[Geoserver-devel] Build failed in Hudson: geoserver-trunk #29
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/29/changes
[...truncated 508 lines...]
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-geotiff:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-geotiff:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-gtopo30:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-gtopo30:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-image:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-image:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-imagemosaic:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-imagemosaic:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 35 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes
[INFO] [resources:testResources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Model v1.1.0
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target
[INFO] [resources:resources]
[INFO] Compiling 149 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows.1_1/1.7.0-SNAPSHOT/net.opengis.ows.1_1-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows.1_1/1.7.0-SNAPSHOT/net.opengis.ows.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows.1_1/target/net.opengis.ows.1_1-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows.1_1/1.7.0-SNAPSHOT/net.opengis.ows.1_1-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Model v1.1.1
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target
[INFO] Compiling 94 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wcs.1_1/1.7.0-SNAPSHOT/net.opengis.wcs.1_1-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wcs.1_1/1.7.0-SNAPSHOT/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wcs.1_1/target/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wcs.1_1/1.7.0-SNAPSHOT/net.opengis.wcs.1_1-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service 1.1.1 Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset" does not exist. Creating the directory.
Reading from file http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java" does not exist. Will create one.
File "http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java" does not exist. Will create one.
Annotated grammar generated successfully in http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] Compiling 54 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/classes
[INFO] snapshot org.geoserver:main:1.7.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:main:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 12 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports
T E S T S
Running org.geoserver.wcs.DescribeCoverageTest
Tests run: 8, Failures: 0, Errors: 8, Skipped: 0, Time elapsed: 2.012 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.GetCoverageReaderTest
Tests run: 9, Failures: 0, Errors: 9, Skipped: 0, Time elapsed: 0.068 sec <<< FAILURE!
Running org.geoserver.wcs.kvp.BoundingBoxKvpParserTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.092 sec
Running org.geoserver.wcs.GetCoverageTest
Tests run: 16, Failures: 0, Errors: 16, Skipped: 0, Time elapsed: 0.132 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCapabilitiesXmlParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.216 sec
Running org.geoserver.wcs.GetCoverageMultipartEncodingTest
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0, Time elapsed: 0.032 sec <<< FAILURE!
Running org.geoserver.wcs.GetCoverageSupportsStoreTrueTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.012 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCoverageXmlParserTest
class [Ljava.lang.Double;: [Ljava.lang.Double;@e76438
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.936 sec
Running org.geoserver.wcs.kvp.RangeSubsetKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.wcs.xml.DescribeCoverageXmlParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.164 sec
Running org.geoserver.wcs.GetCapabilitiesTest
Tests run: 17, Failures: 0, Errors: 17, Skipped: 0, Time elapsed: 0.088 sec <<< FAILURE!
Results :
Tests in error:
  testDescribeNoIdentifiers(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeUnknownCoverageKvp(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeMissingVersion(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeUnknownCoverageXml(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeDemCoverageKvp(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeDemCoverageXml(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeRotatedCoverage(org.geoserver.wcs.DescribeCoverageTest)
  testDescribeImageCoverage(org.geoserver.wcs.DescribeCoverageTest)
  testMissingParams(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testUnknownCoverageParams(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testBasic(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testUnsupportedCRS(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testGridTypes(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testGridCS(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testGridOrigin(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testGridOffsets(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testRangeSubset(org.geoserver.wcs.kvp.GetCoverageReaderTest)
  testKvpBasic(org.geoserver.wcs.GetCoverageTest)
  testAntimeridianWorld(org.geoserver.wcs.GetCoverageTest)
  testAntimeridianTaz(org.geoserver.wcs.GetCoverageTest)
  testWrongFormatParams(org.geoserver.wcs.GetCoverageTest)
  testDefaultGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testWrongGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testWrongGridOffsets(org.geoserver.wcs.GetCoverageTest)
  testNoGridOffsets(org.geoserver.wcs.GetCoverageTest)
  testGridOffsetsSubsample(org.geoserver.wcs.GetCoverageTest)
  testInvalidRangeSubset(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetSingle(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetMulti(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetSwap(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetOnlyInterpolation(org.geoserver.wcs.GetCoverageTest)
  testRangeSubsetOnlyField(org.geoserver.wcs.GetCoverageTest)
  testNullGridOrigin(org.geoserver.wcs.GetCoverageTest)
  testKvpBasic(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testArcgridException(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testTiffOutput(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testPngOutput(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testGeotiffNamesGalore(org.geoserver.wcs.GetCoverageMultipartEncodingTest)
  testKvpBasic(org.geoserver.wcs.GetCoverageSupportsStoreTrueTest)
  testGetBasic(org.geoserver.wcs.GetCapabilitiesTest)
  testNoServiceContactInfo(org.geoserver.wcs.GetCapabilitiesTest)
  testPostBasic(org.geoserver.wcs.GetCapabilitiesTest)
  testUnsupportedVersionPost(org.geoserver.wcs.GetCapabilitiesTest)
  testUnsupportedVersionGet(org.geoserver.wcs.GetCapabilitiesTest)
  testSupportedVersionGet(org.geoserver.wcs.GetCapabilitiesTest)
  testSupportedVersionPost(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceInferiorGet(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceInferiorPost(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceEqualsGet(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceEqualsPost(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceSuperiorGet(org.geoserver.wcs.GetCapabilitiesTest)
  testUpdateSequenceSuperiorPost(org.geoserver.wcs.GetCapabilitiesTest)
  testSectionsBogus(org.geoserver.wcs.GetCapabilitiesTest)
  testSectionsAll(org.geoserver.wcs.GetCapabilitiesTest)
  testOneSection(org.geoserver.wcs.GetCapabilitiesTest)
  testTwoSection(org.geoserver.wcs.GetCapabilitiesTest)
Tests run: 76, Failures: 0, Errors: 56, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 5 seconds
[INFO] Finished at: Mon Mar 31 10:10:16 EDT 2008
[INFO] Final Memory: 32M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/30/changes
