[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3334
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3334/&gt;
[...truncated 3034 lines...]
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at java.lang.reflect.Method.invoke(Method.java:592)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.geoserver.wcs.response.Wcs10GetCapabilitiesResponse.write(Wcs10GetCapabilitiesResponse.java:45)
  ... 52 more
Caused by: org.vfny.geoserver.wcs.WcsException: WCS capabilities document is current (updateSequence = 0)
  at org.geoserver.wcs.response.Wcs10CapsTransformer$WCS100CapsTranslator.encode(Wcs10CapsTransformer.java:146)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 54 more
25 Nov 16:22:03 ERROR [geoserver.ows] -
java.io.IOException
  at org.geoserver.wcs.response.Wcs10GetCapabilitiesResponse.write(Wcs10GetCapabilitiesResponse.java:47)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:775)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:233)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1082)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1101)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1042)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:470)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:451)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:725)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:687)
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorGet(GetCapabilitiesTest.java:100)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:132)
  ... 51 more
Caused by: org.vfny.geoserver.wcs.WcsException: Invalid update sequence value, it's higher than the current value, 0
  at org.geoserver.wcs.response.Wcs10CapsTransformer$WCS100CapsTranslator.encode(Wcs10CapsTransformer.java:140)
  ... 53 more
java.io.IOException
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:655)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:602)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:582)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:791)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:774)
  at org.geoserver.wcs.GetCapabilitiesTest.testUpdateSequenceSuperiorPost(GetCapabilitiesTest.java:112)
  ... 52 more
  ... 54 more
org.vfny.geoserver.wcs.WcsException: Could not find section 'Bogus'
  at org.geoserver.wcs.kvp.SectionKvpParser.parse(SectionKvpParser.java:29)
  at org.geoserver.ows.util.KvpUtils.parse(KvpUtils.java:430)
  at org.geoserver.ows.Dispatcher.parseKVP(Dispatcher.java:1149)
  at org.geoserver.ows.Dispatcher.init(Dispatcher.java:262)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:206)
  at org.geoserver.wcs.GetCapabilitiesTest.testSectionsBogus(GetCapabilitiesTest.java:117)
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.665 sec
Results :
Failed tests:
  testLayerQualified(org.geoserver.wcs.GetCoverageTest)
  testWorkspaceQualified(org.geoserver.wcs.GetCoverageTest)
Tests in error:
  testDomainSubsetRxRy(org.geoserver.wcs.GetCoverageTest)
Tests run: 38, Failures: 2, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wcs1_0/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 1 minute 12 seconds
[INFO] Finished at: Thu Nov 25 16:22:04 UTC 2010
[INFO] Final Memory: 50M/204M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3335/changes&gt;
Changes:
[jdeolive] some README updates to cite tools
[jdeolive] updates to support wms 1.3.0 cite tests
[simboss] minor fix for component color model in raster direct path
[...truncated 3072 lines...]
  ... 52 more
  ... 54 more
25 Nov 17:39:57 ERROR [geoserver.ows] -
java.io.IOException
  ... 51 more
  ... 53 more
java.io.IOException
  ... 52 more
  ... 54 more
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.708 sec
Results :
Failed tests:
Tests in error:
[INFO] Finished at: Thu Nov 25 17:39:57 UTC 2010
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3336/&gt;
