See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3207/changes>
Changes:
[jdeolive] adding h2 console to h2 extension
[jdeolive] GEOS-4150, adding tools section to ui
[jdeolive] added community release artifact for python extension
[jdeolive] updated python module based on recent wms changes, some minor tweaks to filter function loading, and process output parameters
Started by an SCM change
Updating https://svn.codehaus.org/geoserver/trunk/src
U community/release/pom.xml
A community/release/ext-python.xml
U community/python/src/test/java/org/geoserver/python/format/PythonMapFormatAdapterTest.java
U community/python/src/main/java/applicationContext.xml
U community/python/src/main/java/org/geoserver/python/filter/PythonFilterFunctionFactory.java
U community/python/src/main/java/org/geoserver/python/format/PythonGetFeatureInfoOutputFormat.java
U community/python/src/main/java/org/geoserver/python/format/PythonVectorGetMapOutputFormatProvider.java
U community/python/src/main/java/org/geoserver/python/format/PythonMapGetMapOutputFormat.java
A community/python/src/main/java/org/geoserver/python/format/PythonGetMapResponseProvider.java
U community/python/src/main/java/org/geoserver/python/format/PythonGetMapOutputFormat.java
A community/python/src/main/java/org/geoserver/python/format/PythonWebMap.java
U community/python/src/main/java/org/geoserver/python/format/PythonVectorFormatAdapter.java
U community/python/src/main/java/org/geoserver/python/format/PythonGetFeatureInfoOutputFormatProvider.java
U community/python/src/main/java/org/geoserver/python/format/PythonMapGetMapOutputFormatProvider.java
U community/python/src/main/java/org/geoserver/python/format/PythonGetMapOutputFormatProvider.java
U community/python/src/main/java/org/geoserver/python/format/PythonMapFormatAdapter.java
U community/python/src/main/java/org/geoserver/python/format/PythonVectorGetMapOutputFormat.java
A community/python/src/main/java/org/geoserver/python/format/PythonGetMapResponse.java
U community/python/src/main/java/org/geoserver/python/process/PythonProcessAdapter.java
U community/python/pom.xml
U community/python
U community/pom.xml
A extension/h2/src/main/java/GeoServerApplication.properties
U extension/h2/src/main/java/applicationContext.xml
U extension/h2/pom.xml
U web/core/src/main/java/GeoServerApplication.properties
U web/core/src/main/java/GeoServerApplication_es.properties
U web/core/src/main/java/GeoServerApplication_fr.properties
U web/core/src/main/java/applicationContext.xml
A web/core/src/main/java/org/geoserver/web/ToolLinkInfo.java
A web/core/src/main/java/org/geoserver/web/ToolPage.java
U web/core/src/main/java/org/geoserver/web/MenuPageInfo.java
A web/core/src/main/java/org/geoserver/web/ComponentAuthorizer.java
A web/core/src/main/java/org/geoserver/web/AdminComponentAuthorizer.java
U web/core/src/main/java/org/geoserver/web/PageAuthorizer.java
A web/core/src/main/java/org/geoserver/web/ToolLinkExternalInfo.java
A web/core/src/main/java/org/geoserver/web/AllowComponentAuthorizer.java
U web/core/src/main/java/org/geoserver/web/ComponentInfo.java
U web/core/src/main/java/org/geoserver/web/GeoServerBasePage.java
A web/core/src/main/java/org/geoserver/web/ToolPage.html
U web/core/src/main/java/org/geoserver/web/DefaultPageAuthorizer.java
U web/core/src/main/java/GeoServerApplication_de.properties
Fetching 'https://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/minimal’>
At revision 14949
Fetching 'https://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/legacy/web/minimal’>
At revision 14949
Fetching 'https://svn.codehaus.org/geoserver/trunk/src/web/core/src/main/java/org/geoserver/web/css’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/src/test/java/org/geoserver/wicket/test/css’>
At revision 14949
Fetching 'https://svn.codehaus.org/geoserver/trunk/src/web/core/src/main/java/org/geoserver/web/img’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/app/src/test/java/org/geoserver/wicket/test/img’>
At revision 14949
At revision 14949
no change for https://svn.codehaus.org/geoserver/trunk/data/minimal since the previous build
no change for https://svn.codehaus.org/geoserver/trunk/src/web/core/src/main/java/org/geoserver/web/css since the previous build
no change for https://svn.codehaus.org/geoserver/trunk/src/web/core/src/main/java/org/geoserver/web/img since the previous build
[geoserver] $ mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,proxy,printing clean install
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geoserver.extension:h2
POM Location: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/pom.xml>
Validation Messages:
[0] 'dependencies.dependency.version' is missing for org.geoserver.web:web-core:jar
Reason: Failed to validate POM for project org.geoserver.extension:h2 at <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/pom.xml>
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Failed to validate POM for project org.geoserver.extension:h2 at <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/pom.xml>
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:404)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:272)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:138)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:362)
at org.apache.maven.cli.compat.CompatibleMain.main(CompatibleMain.java:60)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Failed to validate POM for project org.geoserver.extension:h2 at <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/pom.xml>
at org.apache.maven.project.DefaultMavenProjectBuilder.processProjectLogic(DefaultMavenProjectBuilder.java:1077)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildInternal(DefaultMavenProjectBuilder.java:880)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMavenProjectBuilder.java:508)
at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java:200)
at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:604)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:487)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:560)
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:391)
... 12 more
[INFO] Total time: 1 second
[INFO] Finished at: Thu Oct 07 18:38:31 UTC 2010
[INFO] Final Memory: 7M/158M
