See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/288/changes
Changes:
[arneke] WMS GetMapResponse - no functional changes, just cleaning up formatting to make it easier to debug
[jdeolive] reading coverage parameters
[groldan] set svn:ignore on /target
[jdeolive] added a special wicket model which backs onto a map
[groldan] datastore set up form revisited: using a listview and panels it is possible to create a specific form input field depending on the ds param type
[groldan] first attempt at creating the new datastore form using a wicket repeater. Gonna try out the dynamic markup hierarchies using panels approach next in order to build up the proper form input control type based on the parameter class
[groldan] added gt-postgis dependency to test datastore set up
[dwinslow] Oops, make ResourceConfigurationPanelInfo's filename match the class name.
[dwinslow] Fix so that resource config form can be submitted. Converters to allow setting more complex data Real Soon Now.
[dwinslow] Initial work on modular resource configuration form.
[jdeolive] removed Serializable
[arneke] KML vector transformer, brings color back (at least for linepolygons), by using color code from symbolizer and avoiding style object.
[arneke] KML vector transformer, fixes unit tests, breaks color for line style (revisit tomorrow)
[arneke] GEOS-1993 , first steps anyway. There's still a problem with some datastores not supporting startIndex.
[arneke] GEOS-1994 KML, allows PointSymbolizer definition on polygon features to override default point symbolizer. Handy when the polygons or lines are small, in which case the entire map get clobbered by the default icons.
[jdeolive] proxying all objects supported by implementation object, factored out list implenetation
[jdeolive] added methods for getting resources by store
[jdeolive] added a global logger and looking of i18n files to initilization
[dwinslow] MainPageInfo is not supposed to be abstract.
[jdeolive] added docs, chagned title -> titleKey
[arneke] KML regionate slightly less verbose
[dwinslow] Get rid of some compiler warnings.
[jdeolive] using repeater for main page links
[jdeolive] added data main page
[arneke] KML regionate - Avoid reprojecting EPSG:4326 (already correct), caused NPEs
[jdeolive] ensured logs directory created when it does not exist
[jdeolive] modified extension lookups so that factory spi extensions are included
[jdeolive] added method to findOrCreateDirectory
[jdeolive] moved logging initialization from web to main
[jdeolive] added web2 community module
[dgricci] French resources updates
[arneke] KML regionating strategy. Cleaning up indentation and two typos, no functional changes
[...truncated 2545 lines...]
2503/19K
2507/19K
2511/19K
2511/19K
19K downloaded
2512/59K
2514/59K
2518/59K
2522/59K
2522/59K
2526/59K
2530/59K
2534/59K
2536/59K
2540/59K
2540/59K
2544/59K
2548/59K
2552/59K
2556/59K
2557/59K
2560/59K
2563/59K
2566/59K
2570/59K
2571/59K
59K downloaded
2572/254K
2573/254K
2575/254K
2576/254K
2580/254K
2582/254K
2585/254K
2586/254K
2588/254K
2589/254K
2590/254K
2592/254K
2595/254K
2596/254K
2597/254K
2600/254K
2603/254K
2605/254K
2606/254K
2607/254K
2609/254K
2610/254K
2612/254K
2613/254K
2614/254K
2616/254K
2617/254K
2619/254K
2620/254K
2622/254K
2623/254K
2624/254K
2626/254K
2629/254K
2630/254K
2631/254K
2633/254K
2634/254K
2636/254K
2637/254K
2639/254K
2640/254K
2641/254K
2643/254K
2644/254K
2646/254K
2647/254K
2648/254K
2650/254K
2651/254K
2653/254K
2654/254K
2655/254K
2657/254K
2660/254K
2661/254K
2663/254K
2664/254K
2665/254K
2667/254K
2668/254K
2670/254K
2671/254K
2672/254K
2674/254K
2675/254K
2677/254K
2681/254K
2685/254K
2689/254K
2693/254K
2697/254K
2701/254K
2702/254K
2704/254K
2708/254K
2712/254K
2713/254K
2715/254K
2719/254K
2723/254K
2727/254K
2731/254K
2735/254K
2739/254K
2739/254K
2743/254K
2747/254K
2751/254K
2755/254K
2757/254K
2761/254K
2765/254K
2769/254K
2773/254K
2777/254K
2781/254K
2783/254K
2787/254K
2791/254K
2795/254K
2799/254K
2803/254K
2804/254K
2808/254K
2812/254K
2816/254K
2820/254K
2824/254K
2825/254K
254K downloaded
2826/153K
2828/153K
2829/153K
2831/153K
2832/153K
2833/153K
2836/153K
2840/153K
2844/153K
2848/153K
2852/153K
2856/153K
2859/153K
2863/153K
2867/153K
2871/153K
2875/153K
2879/153K
2881/153K
2885/153K
2889/153K
2893/153K
2897/153K
2901/153K
2905/153K
2909/153K
2913/153K
2913/153K
2917/153K
2921/153K
2925/153K
2929/153K
2933/153K
2935/153K
2939/153K
2943/153K
2947/153K
2951/153K
2955/153K
2959/153K
2963/153K
2967/153K
2971/153K
2975/153K
2978/153K
153K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 19 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/classes
[INFO] [resources:testResources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] Compiling 7 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/surefire-reports
T E S T S
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.481 sec
Running org.geoserver.feature.ReprojectingFilterVisitorTest
Jun 18, 2008 5:19:34 PM org.geotools.data.DefaultTransaction finalize
SEVERE: There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
SEVERE: Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 11, Failures: 0, Errors: 11, Skipped: 0, Time elapsed: 0.792 sec <<< FAILURE!
Results :
Tests in error:
testNoProjection(org.geoserver.feature.ReprojectingFilterVisitorTest)
testBboxNoReprojection(org.geoserver.feature.ReprojectingFilterVisitorTest)
testBboxReproject(org.geoserver.feature.ReprojectingFilterVisitorTest)
testBboxReprojectUnreferencedProperty(org.geoserver.feature.ReprojectingFilterVisitorTest)
testBboxReprojectUnreferencedBBox(org.geoserver.feature.ReprojectingFilterVisitorTest)
testIntersectsReproject(org.geoserver.feature.ReprojectingFilterVisitorTest)
testIntersectsUnreferencedGeometry(org.geoserver.feature.ReprojectingFilterVisitorTest)
testIntersectsUnreferencedProperty(org.geoserver.feature.ReprojectingFilterVisitorTest)
testPropertyEqualsFirstArgumentNotPropertyName(org.geoserver.feature.ReprojectingFilterVisitorTest)
testIntersectsWithFunction(org.geoserver.feature.ReprojectingFilterVisitorTest)
testPropertyEqualWithFunction(org.geoserver.feature.ReprojectingFilterVisitorTest)
Tests run: 21, Failures: 0, Errors: 11, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 54 seconds
[INFO] Finished at: Wed Jun 18 17:19:35 EDT 2008
[INFO] Final Memory: 24M/52M
Failed to send e-mail to dgricci because no e-mail address is known, and no default e-mail domain is configured
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
