See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/2989/changes>
Changes:
[jdeolive] rolling back recent changes for GEOS-3534 and fixing the issue at the geotools level
[...truncated 29078 lines...]
at org.eclipse.xsd.impl.XSDIncludeImpl.patch(XSDIncludeImpl.java:233)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.patch(XSDConcreteComponentImpl.java:526)
at org.eclipse.xsd.impl.XSDSchemaImpl.patchContents(XSDSchemaImpl.java:1547)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java:1524)
at org.eclipse.xsd.impl.XSDSchemaImpl.incorporate(XSDSchemaImpl.java:3235)
at org.eclipse.xsd.impl.XSDSchemaImpl.included(XSDSchemaImpl.java:3117)
at org.eclipse.xsd.impl.XSDIncludeImpl.handleResolvedSchema(XSDIncludeImpl.java:247)
at org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchemaDirectiveImpl.java:387)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java:1505)
at org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchemaImpl.java:2335)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDConcreteComponentImpl.java:1240)
at org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSchemaImpl.java:829)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl.java:756)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl.java:784)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1094)
at org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchemaDirectiveImpl.java:352)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:900)
at org.geotools.xml.Schemas.parse(Schemas.java:251)
at org.geotools.xml.XSD.buildSchema(XSD.java:250)
at org.geotools.xml.XSD.getSchema(XSD.java:207)
at org.geotools.xml.SchemaLocator.locateSchema(SchemaLocator.java:94)
at org.geotools.xml.Schemas.findSchemas(Schemas.java:148)
at org.geotools.data.complex.config.EmfAppSchemaReader.parse(EmfAppSchemaReader.java:104)
at org.geotools.data.complex.config.EmfAppSchemaReader.parse(EmfAppSchemaReader.java:141)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.parseGmlSchemas(AppSchemaDataAccessConfigurator.java:488)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:179)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:159)
at org.geotools.data.complex.AppSchemaDataAccessFactory.createDataStore(AppSchemaDataAccessFactory.java:93)
at org.geotools.data.complex.AppSchemaDataAccessFactory.createDataStore(AppSchemaDataAccessFactory.java:90)
at org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:96)
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:329)
... 70 more
Jul 19, 2010 3:00:55 PM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_GeoLogicUnit
INFO: WFS GetFeature&typename=gsml:GeologicUnit&featureid=gu.25699:
<ows:ExceptionReport version="1.0.0" xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>Error occurred getting features
null
null</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Tests run: 2, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 9.6 sec <<< FAILURE!
Running org.geoserver.test.SRSWfsTest
Jul 19, 2010 3:00:57 PM org.geoserver.test.SRSWfsTest testGetFeatureContent
INFO: WFS GetFeature&typename=ex:geomContainer response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-07-19T15:00:57.327-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="http://www.cgi-iugs.org/xml/GeoSciML/2" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0" xmlns:ows="http://www.opengis.net/ows"
xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:wfs="http://www.opengis.net/wfs"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock25007data/featureTypes/ex_geomContainer/NestedGeometry.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:geomContainer gml:id="1">
<ex:geom>
<gml:Polygon srsName="urn:x-ogc:def:crs:EPSG:4283">
<gml:exterior>
<gml:LinearRing>
<gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.2">
<ex:geom>
<gml:Point srsName="urn:x-ogc:def:crs:EPSG:4283">
<gml:pos>42.58 31.29</gml:pos>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
</gml:featureMember>
<gml:featureMember>
<ex:geomContainer gml:id="2">
<ex:geom>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.1">
<ex:geom>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
</wfs:FeatureCollection>
Jul 19, 2010 3:00:57 PM org.geoserver.test.SRSWfsTest testReproject
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326 response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-07-19T15:00:57.955-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
<gml:featureMember>
<ex:geom>
<gml:exterior>
<gml:LinearRing>
<gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
<gml:pos>42.58000004047607 31.29</gml:pos>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
<gml:featureMember>
<ex:geom>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
Jul 19, 2010 3:00:58 PM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-07-19T15:00:58.027-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
<gml:featureMember>
<ex:geom>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.245 sec
Results :
Failed tests:
testGetFeature(org.geoserver.test.DataAccessIntegrationWfsTest)
testGetFeatureContent(org.geoserver.test.DataAccessIntegrationWfsTest)
testDescribeFeatureType(org.geoserver.test.DataAccessIntegrationWfsTest)
testAttributeMinOccur0(org.geoserver.test.ValidationTest)
testPolymorphism(org.geoserver.test.PolymorphismWfsTest)
testFirstValueFilters(org.geoserver.test.PolymorphismWfsTest)
testSecondValueFilters(org.geoserver.test.PolymorphismWfsTest)
testAnyTypeFilters(org.geoserver.test.PolymorphismWfsTest)
testMappingNameFilters(org.geoserver.test.PolymorphismWfsTest)
testGetCapabilities(org.geoserver.test.DuplicatePropertiesWfsTest)
testGetFeature(org.geoserver.test.DuplicatePropertiesWfsTest)
testGetCapabilities(org.geoserver.test.FeatureChainingWfsTest)
testGetFeature(org.geoserver.test.FeatureChainingWfsTest)
testGetFeatureContent(org.geoserver.test.FeatureChainingWfsTest)
testDescribeFeatureType(org.geoserver.test.FeatureChainingWfsTest)
testGetFeatureWithMappingName(org.geoserver.test.FeatureChainingWfsTest)
testGetFeaturePropertyFilter(org.geoserver.test.FeatureChainingWfsTest)
testGetFeatureWithFeatureIdFilter(org.geoserver.test.FeatureChainingWfsTest)
testGetFeatureWithGmlObjectIdFilter(org.geoserver.test.FeatureChainingWfsTest)
testAnyType(org.geoserver.test.FeatureChainingWfsTest)
testFilteringXlinkHref(org.geoserver.test.FeatureChainingWfsTest)
testFilteringNestedMultiValuedAttribute(org.geoserver.test.FeatureChainingWfsTest)
testDenormalisedFeaturesCount(org.geoserver.test.FeatureChainingWfsTest)
testEncodeFeatureMember(org.geoserver.test.FeatureChainingWfsTest)
testEncodeFeatureMembers(org.geoserver.test.FeatureChainingWfsTest)
testPropertyEncodingOrder_PlanarOrientation(org.geoserver.test.PropertyEncodingOrderTest)
testPropertyEncodingOrder_GeoLogicUnit(org.geoserver.test.PropertyEncodingOrderTest)
Tests run: 44, Failures: 27, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 8 minutes 39 seconds
[INFO] Finished at: Mon Jul 19 15:00:58 EDT 2010
[INFO] Final Memory: 54M/142M
