See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/289/changes
[...truncated 1137 lines...]
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 80 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Web Feature Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target
[INFO] Compiling 160 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/classes
[INFO] Compiling 33 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports
T E S T S
Running org.geoserver.wfs.AliasTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 2.624 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.VersionNegotiationTest
Tests run: 6, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 0.524 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.GetCapabilitiesTest
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.376 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.LockFeatureTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.072 sec <<< FAILURE!
Running org.geoserver.wfs.response.GeoJSONTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.192 sec <<< FAILURE!
Running org.geoserver.wfs.GeometrylessTest
Tests run: 8, Failures: 0, Errors: 8, Skipped: 0, Time elapsed: 1.836 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.DescribeFeatureResponseTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.116 sec <<< FAILURE!
Running org.geoserver.wfs.SrsNameTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.12 sec <<< FAILURE!
Running org.geoserver.wfs.GetFeatureTest
Tests run: 7, Failures: 0, Errors: 7, Skipped: 0, Time elapsed: 0.548 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.WFSXmlTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.136 sec <<< FAILURE!
Running org.geoserver.wfs.GetFeatureWithLockTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.176 sec <<< FAILURE!
Running org.geoserver.wfs.LockFeatureTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.168 sec <<< FAILURE!
Running org.geoserver.wfs.ReprojectingFilterVisitorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.112 sec
Running org.geoserver.wfs.kvp.FilterKvpParserTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.008 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.GetFeatureTest
Tests run: 17, Failures: 0, Errors: 17, Skipped: 0, Time elapsed: 0.996 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.TransactionTest
Tests run: 10, Failures: 0, Errors: 10, Skipped: 0, Time elapsed: 0.608 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.GetFeatureWithLockTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.048 sec <<< FAILURE!
Running org.geoserver.wfs.xml.GML3FeatureProducerTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.156 sec <<< FAILURE!
Running org.geoserver.wfs.response.WfsXmlWriterTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.052 sec <<< FAILURE!
Running org.geoserver.wfs.TransactionTest
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.984 sec <<< FAILURE!
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.6 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.WFSReprojectionTest
Tests run: 13, Failures: 0, Errors: 13, Skipped: 0, Time elapsed: 1.845 sec <<< FAILURE!
Running org.geoserver.wfs.ReprojectionTest
Tests run: 8, Failures: 0, Errors: 8, Skipped: 0, Time elapsed: 0.432 sec <<< FAILURE!
Running org.geoserver.wfs.TransactionListenerTest
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 7, Skipped: 0, Time elapsed: 0.46 sec <<< FAILURE!
Running org.geoserver.wfs.DescribeFeatureTest
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.1 sec <<< FAILURE!
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.06 sec <<< FAILURE!
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Running org.geoserver.wfs.response.ShapeZipTest
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.164 sec <<< FAILURE!
Results :
Tests in error:
