See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3022/changes>
Changes:
[bencaradocdavies] Ported app-schema tests to use published schemas GeoSciML 2.0 and EarthResourceML 1.1 (in maven artifacts)
[...truncated 26005 lines...]
<gml:LinearRing>
<gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.2">
<ex:geom>
<gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:pos>42.58000004047607 31.29</gml:pos>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
</gml:featureMember>
<gml:featureMember>
<ex:geomContainer gml:id="2">
<ex:geom>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.1">
<ex:geom>
<gml:Polygon srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
</wfs:FeatureCollection>
Aug 3, 2010 3:55:22 AM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-08-03T03:55:22.266Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0" xmlns:ows="http://www.opengis.net/ows"
xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:wfs="http://www.opengis.net/wfs"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock8960335569950833056data/featureTypes/ex_geomContainer/NestedGeometry.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:geomContainer gml:id="1">
<ex:geom>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.603 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Aug 3, 2010 3:55:24 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_PlanarOrientation
INFO: WFS GetFeature&er:MineralOccurrence:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-08-03T03:55:23.972Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:er="urn:cgi:xmlns:GGIC:EarthResource:1.1"
xmlns:gml="http://www.opengis.net/gml" xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0"
xmlns:ows="http://www.opengis.net/ows" xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1"
xmlns:wfs="http://www.opengis.net/wfs" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:cgi:xmlns:GGIC:EarthResource:1.1 http://www.earthresourceml.org/earthresourceml/1.1/xsd/earthResource.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<er:MineralOccurrence gml:id="er.mineraloccurrence.S0032895">
<gml:name>Robinson Range - Deposit D</gml:name>
<er:planarOrientation>
<gsml:CGI_PlanarOrientation>
<gsml:convention>strike dip right hand rule</gsml:convention>
<gsml:azimuth>
<gsml:CGI_NumericValue>
<gsml:principalValue uom="urn:ogc:def:uom:UCUM::deg">50.0</gsml:principalValue>
</gsml:CGI_NumericValue>
</gsml:azimuth>
<gsml:dip>
<gsml:CGI_TermValue>
<gsml:value codeSpace="http://www.dmp.wa.gov.au/371.aspx">60\-80</gsml:value>
</gsml:CGI_TermValue>
</gsml:dip>
<gsml:polarity>not applicable</gsml:polarity>
</gsml:CGI_PlanarOrientation>
</er:planarOrientation>
</er:MineralOccurrence>
03 Aug 03:55:25 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Error occurred getting features
at org.geoserver.wfs.GetFeature.run(GetFeature.java:398)
at org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:115)
at sun.reflect.GeneratedMethodAccessor101.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:52)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy10.getFeature(Unknown Source)
at sun.reflect.GeneratedMethodAccessor100.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:648)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1080)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1099)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1040)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:468)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:449)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:723)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:685)
at org.geoserver.test.AbstractAppSchemaWfsTestSupport.getAsDOM(AbstractAppSchemaWfsTestSupport.java:144)
at org.geoserver.test.PropertyEncodingOrderTest.testPropertyEncodingOrder_GeologicUnit(PropertyEncodingOrderTest.java:93)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: java.io.IOException
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:362)
at org.geoserver.catalog.ResourcePool.getFeatureSource(ResourcePool.java:798)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureSource(FeatureTypeInfoImpl.java:91)
at sun.reflect.GeneratedMethodAccessor103.invoke(Unknown Source)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:144)
at $Proxy11.getFeatureSource(Unknown Source)
at org.geoserver.wfs.GetFeature.run(GetFeature.java:171)
... 62 more
Caused by: java.lang.RuntimeException: Failed to resolve http://schemas.opengis.net/GeoSciML/geosciml.xsd
at org.geotools.xml.AppSchemaResolver.resolve(AppSchemaResolver.java:133)
at org.geotools.data.complex.config.EmfAppSchemaReader.findSchemaNamespace(EmfAppSchemaReader.java:155)
at org.geotools.data.complex.config.EmfAppSchemaReader.parse(EmfAppSchemaReader.java:125)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.parseGmlSchemas(AppSchemaDataAccessConfigurator.java:488)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:179)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:159)
at org.geotools.data.complex.AppSchemaDataAccessFactory.createDataStore(AppSchemaDataAccessFactory.java:93)
at org.geotools.data.complex.AppSchemaDataAccessFactory.createDataStore(AppSchemaDataAccessFactory.java:90)
at org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:96)
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:329)
... 70 more
Aug 3, 2010 3:55:25 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_GeologicUnit
INFO: WFS GetFeature&typename=gsml:GeologicUnit&featureid=gu.25699:
<ows:ExceptionReport version="1.0.0" xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>Error occurred getting features
null
Failed to resolve http://schemas.opengis.net/GeoSciML/geosciml.xsd</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 3.29 sec <<< FAILURE!
Results :
Failed tests:
testDescribeFeatureType(org.geoserver.test.DataAccessIntegrationWfsTest)
testGetFeature(org.geoserver.test.DataAccessIntegrationWfsTest)
testGetFeatureContent(org.geoserver.test.DataAccessIntegrationWfsTest)
testPolymorphism(org.geoserver.test.PolymorphismWfsTest)
testFirstValueFilters(org.geoserver.test.PolymorphismWfsTest)
testSecondValueFilters(org.geoserver.test.PolymorphismWfsTest)
testAnyTypeFilters(org.geoserver.test.PolymorphismWfsTest)
testMappingNameFilters(org.geoserver.test.PolymorphismWfsTest)
testGetCapabilities(org.geoserver.test.FeatureChainingWfsTest)
testDescribeFeatureType(org.geoserver.test.FeatureChainingWfsTest)
testGetFeature(org.geoserver.test.FeatureChainingWfsTest)
testGetFeatureContent(org.geoserver.test.FeatureChainingWfsTest)
testGetFeatureWithMappingName(org.geoserver.test.FeatureChainingWfsTest)
testGetFeaturePropertyFilter(org.geoserver.test.FeatureChainingWfsTest)
testGetFeatureWithFeatureIdFilter(org.geoserver.test.FeatureChainingWfsTest)
testGetFeatureWithGmlObjectIdFilter(org.geoserver.test.FeatureChainingWfsTest)
testAnyType(org.geoserver.test.FeatureChainingWfsTest)
testFilteringXlinkHref(org.geoserver.test.FeatureChainingWfsTest)
testFilteringNestedMultiValuedAttribute(org.geoserver.test.FeatureChainingWfsTest)
testDenormalisedFeaturesCount(org.geoserver.test.FeatureChainingWfsTest)
testEncodeFeatureMember(org.geoserver.test.FeatureChainingWfsTest)
testEncodeFeatureMembers(org.geoserver.test.FeatureChainingWfsTest)
testPropertyEncodingOrder_GeologicUnit(org.geoserver.test.PropertyEncodingOrderTest)
Tests run: 45, Failures: 23, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 5 minutes 56 seconds
[INFO] Finished at: Tue Aug 03 03:55:25 UTC 2010
[INFO] Final Memory: 65M/277M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
