[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3156
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3156/changes&gt;
Changes:
[aaime] Fixing feature building in the clip process
[...truncated 33271 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.248 sec
Running org.geoserver.catalog.rest.CoverageStoreFileUploadTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.168 sec
Running org.geoserver.catalog.rest.LayerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.76 sec
Running org.geoserver.catalog.rest.StyleTest
10 Sep 09:26:11 ERROR [geoserver.rest] - Can't delete style referenced by existing layers.
org.geoserver.rest.RestletException
  at org.geoserver.catalog.rest.StyleResource.handleObjectDelete(StyleResource.java:210)
  at org.geoserver.rest.ReflectiveResource.handleDelete(ReflectiveResource.java:216)
  at org.restlet.Finder.handle(Finder.java:300)
  at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
  at org.restlet.Filter.doHandle(Filter.java:105)
  at org.restlet.Filter.handle(Filter.java:134)
  at org.restlet.Router.handle(Router.java:444)
  at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
  at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:77)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doDelete(FrameworkServlet.java:531)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1080)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1099)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1040)
  at org.geoserver.test.GeoServerAbstractTestSupport.deleteAsServletResponse(GeoServerAbstractTestSupport.java:667)
  at org.geoserver.catalog.rest.StyleTest.testDeleteWithLayerReference(StyleTest.java:167)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.585 sec
Results :
Tests run: 178, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/restconfig/target/restconfig-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/restconfig/target/restconfig-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/restconfig/target/restconfig-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/restconfig/target/restconfig-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/restconfig/2.1-SNAPSHOT/restconfig-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/restconfig/target/restconfig-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/restconfig/2.1-SNAPSHOT/restconfig-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/restconfig/target/restconfig-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/restconfig/2.1-SNAPSHOT/restconfig-2.1-SNAPSHOT-sources.jar
[INFO] Building Feature Generalization Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target&gt;
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/src/main/resources&gt;
[INFO] snapshot org.geotools:gt-feature-pregeneralized:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-feature-pregeneralized:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/src/test/java&gt;
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-sources.jar
[INFO] Building Image Mosaic JDBC Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/src/main/resources&gt;
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/src/test/java&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target&gt;
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/src/main/resources&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/classes&gt;
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/surefire-reports&gt;
T E S T S
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.046 sec
Running org.geoserver.flow.controller.UserFlowControllerTest
Thread[Thread-1,5,main] calling requestIncoming
Thread[Thread-1,5,main] waiting
Thread[Thread-1,5,main] calling requestComplete
Thread[Thread-1,5,main] done
Thread[Thread-2,5,main] calling requestIncoming
Thread[Thread-2,5,main] waiting
Thread[Thread-3,5,main] calling requestIncoming
Thread[Thread-2,5,main] calling requestComplete
Thread[Thread-2,5,main] done
Thread[Thread-3,5,main] waiting
Thread[Thread-3,5,main] calling requestComplete
Thread[Thread-3,5,main] done
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.917 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-4,5,main] calling requestIncoming
Thread[Thread-4,5,main] waiting
Thread[Thread-5,5,main] calling requestIncoming
Thread[Thread-4,5,main] calling requestComplete
Thread[Thread-4,5,main] done
Thread[Thread-6,5,main] calling requestIncoming
Thread[Thread-6,5,main] waiting
Thread[Thread-7,5,main] calling requestIncoming
Thread[Thread-8,5,main] calling requestIncoming
Thread[Thread-6,5,main] calling requestComplete
Thread[Thread-6,5,main] done
Thread[Thread-7,5,main] waiting
Thread[Thread-7,5,main] calling requestComplete
Thread[Thread-7,5,main] done
Thread[Thread-8,5,main] waiting
Thread[Thread-8,5,main] calling requestComplete
Thread[Thread-8,5,main] done
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.752 sec <<< FAILURE!
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.942 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Results :
Failed tests:
  testTimeout(org.geoserver.flow.controller.GlobalFlowControllerTest)
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/control-flow/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 9 minutes 7 seconds
[INFO] Finished at: Fri Sep 10 09:26:57 UTC 2010
[INFO] Final Memory: 65M/199M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3157/&gt;
