[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3269
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3269/changes&gt;
Changes:
[riniangreani] GEOT-3304: App-schema: client properties not encoded correctly with polymorphism
[...truncated 15881 lines...]
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at java.lang.reflect.Method.invoke(Method.java:592)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: java.lang.IllegalArgumentException: gsml:CGI_TermValue is not a valid location path for type urn:cgi:xmlns:CGI:GeoSciML:2.0:CGI_ValuePropertyType. gsml:CGI_TermValue ns: urn:cgi:xmlns:CGI:GeoSciML:2.0, CGI_ValuePropertyType properties: urn:cgi:xmlns:CGI:GeoSciML:2.0#CGI_Value
  at org.geotools.data.complex.filter.XPath.set(XPath.java:679)
  at org.geotools.data.complex.filter.XPath.set(XPath.java:553)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.setAttributeValue(DataAccessMappingFeatureIterator.java:410)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:716)
  ... 70 more
Oct 29, 2010 7:47:21 AM org.geoserver.test.PolymorphismInlineWfsTest testGetFeature
INFO: WFS GetFeature&typename=ex:PolymorphicFeature response:
<ows:ExceptionReport version="1.0.0" xmlns:ows="http://www.opengis.net/ows&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd&quot;&gt;
    <ows:Exception exceptionCode="NoApplicableCode">
        <ows:ExceptionText>java.lang.RuntimeException: Error applying mapping with targetAttribute ex:firstValue[2]/gsml:CGI_TermValue/gsml:value
gsml:CGI_TermValue is not a valid location path for type urn:cgi:xmlns:CGI:GeoSciML:2.0:CGI_ValuePropertyType. gsml:CGI_TermValue ns: urn:cgi:xmlns:CGI:GeoSciML:2.0, CGI_ValuePropertyType properties: urn:cgi:xmlns:CGI:GeoSciML:2.0#CGI_Value</ows:ExceptionText>
    </ows:Exception>
</ows:ExceptionReport>
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.136 sec <<< FAILURE!
Running org.geoserver.test.MappingNameTest
Oct 29, 2010 7:47:23 AM org.geoserver.test.MappingNameTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="4" timeStamp="2010-10-29T07:47:23.557Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot; xmlns:ows="http://www.opengis.net/ows&quot;
    xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot; xmlns:wfs="http://www.opengis.net/wfs&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="urn:cgi:xmlns:CGI:GeoSciML:2.0 http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMember>
        <gsml:MappedFeature gml:id="gsml.mappedfeature.mf1">
            <gsml:observationMethod>
                <gsml:CGI_TermValue>
                    <gsml:value codeSpace="codespace01">value01</gsml:value>
                </gsml:CGI_TermValue>
            </gsml:observationMethod>
                    <gsml:value codeSpace="codespace02">value02</gsml:value>
            <gsml:shape>
                <gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
                    <gml:pos>-23.6701 133.8855</gml:pos>
                </gml:Point>
            </gsml:shape>
        </gsml:MappedFeature>
    </gml:featureMember>
    <gml:featureMember>
        <gsml:MappedFeature gml:id="gsml.mappedfeature.mf2">
                    <gsml:value codeSpace="codespace03">value03</gsml:value>
            <gsml:shape>
                    <gml:pos>-29.0434 167.9388</gml:pos>
                </gml:Point>
            </gsml:shape>
    <gml:featureMember>
        <gsml:MappedFeature gml:id="gsml.mappedfeature.mf3">
            <gsml:shape>
                    <gml:pos>-12.1883 96.8339</gml:pos>
                </gml:Point>
            </gsml:shape>
    <gml:featureMember>
        <gsml:MappedFeature gml:id="gsml.mappedfeature.mf4">
            <gsml:shape>
                    <gml:pos>-34.9502 117.8102</gml:pos>
                </gml:Point>
            </gsml:shape>
</wfs:FeatureCollection>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.862 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Oct 29, 2010 7:47:28 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_Borehole
INFO: WFS GetFeature&gsml:Borehole:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-10-29T07:47:28.311Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:er="urn:cgi:xmlns:GGIC:EarthResource:1.1"
    xmlns:gml="http://www.opengis.net/gml&quot; xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot;
    xmlns:ows="http://www.opengis.net/ows&quot; xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot;
    xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="urn:cgi:xmlns:CGI:GeoSciML:2.0 http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMember>
        <gsml:Borehole gml:id="BOREHOLE.WTB5">
            <gml:name>WTB5 TEST</gml:name>
            <sa:sampledFeature xlink:href="http://www.opengis.net/def/nil/OGC/0/unknown&quot; xlink:role="http://www.geosciml.org/geosciml/2.0/doc/GeoSciML/GeologicUnit/GeologicUnit.html&quot; xlink:title="unknown"/>
            <sa:shape>
                <gml:LineString>
                    <gml:posList>-28.4139 121.142 -28.4139 121.142</gml:posList>
                </gml:LineString>
            </sa:shape>
            <gsml:collarLocation>
                <gsml:BoreholeCollar gml:id="BOREHOLE.COLLAR.WTB5">
                    <gsml:location>
                        <gml:Point>
                            <gml:pos>-28.4139 121.142</gml:pos>
                        </gml:Point>
                    </gsml:location>
                    <gsml:elevation axisLabels="Gravity-related height" srsDimension="1" srsName="http://www.opengis.net/gml/srs/epsg.xml#5711&quot; uomLabels="m">1.0</gsml:elevation>
