:43:23 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.091 sec
Results :
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target&gt;
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.security.user.NewUserPageTest
May 31, 2010 11:43:34 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won't be enabled.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 12.338 sec <<< FAILURE!
Running org.geoserver.web.security.user.UserListPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.02 sec
Running org.geoserver.web.security.data.DataAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.517 sec
Running org.geoserver.web.security.data.NewRulePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.062 sec
Running org.geoserver.web.security.ConfirmRemovalUserPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.554 sec
Running org.geoserver.web.security.user.EditUserPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.649 sec
Running org.geoserver.web.security.ConfirmRemovalServicePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.321 sec
Running org.geoserver.web.security.ConfirmRemovalDataAccessRulePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.373 sec
Running org.geoserver.web.security.service.ServiceAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.896 sec
Running org.geoserver.web.security.catalog.CatalogModePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.058 sec
Results :
Tests in error:
  testFill(org.geoserver.web.security.user.NewUserPageTest)
Tests run: 18, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 7 minutes 6 seconds
[INFO] Finished at: Mon May 31 23:43:51 EDT 2010
[INFO] Final Memory: 47M/112M
Failed to send e-mail to riniangreani because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2789/changes&gt;