testAliasFifteen(org.geoserver.wfs.AliasTest)
testGetByFeatureId(org.geoserver.wfs.AliasTest)
test0(org.geoserver.wfs.v1_1.VersionNegotiationTest)
test1(org.geoserver.wfs.v1_1.VersionNegotiationTest)
test2(org.geoserver.wfs.v1_1.VersionNegotiationTest)
test5(org.geoserver.wfs.v1_1.VersionNegotiationTest)
test6(org.geoserver.wfs.v1_1.VersionNegotiationTest)
test7(org.geoserver.wfs.v1_1.VersionNegotiationTest)
testGet(org.geoserver.wfs.v1_1.GetCapabilitiesTest)
testPost(org.geoserver.wfs.v1_1.GetCapabilitiesTest)
testOutputFormats(org.geoserver.wfs.v1_1.GetCapabilitiesTest)
testPostNoSchemaLocation(org.geoserver.wfs.v1_1.GetCapabilitiesTest)
testLock(org.geoserver.wfs.v1_1.LockFeatureTest)
testGet(org.geoserver.wfs.response.GeoJSONTest)
testPost(org.geoserver.wfs.response.GeoJSONTest)
testGeometryCollection(org.geoserver.wfs.response.GeoJSONTest)
testGetFeature10(org.geoserver.wfs.GeometrylessTest)
testGetFeatureReproject10(org.geoserver.wfs.GeometrylessTest)
testGetFeature11(org.geoserver.wfs.GeometrylessTest)
testGetFeatureReproject11(org.geoserver.wfs.GeometrylessTest)
testGetFeatureReprojectPost(org.geoserver.wfs.GeometrylessTest)
testUpdate(org.geoserver.wfs.GeometrylessTest)
testDelete(org.geoserver.wfs.GeometrylessTest)
testInsert(org.geoserver.wfs.GeometrylessTest)
testSingle(org.geoserver.wfs.v1_1.DescribeFeatureResponseTest)
testWithDifferntNamespaces(org.geoserver.wfs.v1_1.DescribeFeatureResponseTest)
testWfs10(org.geoserver.wfs.SrsNameTest)
testWfs11(org.geoserver.wfs.SrsNameTest)
testGet(org.geoserver.wfs.GetFeatureTest)
testPost(org.geoserver.wfs.GetFeatureTest)
testGetPropertyNameEmpty(org.geoserver.wfs.GetFeatureTest)
testGetPropertyNameStar(org.geoserver.wfs.GetFeatureTest)
testAlienNamespace(org.geoserver.wfs.GetFeatureTest)
testPostWithFilter(org.geoserver.wfs.GetFeatureTest)
testLax(org.geoserver.wfs.GetFeatureTest)
testValid(org.geoserver.wfs.v1_1.WFSXmlTest)
testInvalid(org.geoserver.wfs.v1_1.WFSXmlTest)
testUpdateLockedFeatureWithLockId(org.geoserver.wfs.GetFeatureWithLockTest)
testUpdateLockedFeatureWithoutLockId(org.geoserver.wfs.GetFeatureWithLockTest)
testGetFeatureWithLockReleaseActionSome(org.geoserver.wfs.GetFeatureWithLockTest)
testLockActionSomeAlreadyLocked(org.geoserver.wfs.LockFeatureTest)
testDeleteWithoutLockId(org.geoserver.wfs.LockFeatureTest)
testUpdateWithLockId(org.geoserver.wfs.LockFeatureTest)
testMultiFilter(org.geoserver.wfs.kvp.FilterKvpParserTest)
testEmptyAndNonEmptyFilter(org.geoserver.wfs.kvp.FilterKvpParserTest)
test(org.geoserver.wfs.kvp.FilterKvpParserTest)
testGet(org.geoserver.wfs.v1_1.GetFeatureTest)
testPost(org.geoserver.wfs.v1_1.GetFeatureTest)
testGetPropertyNameEmpty(org.geoserver.wfs.v1_1.GetFeatureTest)
testGetPropertyNameStar(org.geoserver.wfs.v1_1.GetFeatureTest)
testPostWithFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
testPostFormEncoded(org.geoserver.wfs.v1_1.GetFeatureTest)
testPostWithBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
testPostWithFailingUrnBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
testPostWithMatchingUrnBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest)
testResultTypeHitsGet(org.geoserver.wfs.v1_1.GetFeatureTest)
testResultTypeHitsPost(org.geoserver.wfs.v1_1.GetFeatureTest)
testWithSRS(org.geoserver.wfs.v1_1.GetFeatureTest)
testWithSillyLiteral(org.geoserver.wfs.v1_1.GetFeatureTest)
testWithGmlObjectId(org.geoserver.wfs.v1_1.GetFeatureTest)
testPostWithBoundsEnabled(org.geoserver.wfs.v1_1.GetFeatureTest)
testAfterFeatureTypeAdded(org.geoserver.wfs.v1_1.GetFeatureTest)
testWithGMLProperties(org.geoserver.wfs.v1_1.GetFeatureTest)
testInsertWithBoundedBy(org.geoserver.wfs.v1_1.TransactionTest)
testInsert1(org.geoserver.wfs.v1_1.TransactionTest)
testInsertWithNoSRS(org.geoserver.wfs.v1_1.TransactionTest)
testInsertWithSRS(org.geoserver.wfs.v1_1.TransactionTest)
