[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3289
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3289/changes&gt;
Changes:
[mbarto] imagemap extension: fixed a problem with reading a PointSymbolizer Size
[...truncated 17788 lines...]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.1-SNAPSHOT/oracle-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.1-SNAPSHOT/oracle-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/oracle/target/oracle-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/oracle/2.1-SNAPSHOT/oracle-2.1-SNAPSHOT-sources.jar
[INFO] Building MySQL DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/src/main/resources&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-mysql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-mysql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/src/test/java&gt;
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/mysql/2.1-SNAPSHOT/mysql-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/mysql/2.1-SNAPSHOT/mysql-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/mysql/target/mysql-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/mysql/2.1-SNAPSHOT/mysql-2.1-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target&gt;
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/src/main/resources&gt;
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-postgis-versioned:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-postgis-versioned:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-postgis:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-postgis:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-postgis:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/geotools/gt-postgis/2.7-SNAPSHOT/gt-postgis-2.7-SNAPSHOT.pom
Downloading: http://repo.opengeo.org//org/geotools/gt-postgis/2.7-SNAPSHOT/gt-postgis-2.7-SNAPSHOT.jar
[INFO] Compiling 55 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/classes&gt;
[INFO] Copying 1 resource
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfsv.security.ReadOnlyVersioningDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.683 sec
Running org.geoserver.wfsv.HistoryRelatedTest
Nov 8, 2010 5:46:16 PM org.geoserver.data.test.LiveDbmsData disableTest
WARNING: Disabling test based on fixture wfsv since the file /home/tomcat/.geoserver/wfsv.properties could not be found
Nov 8, 2010 5:46:16 PM org.geoserver.test.GeoServerAbstractTestSupport runTest
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testValidateInvalidRequest since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetFeatureBeforeAfter since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection10Reproject since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection11Reproject since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testLog10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testLog11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testLog10Html since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Html since test data is not available
WARNING: Skipping class org.geoserver.wfsv.HistoryRelatedTest.testGetDiff11Reverse since test data is not available
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.086 sec
Running org.geoserver.wfsv.LogOrderTest
WARNING: Skipping class org.geoserver.wfsv.LogOrderTest.testLogForward since test data is not available
WARNING: Skipping class org.geoserver.wfsv.LogOrderTest.testLogBackwards since test data is not available
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testValidateInvalidRequest since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet11 since test data is not available
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.wfsv.security.ReadOnlyVersioningFeatureStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.027 sec
Running org.geoserver.wfsv.RollbackTest
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testRollbackWfs11 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testRollbackWfs10 since test data is not available
WARNING: Skipping class org.geoserver.wfsv.RollbackTest.testInvalidRollback since test data is not available
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Results :
Tests run: 27, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfsv/2.1-SNAPSHOT/wfsv-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfsv/2.1-SNAPSHOT/wfsv-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/wfsv-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfsv/2.1-SNAPSHOT/wfsv-2.1-SNAPSHOT-sources.jar
[INFO] Building DB2 DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/src/main/resources&gt;
[INFO] snapshot org.geotools.jdbc:gt-jdbc-db2:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-db2:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/src/test/java&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/db2/2.1-SNAPSHOT/db2-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/db2/2.1-SNAPSHOT/db2-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/db2/target/db2-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/db2/2.1-SNAPSHOT/db2-2.1-SNAPSHOT-sources.jar
[INFO] Building ImageMap Output Format
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target&gt;
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/src/main/resources&gt;
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/EncodeHTMLImageMap.java&gt;:\[345,22\] writeFeatures(org.geotools.data.simple.SimpleFeatureCollection,org.geotools.styling.FeatureTypeStyle) in org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapWriter cannot be applied to (org.geotools.data.simple.SimpleFeatureCollection,org.geotools.styling.Style,org.geotools.styling.FeatureTypeStyle)
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/imagemap/src/main/java/org/vfny/geoserver/wms/responses/map/htmlimagemap/HTMLImageMapWriter.java&gt;:\[667,24\] cannot find symbol
symbol : class Graphic
location: class org.vfny.geoserver.wms.responses.map.htmlimagemap.HTMLImageMapWriter.PointWriter
[INFO] Total time: 7 minutes 25 seconds
[INFO] Finished at: Mon Nov 08 17:46:19 UTC 2010
[INFO] Final Memory: 68M/243M
Failed to send e-mail to mbarto because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3290/changes&gt;
