[Geoserver-devel] Build failed in Hudson: geoserver-trunk #2934
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2934/&gt;
[...truncated 1317 lines...]
06 Jul 11:30:28 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
06 Jul 11:30:28 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
06 Jul 11:30:28 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
Jul 6, 2010 11:30:28 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14403data&gt;
Jul 6, 2010 11:30:28 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6b28'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6b29'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6b2a'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6b2b'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14405data&gt;
INFO: Disposing datastore 'sf'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.457 sec
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
Jul 6, 2010 11:30:29 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14407data&gt;
Jul 6, 2010 11:30:29 AM org.geotools.referencing.operation.projection.TransverseMercator.Inverse transform
WARNING: Possible use of "Transverse_Mercator (Inverse transform)" projection outside its valid area.
Latitude 2541°05.9'N is out of range (±90°).
Jul 6, 2010 11:30:29 AM org.geoserver.test.RemoteOWSTestSupport isRemoteWMSStatesAvailable
WARNING: Skipping remote OWS test because they were not enabled via -DremoteOwsTests=true
Jul 6, 2010 11:30:29 AM org.geoserver.catalog.impl.CatalogBuilderTest testWMS
WARNING: Remote OWS tests disabled, skipping catalog builder wms tests
Jul 6, 2010 11:30:29 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6a77'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6a78'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6a75'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6a76'
Jul 6, 2010 11:30:29 AM org.geoserver.catalog.ResourcePool$CoverageReaderCache dispose
INFO: Disposing grid coverage reader 'DEM'
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.684 sec
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.security.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.vfny.geoserver.ProjectionPolicyTest
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14409data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6a22'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6a21'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14411data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6a0d'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6a0c'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14413data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-69f7'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-69f8'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.294 sec
Running org.geoserver.security.SecureCatalogIntegrationTest
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14415data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-69d3'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-69d5'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-69d6'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-69d4'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14418data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-697c'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-697d'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-697e'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-697b'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14420data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6923'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6924'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6926'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6925'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.404 sec
Running org.geoserver.ows.URLManglersTest
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14422data&gt;
Jul 6, 2010 11:30:30 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-68cb'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-68cc'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-68cd'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-68ce'
Jul 6, 2010 11:30:30 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14424data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6873'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6874'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6875'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6876'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14426data&gt;
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.384 sec
Running org.geoserver.catalog.impl.CatalogImplTest
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-681b'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-681c'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-681d'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-681e'
Tests run: 55, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.05 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14428data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6772'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6773'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6774'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6771'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14430data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6719'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-671a'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-671b'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6718'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14432data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-66c0'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-66c1'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-66c2'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-66bf'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/./target/mock14434data&gt;
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6667'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6668'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6669'
INFO: Disposing datastore 'DataStoreInfoImpl-6453e363:129a860e835:-6666'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.614 sec
Results :
Failed tests:
  testReadOnlyFeatureSourceDataStore(org.geoserver.security.decorators.ReadOnlyFeatureSourceTest)
Tests run: 256, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 1 minute 24 seconds
[INFO] Finished at: Tue Jul 06 11:30:31 EDT 2010
[INFO] Final Memory: 40M/114M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2935/&gt;