testInsertWithGMLProperties(org.geoserver.wfs.v1_1.TransactionTest)
testUpdateWithGMLProperties(org.geoserver.wfs.v1_1.TransactionTest)
testInsert2(org.geoserver.wfs.v1_1.TransactionTest)
testUpdateForcedSRS(org.geoserver.wfs.v1_1.TransactionTest)
testUpdateNoSRS(org.geoserver.wfs.v1_1.TransactionTest)
testUpdateWithInvalidProperty(org.geoserver.wfs.v1_1.TransactionTest)
test(org.geoserver.wfs.v1_1.GetFeatureWithLockTest)
testSingle(org.geoserver.wfs.xml.GML3FeatureProducerTest)
testMultipleSameNamespace(org.geoserver.wfs.xml.GML3FeatureProducerTest)
testMultipleDifferentNamespace(org.geoserver.wfs.xml.GML3FeatureProducerTest)
test(org.geoserver.wfs.response.WfsXmlWriterTest)
testUpdate(org.geoserver.wfs.TransactionTest)
testDelete(org.geoserver.wfs.TransactionTest)
testInsert(org.geoserver.wfs.TransactionTest)
testInsertWithBoundedBy(org.geoserver.wfs.TransactionTest)
testGML2(org.geoserver.wfs.xml.GMLOutputFormatTest)
testGML2GZIP(org.geoserver.wfs.xml.GMLOutputFormatTest)
testGML3(org.geoserver.wfs.xml.GMLOutputFormatTest)
testUpdate(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testGetFeatureGet(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testGetFeaturePost(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testGetFeatureWithProjectedBoxGet(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testGetFeatureWithProjectedBoxPost(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testInsertSrsName(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testInsertGeomSrsName(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testUpdateReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testUpdateReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testDeleteReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testDeleteReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testLockReprojectFilter(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testLockReprojectFilterDefaultCRS(org.geoserver.wfs.v1_1.WFSReprojectionTest)
testUpdate(org.geoserver.wfs.ReprojectionTest)
testGetFeatureGet(org.geoserver.wfs.ReprojectionTest)
testGetFeaturePost(org.geoserver.wfs.ReprojectionTest)
testReprojectNullGeometries(org.geoserver.wfs.ReprojectionTest)
testGetFeatureWithProjectedBoxGet(org.geoserver.wfs.ReprojectionTest)
testGetFeatureWithProjectedBoxPost(org.geoserver.wfs.ReprojectionTest)
testInsertSrsName(org.geoserver.wfs.ReprojectionTest)
testInsertGeomSrsName(org.geoserver.wfs.ReprojectionTest)
testUpdate(org.geoserver.wfs.TransactionListenerTest)
testDelete(org.geoserver.wfs.TransactionListenerTest)
testInsert(org.geoserver.wfs.TransactionListenerTest)
testGlobalMax(org.geoserver.wfs.MaxFeaturesTest)
testLocalMax(org.geoserver.wfs.MaxFeaturesTest)
testLocalMaxBigger(org.geoserver.wfs.MaxFeaturesTest)
testCombinedLocalMaxes(org.geoserver.wfs.MaxFeaturesTest)
testCombinedLocalMaxesBigger(org.geoserver.wfs.MaxFeaturesTest)
testCombinedLocalMaxesBiggerRequestOverride(org.geoserver.wfs.MaxFeaturesTest)
testMaxFeaturesBreak(org.geoserver.wfs.MaxFeaturesTest)
testGet(org.geoserver.wfs.DescribeFeatureTest)
testPost(org.geoserver.wfs.DescribeFeatureTest)
testPostDummyFeature(org.geoserver.wfs.DescribeFeatureTest)
testDateMappings(org.geoserver.wfs.v1_1.DescribeFeatureTypeTest)
testNoNamespaceDeclaration(org.geoserver.wfs.v1_1.DescribeFeatureTypeTest)
testBuildGml2(org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest)
test(org.geoserver.wfs.v1_1.CapabilitiesTransformerTest)
testNoNativeProjection(org.geoserver.wfs.response.ShapeZipTest)
testGet(org.geoserver.wfs.GetCapabilitiesTest)
testPost(org.geoserver.wfs.GetCapabilitiesTest)
testOutputFormats(org.geoserver.wfs.GetCapabilitiesTest)
Tests run: 135, Failures: 0, Errors: 127, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 41 seconds
[INFO] Finished at: Fri Feb 15 18:08:43 EST 2008
[INFO] Final Memory: 32M/63M