                </gsml:BoreholeCollar>
            </gsml:collarLocation>
            <gsml:indexData>
                <gsml:BoreholeDetails>
                    <gsml:operator xlink:href="http://www.opengis.net/def/nil/OGC/0/unknown&quot; xlink:role="http://www.geosciml.org/geosciml/2.0/doc/GeoSciML/Borehole/BoreholeDetails.html#operator&quot; xlink:title="GSWA"/>
                    <gsml:dateOfDrilling>2004-09-17</gsml:dateOfDrilling>
                    <gsml:drillingMethod>diamond core</gsml:drillingMethod>
                    <gsml:startPoint>natural ground surface</gsml:startPoint>
                    <gsml:inclinationType>vertical</gsml:inclinationType>
                    <gsml:coredInterval>
                        <gml:Envelope axisLabels="core envelope" srsDimension="1" srsName="#BOREHOLE.WTB5.LINESTRING" uomLabels="m">
                            <gml:lowerCorner>106.0</gml:lowerCorner>
                            <gml:upperCorner>249.0</gml:upperCorner>
                        </gml:Envelope>
                    </gsml:coredInterval>
                    <gsml:coreCustodian xlink:href="http://www.opengis.net/def/nil/OGC/0/unknown&quot;
                        xlink:role="http://www.geosciml.org/geosciml/2.0/doc/GeoSciML/Borehole/BoreholeDetails.html#coreCustodian&quot; xlink:title="CSIRONR"/>
                </gsml:BoreholeDetails>
            </gsml:indexData>
        </gsml:Borehole>
Oct 29, 2010 7:47:28 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_PlanarOrientation
INFO: WFS GetFeature&er:MineralOccurrence:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-10-29T07:47:28.608Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:er="urn:cgi:xmlns:GGIC:EarthResource:1.1"
    xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="urn:cgi:xmlns:GGIC:EarthResource:1.1 http://www.earthresourceml.org/earthresourceml/1.1/xsd/earthResource.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMember>
        <er:MineralOccurrence gml:id="er.mineraloccurrence.S0032895">
            <gml:name>Robinson Range - Deposit D</gml:name>
            <er:planarOrientation>
                <gsml:CGI_PlanarOrientation>
                    <gsml:convention>strike dip right hand rule</gsml:convention>
                    <gsml:azimuth>
                        <gsml:CGI_NumericValue>
                            <gsml:principalValue uom="urn:ogc:def:uom:UCUM::deg">50.0</gsml:principalValue>
                        </gsml:CGI_NumericValue>
                    </gsml:azimuth>
                    <gsml:dip>
                            <gsml:value codeSpace="http://www.dmp.wa.gov.au/371.aspx&quot;&gt;60\-80&lt;/gsml:value&gt;
                    </gsml:dip>
                    <gsml:polarity>not applicable</gsml:polarity>
                </gsml:CGI_PlanarOrientation>
            </er:planarOrientation>
        </er:MineralOccurrence>
Oct 29, 2010 7:47:28 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_GeologicUnit
INFO: WFS GetFeature&typename=gsml:GeologicUnit&featureid=gu.25699:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-10-29T07:47:28.642Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:er="urn:cgi:xmlns:GGIC:EarthResource:1.1"
    <gml:featureMember>
        <gsml:GeologicUnit gml:id="gu.25699">
            <gml:description>Olivine basalt, tuff, microgabbro, minor sedimentary rocks</gml:description>
            <gml:name codeSpace="urn:ietf:rfc:2141">Yaugher Volcanic Group</gml:name>
            <gml:name>-Py</gml:name>
                    <gsml:value codeSpace="http://urn.opengis.net">urn:ogc:def:nil:OGC::missing</gsml:value>
            <gsml:purpose>instance</gsml:purpose>
            <gsml:occurrence xlink:href="urn:cgi:feature:MappedFeature:mf1"/>
            <gsml:geologicUnitType xlink:href="urn:ogc:def:nil:OGC::unknown"/>
            <gsml:exposureColor>
                    <gsml:value codeSpace="some:uri">Blue</gsml:value>
            </gsml:exposureColor>
            <gsml:outcropCharacter>
                    <gsml:value codeSpace="some:uri">x</gsml:value>
            </gsml:outcropCharacter>
            <gsml:composition>
                <gsml:CompositionPart>
                    <gsml:role codeSpace="urn:cgi:classifierScheme:Example:CompositionPartRole">fictitious component</gsml:role>
                    <gsml:lithology>
                        <gsml:ControlledConcept gml:id="cc.5">
                            <gml:name>name_cc_5</gml:name>
                            <gsml:name xml:lang="en">name_cc_5</gsml:name>
                            <gsml:vocabulary xlink:href="urn:ogc:def:nil:OGC::missing"/>
                        </gsml:ControlledConcept>
                    </gsml:lithology>
                    <gsml:proportion>
                            <gsml:value codeSpace="some:uri">nonexistent</gsml:value>
                    </gsml:proportion>
                </gsml:CompositionPart>
            </gsml:composition>
        </gsml:GeologicUnit>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.278 sec
Results :
Failed tests:
  testPolymorphism(org.geoserver.test.PolymorphismWfsTest)
  testGetFeature(org.geoserver.test.PolymorphismInlineWfsTest)
Tests run: 56, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 6 minutes 10 seconds
[INFO] Finished at: Fri Oct 29 07:47:29 UTC 2010
[INFO] Final Memory: 66M/278M
Failed to send e-mail to riniangreani because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3270/&gt;
