See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/294/changes
[...truncated 1582 lines...]
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:408)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:517)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:500)
at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:29)
at sun.reflect.GeneratedMethodAccessor93.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.444 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.904 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.104 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.244 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.164 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.416 sec
Results :
Tests run: 135, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.7.0-SNAPSHOT/wfs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.7.0-SNAPSHOT/wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Versioning Web Feature Service Model
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 28 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfsv/1.7.0-SNAPSHOT/net.opengis.wfsv-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfsv/1.7.0-SNAPSHOT/net.opengis.wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target
[INFO] snapshot org.geotools:gt2-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 43 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/classes
[INFO] Nothing to compile - all classes are up to date
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target
[INFO] snapshot org.geotools:gt2-shapefile-renderer:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 128 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/classes
[INFO] Compiling 17 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.508 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.964 sec
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.66 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.9 sec
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.388 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.36 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.172 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.82 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
org.vfny.geoserver.wms.WmsException: No such style: ThisStyleDoesNotExists
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.133 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureDescriptionTemplateTest
<table border='1'>
<tr>
<th colspan='4' scope='col'>testType</th>
</tr>
<tr>
<td>string</td>
<td>int</td>
<td>double</td>
<td>geom</td>
</tr>
<tr>
<td>
three
</td>
<td>
3
</td>
<td>
3.3
</td>
<td>
[GEOMETRY]
</td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.248 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.14 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.5 sec
Results :
Tests run: 48, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.0-SNAPSHOT/wms-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.0-SNAPSHOT/wms-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Application Module
[INFO] artifact org.geoserver.maven:config: checking for updates from mortbay-repo
[INFO] artifact org.geoserver.maven:config: checking for updates from refractions-plugins
[INFO] artifact org.geoserver.maven:config: checking for updates from central
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from mortbay-repo
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
[delete] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] Compiling 109 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/classes
[INFO] Compiling 4 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/surefire-reports
Failed to load Main-Class manifest attribute from
/tmp/surefirebooter8226.jar
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 22 seconds
[INFO] Finished at: Sun Feb 17 18:15:08 EST 2008
[INFO] Final Memory: 30M/63M
