See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3149/changes>
Changes:
[riniangreani] - app-schema: enable gml:id encoding in Geometry
- app-schema: srsName doesn't appear for nested geometry that is mapped inline
[...truncated 29511 lines...]
<ex:fourthValue xlink:href="urn:ogc:def:nil:OGC::missing"/>
<ex:anyValue xlink:href="urn:numeric-value::0"/>
</ex:PolymorphicFeature>
</gml:featureMember>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f4">
<ex:thirdValue>
<gsml:CGI_NumericValue>
<gsml:principalValue uom="m">1.0</gsml:principalValue>
</gsml:CGI_NumericValue>
</ex:thirdValue>
<ex:anyValue xlink:href="urn:ogc:def:nil:OGC::missing"/>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f5">
<ex:firstValue xlink:href="urn:value::y"/>
<ex:secondValue>
<gsml:CGI_TermValue>
<gsml:value>0</gsml:value>
</gsml:CGI_TermValue>
</ex:secondValue>
<ex:thirdValue>
<gsml:value codeSpace="some:uri">y</gsml:value>
</ex:thirdValue>
<ex:anyValue>
</ex:anyValue>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f6">
<ex:secondValue>
<gsml:value>1000</gsml:value>
</ex:secondValue>
<ex:thirdValue>
<gsml:principalValue uom="m">1000.0</gsml:principalValue>
</ex:thirdValue>
<ex:fourthValue>
</ex:fourthValue>
</wfs:FeatureCollection>
Sep 6, 2010 9:27:53 AM org.geoserver.test.PolymorphismWfsTest testFirstValueFilters
INFO: WFS filter GetFeature response:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-09-06T09:27:53.034Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0" xmlns:ows="http://www.opengis.net/ows"
xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:wfs="http://www.opengis.net/wfs"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock5702661124005586448data/featureTypes/ex_PolymorphicFeature/polymorphism.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f1">
<ex:firstValue>
</ex:firstValue>
<ex:secondValue>
</ex:secondValue>
<ex:thirdValue>
</ex:thirdValue>
<ex:anyValue xlink:href="urn:numeric-value::1"/>
Sep 6, 2010 9:27:53 AM org.geoserver.test.PolymorphismWfsTest testSecondValueFilters
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-09-06T09:27:53.077Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
<gml:featureMember>
<ex:firstValue>
</ex:firstValue>
<ex:secondValue>
</ex:secondValue>
<ex:thirdValue>
</ex:thirdValue>
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f3">
<ex:secondValue>
<gsml:principalValue uom="m">0.0</gsml:principalValue>
</ex:secondValue>
<ex:thirdValue>
</ex:thirdValue>
Sep 6, 2010 9:27:53 AM org.geoserver.test.PolymorphismWfsTest testAnyTypeFilters
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-09-06T09:27:53.114Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
<gml:featureMember>
<ex:PolymorphicFeature gml:id="f2">
<ex:firstValue xlink:href="urn:value::x"/>
<ex:secondValue>
</ex:secondValue>
<ex:thirdValue>
<gsml:value codeSpace="some:uri">x</gsml:value>
</ex:thirdValue>
<ex:anyValue>
</ex:anyValue>
<gml:featureMember>
<ex:secondValue>
</ex:secondValue>
<ex:thirdValue>
</ex:thirdValue>
<ex:anyValue>
</ex:anyValue>
Sep 6, 2010 9:27:53 AM org.geoserver.test.PolymorphismWfsTest testMappingNameFilters
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-09-06T09:27:53.152Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
<gml:featureMember>
<ex:firstValue>
</ex:firstValue>
<ex:secondValue>
</ex:secondValue>
<ex:thirdValue>
</ex:thirdValue>
<gml:featureMember>
<ex:thirdValue>
</ex:thirdValue>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.066 sec
Results :
Failed tests:
testGetFeatureContent(org.geoserver.test.SRSWfsTest)
testReproject(org.geoserver.test.SRSWfsTest)
Tests run: 50, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 8 minutes 12 seconds
[INFO] Finished at: Mon Sep 06 09:27:53 UTC 2010
[INFO] Final Memory: 60M/242M
Failed to send e-mail to riniangreani because no e-mail address is known, and no default e-mail domain is configured
