See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/324/changes
Changes:
[aaime] Fixing class names (this is an edit/remove component, not an add/remove one)
[...truncated 5940 lines...]
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor155.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
26 Jun 13:52:32 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Jun 26 13:52:32 EDT 2008]; root of context hierarchy
26 Jun 13:52:32 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
26 Jun 13:52:32 INFO [geoserver.global] - Done disposing datastores.
26 Jun 13:52:32 INFO [geoserver.catalog] - Disposing datastore 'cgf'
26 Jun 13:52:32 INFO [geoserver.catalog] - Disposing datastore 'cdf'
26 Jun 13:52:32 INFO [geoserver.catalog] - Disposing datastore 'cite'
26 Jun 13:52:32 INFO [geoserver.catalog] - Disposing datastore 'sf'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.264 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
here
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
26 Jun 13:52:32 INFO [geoserver.wfs] -
Request: describeFeatureType
handle = null
service = WFS
version = 1.1.0
baseUrl = http://localhost:80/geoserver/
typeName = [{http://cite.opengeospatial.org/gmlsf\}PrimitiveGeoFeature]
outputFormat = text/xml; subtype=gml/3.1.1
handle = null
service = WFS
version = 1.1.0
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.304 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
here
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.168 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
here
26 Jun 13:52:33 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Jun 26 13:52:32 EDT 2008]; root of context hierarchy
26 Jun 13:52:33 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
26 Jun 13:52:33 INFO [geoserver.global] - Done disposing datastores.
26 Jun 13:52:33 INFO [geoserver.catalog] - Disposing datastore 'cite'
26 Jun 13:52:33 INFO [geoserver.catalog] - Disposing datastore 'cgf'
26 Jun 13:52:33 INFO [geoserver.catalog] - Disposing datastore 'cdf'
26 Jun 13:52:33 INFO [geoserver.catalog] - Disposing datastore 'sf'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.796 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
here
Feature type cite:InvalidTypeName unknown
26 Jun 13:52:33 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Jun 26 13:52:33 EDT 2008]; root of context hierarchy
here
Feature type gs:InvalidTypeName unknown
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.3 sec
Running org.geoserver.wfs.response.ShapeZipTest
here
26 Jun 13:52:34 INFO [test.GeoServerTestApplicationContext] - Closing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Thu Jun 26 13:52:34 EDT 2008]; root of context hierarchy
26 Jun 13:52:34 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown...
26 Jun 13:52:34 INFO [geoserver.global] - Done disposing datastores.
26 Jun 13:52:34 INFO [geoserver.catalog] - Disposing datastore 'cgf'
26 Jun 13:52:34 INFO [geoserver.catalog] - Disposing datastore 'cdf'
26 Jun 13:52:34 INFO [geoserver.catalog] - Disposing datastore 'sf'
26 Jun 13:52:34 INFO [geoserver.catalog] - Disposing datastore 'cite'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.2 sec
Running org.geoserver.wfs.GetCapabilitiesTest
here
26 Jun 13:52:34 INFO [geoserver.wfs] -
Request: getCapabilities
acceptVersions = null
sections = null
acceptFormats = null
updateSequence = null
service = WFS
acceptVersions:
version = [1.0.0]
sections = null
service = WFS
acceptVersions:
version = [1.0.0]
sections = null
service = WFS
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.308 sec
Results :
Tests run: 136, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.8.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.8.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.8.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.8.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.8.0-SNAPSHOT/wfs-1.8.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.8.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.8.0-SNAPSHOT/wfs-1.8.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.8.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.8.0-SNAPSHOT/wfs-1.8.0-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 47 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 5 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/surefire-reports
T E S T S
Running org.geoserver.wfsv.HistoryRelatedTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.316 sec <<< FAILURE!
Running org.geoserver.wfsv.LogOrderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.028 sec <<< FAILURE!
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
Running org.geoserver.wfsv.RollbackTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.056 sec <<< FAILURE!
Results :
Tests in error:
testRollbackWfs11(org.geoserver.wfsv.RollbackTest)
testRollbackWfs10(org.geoserver.wfsv.RollbackTest)
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 14 seconds
[INFO] Finished at: Thu Jun 26 13:52:40 EDT 2008
[INFO] Final Memory: 30M/63M
