[Geoserver-devel] Build failed in Hudson: geoserver-trunk #279
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/279/changes
Changes:
[aaime] GEOS-1936, EXCEPTIONS=application/Fvnd.ogc.se_inimage is not respected
[...truncated 2555 lines...]
Jun 13, 2008 8:39:34 AM org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest testSimpleGetMapQuery
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[-2.0 : 2.0, -1.0 : 6.0]
13 Jun 08:39:34 ERROR [geotools.rendering] -
java.lang.NullPointerException
  at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1536)
  at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:643)
  at org.geotools.renderer.shape.ShapefileRenderer.renderWithStreamingRenderer(ShapefileRenderer.java:1475)
  at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:1344)
  at org.geotools.renderer.shape.ShapefileRenderer.paint(ShapefileRenderer.java:266)
  at org.vfny.geoserver.wms.responses.DefaultRasterMapProducer.produceMap(DefaultRasterMapProducer.java:302)
  at org.vfny.geoserver.wms.responses.map.DefaultRasterMapProducerTest.testSimpleGetMapQuery(DefaultRasterMapProducerTest.java:119)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:120)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Jun 13, 2008 8:39:34 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testSimpleGetMapQuery: pixel count=90000 non bg pixels: 90000
INFO: testDefaultStyle Streams: pixel count=192000 non bg pixels: 3877
INFO: testDefaultStyle Bridges: pixel count=192000 non bg pixels: 289
INFO: testDefaultStyle BasicPolygons: pixel count=280000 non bg pixels: 101880
INFO: testDefaultStyle Forests: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle NamedPlaces: pixel count=280000 non bg pixels: 306
INFO: testDefaultStyle Buildings: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle RoadSegments: pixel count=280000 non bg pixels: 323
INFO: testDefaultStyle DividedRoutes: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle Lakes: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle MapNeatline: pixel count=280000 non bg pixels: 289
INFO: testDefaultStyle Ponds: pixel count=280000 non bg pixels: 289
Jun 13, 2008 8:39:35 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testBlueLake: pixel count=250000 non bg pixels: 250000
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.492 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<h4>testType</h4>
<ul class="textattributes">
  <li><strong><span class="atr-name">string</span>:</strong> <span class="atr-value">three</span></li>
  <li><strong><span class="atr-name">int</span>:</strong> <span class="atr-value">3</span></li>
  <li><strong><span class="atr-name">double</span>:</strong> <span class="atr-value">3.3</span></li>
</ul>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.268 sec
Running org.vfny.geoserver.wms.responses.map.kml.CachedHierarchyRegionatingStrategyTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.416 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.204 sec
Running org.vfny.geoserver.wms.responses.palette.CustomPaletteBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.04 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.388 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
<kml>
  <Document xmlns:atom="http://purl.org/atom/ns#&quot;&gt;
    <name>Points</name>
    <Style id="GeoServerStylePoints.0">
      <IconStyle>
        <Icon/>
      </IconStyle>
      <IconStyle>
        <colorMode>normal</colorMode>
        <Icon>
          <href>http://localhost:80/geoserver/styles/bridge.png&lt;/href&gt;
        </Icon>
      </IconStyle>
    </Style>
    <Placemark id="Points.0">
      <description><![CDATA[<h4>Points</h4>
  <li><strong><span class="atr-name">id</span>:</strong> <span class="atr-value">t0000</span></li>
</ul>
]]></description>
      <LookAt>
        <longitude>500050.0</longitude>
        <latitude>500050.0</latitude>
        <range>700</range>
        <tilt>10.0</tilt>
        <heading>10.0</heading>
      </LookAt>
      <styleUrl>#GeoServerStylePoints.0</styleUrl>
      <Point>
        <coordinates decimal="." cs="," ts=" ">500050,500050</coordinates>
      </Point>
    </Placemark>
  </Document>
</kml>
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.78 sec
Running org.vfny.geoserver.wms.responses.map.kml.TileLevelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.688 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Running org.geoserver.wms.CapabilitiesTest
Jun 13, 2008 8:39:38 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.656 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Jun 13, 2008 8:39:39 AM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.176 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.444 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.016 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.172 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
13 Jun 08:39:41 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
  at org.vfny.geoserver.wms.requests.GetFeatureInfoKvpReader.getRequest(GetFeatureInfoKvpReader.java:103)
  at org.geoserver.ows.adapters.KvpRequestReaderAdapter.createRequest(KvpRequestReaderAdapter.java:94)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:963)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:373)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:187)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:874)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:808)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:523)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:453)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:882)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:849)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:435)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:416)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:628)
  at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testUknownFormat(GetFeatureInfoTest.java:46)
  at sun.reflect.GeneratedMethodAccessor103.invoke(Unknown Source)
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.256 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
13 Jun 08:39:42 ERROR [geoserver.geosearch] - Regionating strategy for layer cite:DividedRoutes will start at ReferencedEnvelope[-180.0 : 0.0, -90.0 : 90.0] , 0,0,0. Starting to build database now.
13 Jun 08:39:42 ERROR [geoserver.geosearch] - builDB of cite_DividedRoutes_NUM_LANES completed after 1 features.
13 Jun 08:39:42 ERROR [geoserver.geosearch] - Table cite_DividedRoutes_NUM_LANES contains 1 rows after populateDB()
13 Jun 08:39:42 ERROR [geoserver.geosearch] - builDB of cite_DividedRoutes_the_geom completed after 1 features.
13 Jun 08:39:42 ERROR [geoserver.geosearch] - Table cite_DividedRoutes_the_geom contains 1 rows after populateDB()
13 Jun 08:39:43 ERROR [geoserver.geosearch] - Regionating strategy for layer sf:CenteredPoly will use world bounds. Starting to build database now.
13 Jun 08:39:43 ERROR [geoserver.geosearch] - builDB of sf_CenteredPoly_foo completed after 1 features.
13 Jun 08:39:43 ERROR [geoserver.geosearch] - Table sf_CenteredPoly_foo contains 1 rows after populateDB()
13 Jun 08:39:43 ERROR [geoserver.geosearch] - Regionating strategy for layer sf:Tiles will use world bounds. Starting to build database now.
13 Jun 08:39:43 ERROR [geoserver.geosearch] - builDB of sf_Tiles_location completed after 4 features.
13 Jun 08:39:43 ERROR [geoserver.geosearch] - builDB of sf_Tiles_location completed after 8 features.
13 Jun 08:39:43 ERROR [geoserver.geosearch] - Table sf_Tiles_location contains 8 rows after populateDB()
13 Jun 08:39:43 ERROR [geoserver.geosearch] - builDB of sf_Tiles_z completed after 4 features.
13 Jun 08:39:43 ERROR [geoserver.geosearch] - builDB of sf_Tiles_z completed after 8 features.
13 Jun 08:39:43 ERROR [geoserver.geosearch] - Table sf_Tiles_z contains 8 rows after populateDB()
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.657 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.22 sec
Results :
Tests in error:
  testUknownFormat(org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest)
Tests run: 88, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 50 seconds
[INFO] Finished at: Fri Jun 13 08:39:44 EDT 2008
[INFO] Final Memory: 32M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/280/changes
