[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2845
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2845/changes&gt;
Changes:
[aaime] Forgot to update one provider
[aaime] [GEOS-4015] GeoServerTablePanel is not setup to support editable tables
[...truncated 19024 lines...]
  UNIT["degree", 0.017453292519943295],
  AXIS["Geodetic longitude", EAST],
  AXIS["Geodetic latitude", NORTH],
  AUTHORITY["EPSG","4326"]]-->
        <LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <BoundingBox SRS="EPSG:4326" maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <Style>
          <Name>RoadSegments</Name>
          <Title>Default Styler</Title>
          <Abstract/>
          <LegendURL height="20" width="20">
            <Format>image/png</Format>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=RoadSegments&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
      <Layer queryable="1">
        <Name>cdf:Seven</Name>
        <Title>Seven</Title>
        <Abstract>abstract about Seven</Abstract>
        <KeywordList>
          <Keyword>Seven</Keyword>
        </KeywordList>
        <SRS>EPSG:32615</SRS>
        <!--WKT definition of this CRS:
PROJCS["WGS 84 / UTM zone 15N",
  GEOGCS["WGS 84",
    DATUM["World Geodetic System 1984",
      SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]],
  PARAMETER["central_meridian", -93.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["scale_factor", 0.9996],
  PARAMETER["false_easting", 500000.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["Easting", EAST],
  AXIS["Northing", NORTH],
  AUTHORITY["EPSG","32615"]]-->
        <Style>
          <Name>Default</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Seven&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cite:Streams</Name>
        <Title>Streams</Title>
        <Abstract>abstract about Streams</Abstract>
        <KeywordList>
          <Keyword>Streams</Keyword>
        </KeywordList>
        <SRS>EPSG:4326</SRS>
GEOGCS["WGS 84",
        <Style>
          <Name>Streams</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Streams&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cdf:Updates</Name>
        <Title>Updates</Title>
        <Abstract>abstract about Updates</Abstract>
        <KeywordList>
          <Keyword>Updates</Keyword>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Updates&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
</WMT_MS_Capabilities>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.39 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.197 sec
Results :
Tests run: 182, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target&gt;
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/surefire-reports&gt;
T E S T S
Running org.geoserver.gwc.GWCCatalogListenerTest
Jun 17, 2010 7:43:44 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won't be enabled.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
17 Jun 07:43:46 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
17 Jun 07:43:46 ERROR [layer.TileLayerDispatcher] - Configuration <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources&gt; contained no layers.
17 Jun 07:43:46 ERROR [layer.TileLayerDispatcher] - Error reading service information from <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources&gt;: Error parsing file <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/null/../resources/geowebcache\.xml&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.809 sec
Running org.geoserver.gwc.GWCIntegrationTest
17 Jun 07:43:48 ERROR [geowebcache.GeoWebCacheDispatcher] - null http://localhost/geoserver/gwc/service/wmts?request=GetTile&layer=cite:BasicPolygons&format=image/png&tilematrixset=EPSG:4326&tilematrix=EPSG:4326:0&tilerow=0&tilecol=0
java.lang.NullPointerException
  at org.geowebcache.layer.TileLayerDispatcher.getTileLayer(TileLayerDispatcher.java:69)
  at org.geowebcache.service.wmts.WMTSService.getTile(WMTSService.java:108)
  at org.geowebcache.service.wmts.WMTSService.getConveyor(WMTSService.java:79)
  at org.geowebcache.GeoWebCacheDispatcher.handleServiceRequest(GeoWebCacheDispatcher.java:333)
  at org.geowebcache.GeoWebCacheDispatcher.handleRequestInternal(GeoWebCacheDispatcher.java:252)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1089)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1056)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:463)
  at org.geoserver.gwc.GWCIntegrationTest.testPngIntegration(GWCIntegrationTest.java:12)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:126)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.32 sec <<< FAILURE!
