[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2816
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2816/&gt;
[...truncated 20583 lines...]
[INFO] Preparing source:jar
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT-tests.jar
[INFO] Building Printing Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target&gt;
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/surefire-reports&gt;
T E S T S
Running org.geoserver.printing.SmokeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.125 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT-sources.jar
[INFO] Building HTTP Proxy Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/target&gt;
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/target/classes&gt;
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/target/proxy-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/target/proxy-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/target/proxy-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/target/proxy-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/proxy/2.1-SNAPSHOT/proxy-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/target/proxy-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/proxy/2.1-SNAPSHOT/proxy-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/target/proxy-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/proxy/2.1-SNAPSHOT/proxy-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoServer Web Application
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target&gt;
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/src/main/webapp/data&gt;
[INFO] snapshot org.geotools:gt-directory:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-directory:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/classes&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Jun 7, 2010 12:42:35 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won't be enabled.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.048 sec
Running org.geoserver.filters.GZIPResponseStreamTest
07 Jun 12:42:43 ERROR [layer.TileLayerDispatcher] - Configuration GeoServer Catalog Listener contained no layers.
07 Jun 12:42:43 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
07 Jun 12:42:43 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/null/../resources&gt; contained no layers.
07 Jun 12:42:43 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/null/../resources&gt;: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/null/../resources/geowebcache\.xml&gt;
07 Jun 12:42:45 ERROR [layer.TileLayerDispatcher] - Configuration GeoServer Catalog Listener contained no layers.
07 Jun 12:42:45 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
07 Jun 12:42:45 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/null/../resources&gt; contained no layers.
07 Jun 12:42:45 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/null/../resources&gt;: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/null/../resources/geowebcache\.xml&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.882 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.88 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.396 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/web-app-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/web-app-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/web-app-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/minimal&gt;
     [copy] Copying 25 files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/src/main/webapp/data&gt;
     [copy] Copied 14 empty directories to 8 empty directories under <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/src/main/webapp/data&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/web-app-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/web-app-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/web-app-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.1-SNAPSHOT/web-app-2.1-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Webapp assembled in[10952 msecs]
[INFO] Building war: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/target/geoserver.war&gt;
[INFO] Building GeoServer Extensions
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target&gt;
[INFO] [site:attach-descriptor]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/2.1-SNAPSHOT/extension-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/2.1-SNAPSHOT/extension-2.1-SNAPSHOT-tests.jar
[INFO] Building Application Schema Support
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/target&gt;
[INFO] snapshot org.geotools:gt-app-schema:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-app-schema:2.7-SNAPSHOT: checking for updates from osgeo
[WARNING] repository metadata for: 'snapshot org.geotools:gt-app-schema:2.7-SNAPSHOT' could not be retrieved from repository: osgeo due to an error: Error transferring file
[INFO] Repository 'osgeo' will be blacklisted
[INFO] snapshot org.geotools:app-schema:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-app-schema-resolver:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/target/app-schema-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/app-schema/2.1-SNAPSHOT/app-schema-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/target/app-schema-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/app-schema/2.1-SNAPSHOT/app-schema-2.1-SNAPSHOT-tests.jar
[INFO] Building Application Schema Integration Test
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target&gt;
[INFO] artifact org.geosciml:geosciml-2.0: checking for updates from opengeo
[INFO] artifact org.geosciml:geosciml-2.0: checking for updates from osgeo
[INFO] artifact org.geosciml:geosciml-2.0: checking for updates from maven-restlet
[INFO] artifact org.geosciml:geosciml-2.0: checking for updates from central
[INFO] artifact net.opengis.schemas:gml-3.1: checking for updates from opengeo
[INFO] artifact net.opengis.schemas:gml-3.1: checking for updates from osgeo
[INFO] artifact net.opengis.schemas:gml-3.1: checking for updates from maven-restlet
[INFO] artifact net.opengis.schemas:gml-3.1: checking for updates from central
[INFO] artifact net.opengis.schemas:xlink: checking for updates from opengeo
[INFO] artifact net.opengis.schemas:xlink: checking for updates from osgeo
[WARNING] repository metadata for: 'artifact net.opengis.schemas:xlink' could not be retrieved from repository: osgeo due to an error: Error transferring file
[INFO] artifact net.opengis.schemas:xlink: checking for updates from maven-restlet
[INFO] artifact net.opengis.schemas:xlink: checking for updates from central
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
No versions are present in the repository for the artifact with a range [1.0.0,1.0.1)
  net.opengis.schemas:xlink:jar:null
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  maven-restlet (http://maven.restlet.org),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  opengeo (http://repo.opengeo.org/)
[INFO] Total time: 14 minutes 10 seconds
[INFO] Finished at: Mon Jun 07 12:43:13 EDT 2010
[INFO] Final Memory: 52M/138M
Andrea,
I think this is exactly the same osgeo repo outage that bit you once:
[ERROR] BUILD ERROR
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2817/&gt;
