[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3181
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3181/&gt;
[...truncated 16265 lines...]
                        <ogc:FunctionName nArgs="2">union</ogc:FunctionName>
                        <ogc:FunctionName nArgs="2">UniqueInterval</ogc:FunctionName>
                        <ogc:FunctionName nArgs="1">vertices</ogc:FunctionName>
                        <ogc:FunctionName nArgs="0">Vocab</ogc:FunctionName>
                        <ogc:FunctionName nArgs="2">within</ogc:FunctionName>
                    </ogc:FunctionNames>
                </ogc:Functions>
            </ogc:ArithmeticOperators>
        </ogc:Scalar_Capabilities>
        <ogc:Id_Capabilities>
            <ogc:FID/>
            <ogc:EID/>
        </ogc:Id_Capabilities>
    </ogc:Filter_Capabilities>
</wfs:WFS_Capabilities>
Sep 22, 2010 2:58:20 AM org.geoserver.test.SampleDataAccessWfsTest testDescribeFeatureType
INFO: WFS DescribeFeatureType response:
<xsd:schema elementFormDefault="qualified"
    targetNamespace="http://www.example.org/sample-data-access/GeoSciML-lite&quot;
    xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="http://www.example.org/sample-data-access/GeoSciML-lite&quot; xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot;&gt;
    <xsd:import namespace="http://www.opengis.net/gml&quot; schemaLocation="http://localhost:8080/geoserver/schemas/gml/3.1.1/base/gml.xsd&quot;/&gt;
    <xsd:complexType name="MappedFeatureType">
        <xsd:complexContent>
            <xsd:extension base="gml:AbstractFeatureType">
                <xsd:sequence>
                    <xsd:element maxOccurs="1" minOccurs="0"
                        name="specification" nillable="false" type="gml:FeaturePropertyType"/>
                    <xsd:element maxOccurs="1" minOccurs="1"
                        name="shape" nillable="false" type="gml:GeometryPropertyType"/>
                </xsd:sequence>
            </xsd:extension>
        </xsd:complexContent>
    </xsd:complexType>
    <xsd:element name="MappedFeature" substitutionGroup="gml:_Feature" type="gsml:MappedFeatureType"/>
</xsd:schema>
Sep 22, 2010 2:58:20 AM org.geoserver.test.SampleDataAccessWfsTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2"
    timeStamp="2010-09-22T02:58:20.088Z"
    xmlns:ogc="http://www.opengis.net/ogc&quot;
    xmlns:ows="http://www.opengis.net/ows&quot;
    xmlns:wfs="http://www.opengis.net/wfs&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.example.org/sample-data-access/GeoSciML-lite http://localhost:8080/geoserver/wfs?service=WFS&amp;version=1.1.0&amp;request=DescribeFeatureType&amp;typeName=gsml%3AMappedFeature http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMembers>
        <gsml:MappedFeature gml:id="mf1">
            <gml:description>GUNTHORPE FORMATION</gml:description>
            <gsml:specification>
                <gsml:GeologicUnit gml:id="mf1.spec">
                    <gml:description>Gunthorpe specification description</gml:description>
                </gsml:GeologicUnit>
            </gsml:specification>
            <gsml:shape>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </gsml:shape>
        </gsml:MappedFeature>
        <gsml:MappedFeature gml:id="mf2">
            <gml:description>MERCIA MUDSTONE GROUP</gml:description>
                <gsml:GeologicUnit gml:id="mf2.spec">
                    <gml:description>Mercia specification description</gml:description>
            <gsml:shape>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.3 52.5 -1.3 52.6 -1.2 52.6 -1.2 52.5 -1.3 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </gsml:shape>
    </gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.308 sec
Results :
Downloading: http://repo.opengeo.org//org/geotools/gt-metadata/2.7-SNAPSHOT/gt-metadata-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/2.7-SNAPSHOT/gt-coverage-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-property/2.7-SNAPSHOT/gt-property-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-render/2.7-SNAPSHOT/gt-render-2.7-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.1-SNAPSHOT/sample-data-access-test-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.1-SNAPSHOT/sample-data-access-test-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/sample-data-access-test/target/sample-data-access-test-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/sample-data-access-test/2.1-SNAPSHOT/sample-data-access-test-2.1-SNAPSHOT-sources.jar
[INFO] Building ArcSDE DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target&gt;
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/src/main/resources&gt;
[INFO] snapshot org.geotools:gt-arcsde-common:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde-common:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:arcsde-plugin:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:arcsde-plugin:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcsde:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-sde-dummy:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sde-dummy:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-sde-dummy/2.7-SNAPSHOT/gt-sde-dummy-2.7-SNAPSHOT.pom
Downloading: http://repo.opengeo.org//org/geotools/gt-sde-dummy/2.7-SNAPSHOT/gt-sde-dummy-2.7-SNAPSHOT.jar
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.data.store.arcsde.ArcSDECoverageStoreEditPanelTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.817 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.1-SNAPSHOT/arcsde-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.1-SNAPSHOT/arcsde-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.1-SNAPSHOT/arcsde-2.1-SNAPSHOT-sources.jar
[INFO] Building GeoSearch Index Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target&gt;
[INFO] Copying 7 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/src/main/resources&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/src/main/java/org/geoserver/geosearch/HTMLFeatureDescription.java&gt;:\[12,46\] package org.geoserver.wms.response.featureinfo does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/src/main/java/org/geoserver/geosearch/FeatureRestlet.java&gt;:\[22,29\] cannot find symbol
symbol : class GetMapKvpRequestReader
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/src/main/java/org/geoserver/geosearch/FeatureRestlet.java&gt;:\[23,34\] package org.geoserver.wms.response does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/src/main/java/org/geoserver/geosearch/HTMLFeatureDescription.java&gt;:\[45,8\] cannot find symbol
symbol : class FeatureTemplate
location: class org.geoserver.geosearch.HTMLFeatureDescription
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/src/main/java/org/geoserver/geosearch/HTMLFeatureDescription.java&gt;:\[45,32\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/src/main/java/org/geoserver/geosearch/FeatureRestlet.java&gt;:\[177,12\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/src/main/java/org/geoserver/geosearch/FeatureRestlet.java&gt;:\[177,48\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/geosearch/src/main/java/org/geoserver/geosearch/FeatureRestlet.java&gt;:\[189,18\] cannot find symbol
symbol : class GetMapResponse
[INFO] Total time: 6 minutes 45 seconds
[INFO] Finished at: Wed Sep 22 02:58:32 UTC 2010
[INFO] Final Memory: 66M/242M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3182/changes&gt;