Results :
Failed tests:
  testPngIntegration(org.geoserver.gwc.GWCIntegrationTest)
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 4 minutes 18 seconds
[INFO] Finished at: Thu Jun 17 07:43:49 EDT 2010
[INFO] Final Memory: 45M/117M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2846/changes&gt;
Changes:
[jdeolive] GEOS-3998, fixing GeoServerInfo client properties bug and adding test
[...truncated 20493 lines...]
  at org.geoserver.web.demo.PreviewLayer.getRequest(PreviewLayer.java:134)
  at org.geoserver.web.demo.PreviewLayer.getWmsLink(PreviewLayer.java:172)
  at org.geoserver.web.demo.MapPreviewPage$1.getComponentForProperty(MapPreviewPage.java:76)
  at org.geoserver.web.wicket.GeoServerTablePanel$1$1.populateItem(GeoServerTablePanel.java:139)
  at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:573)
  at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:127)
  at org.apache.wicket.Component.internalBeforeRender(Component.java:1009)
  at org.apache.wicket.Component.beforeRender(Component.java:1041)
  at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590)
  at org.apache.wicket.Component.onBeforeRender(Component.java:3727)
  at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:147)
  at org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:109)
  at org.apache.wicket.Page.onBeforeRender(Page.java:1458)
  at org.apache.wicket.Component.prepareForRender(Component.java:2167)
  at org.apache.wicket.Page.renderPage(Page.java:892)
  at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:240)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:104)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1245)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1316)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:578)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:469)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:378)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:289)
  at org.geoserver.web.demo.MapPreviewPageTest.testValues(MapPreviewPageTest.java:7)
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.305 sec
Running org.geoserver.web.demo.DemoRequestsPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.14 sec
Running org.geoserver.web.demo.SRSListPageTest
Jun 17, 2010 1:42:01 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.106 sec
Results :
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/demo/target/web-demo-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.1-SNAPSHOT/web-demo-2.1-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target&gt;
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/classes&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.security.user.NewUserPageTest
Jun 17, 2010 1:42:12 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.794 sec
Running org.geoserver.web.security.user.UserListPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.62 sec
Running org.geoserver.web.security.data.DataAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.267 sec
Running org.geoserver.web.security.data.NewRulePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.038 sec
Running org.geoserver.web.security.ConfirmRemovalUserPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.319 sec
Running org.geoserver.web.security.user.EditUserPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.488 sec
Running org.geoserver.web.security.ConfirmRemovalServicePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.272 sec
Running org.geoserver.web.security.ConfirmRemovalDataAccessRulePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.247 sec
Running org.geoserver.web.security.service.ServiceAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.986 sec
Running org.geoserver.web.security.catalog.CatalogModePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.075 sec
Results :
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/web-security-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/web-security-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/web-security-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/web-security-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/web-security-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/security/target/web-security-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT-sources.jar
[INFO] Building Community Space
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target&gt;
[INFO] [site:attach-descriptor]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/target/community-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT-tests.jar
[INFO] Building Printing Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target&gt;
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/classes&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/surefire-reports&gt;
T E S T S
Running org.geoserver.printing.SmokeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.184 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/printing/target/printing-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.1-SNAPSHOT/printing-2.1-SNAPSHOT-sources.jar
[INFO] Building HTTP Proxy Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/target&gt;
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/target/classes&gt;
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/src/main/java/org/geoserver/web/proxy/MimetypeProvider.java&gt;:\[43,18\] model(java.lang.Object) in org.geoserver.web.proxy.MimetypeProvider cannot override model(java.lang.Object) in org.geoserver.web.wicket.GeoServerDataProvider; overridden method is final
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/proxy/src/main/java/org/geoserver/web/proxy/HostnameProvider.java&gt;:\[43,18\] model(java.lang.Object) in org.geoserver.web.proxy.HostnameProvider cannot override model(java.lang.Object) in org.geoserver.web.wicket.GeoServerDataProvider; overridden method is final
[INFO] Total time: 6 minutes 40 seconds
[INFO] Finished at: Thu Jun 17 13:42:36 EDT 2010
[INFO] Final Memory: 48M/112M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2847/changes&gt;
