[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3385
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3385/changes&gt;
Changes:
[jdeolive] created a request logging interceptor for non emf based request objects
[jdeolive] moved code to create a buffered xml reader capable of rewinding itself to support pre parsing to utility class
[jdeolive] moved additional search lookup logic to GeoServerResourceLoader, made createFile() capable of handling case of parent directory not existing
[...truncated 785 lines...]
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Running org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest
Tests run: 5, Failures: 0, Errors: 5, Skipped: 0, Time elapsed: 0.513 sec <<< FAILURE!
Running org.geoserver.ows.CustomManglerTest
Tests run: 2, Failures: 0, Errors: 2, Skipped: 0, Time elapsed: 0.205 sec <<< FAILURE!
Running org.geoserver.security.DefaultDataAccessManagerAuthTest
Dec 16, 2010 7:37:32 PM org.geoserver.security.DataAccessRuleDAO parseDataAccessRule
WARNING: Namespace/Workspace topp is unknown in rule topp.*.r=*
WARNING: Namespace/Workspace topp is unknown in rule topp.bases.w=MILITARY
WARNING: Layer topp is unknown in rule + topp.bases.w=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.bases.r=MILITARY
WARNING: Layer topp is unknown in rule + topp.bases.r=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.states.w=WRITER
WARNING: Layer topp is unknown in rule + topp.states.w=WRITER
WARNING: Namespace/Workspace nurc is unknown in rule nurc.arc\.grid.w=MILITARY
WARNING: Layer nurc is unknown in rule + nurc.arc\.grid.w=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.states.r=READER
WARNING: Layer topp is unknown in rule + topp.states.r=READER
WARNING: Namespace/Workspace nurc is unknown in rule nurc.arc\.grid.r=MILITARY
WARNING: Layer nurc is unknown in rule + nurc.arc\.grid.r=MILITARY
WARNING: Namespace/Workspace topp is unknown in rule topp.landmarks.w=WRITER
WARNING: Layer topp is unknown in rule + topp.landmarks.w=WRITER
Dec 16, 2010 7:37:32 PM org.geoserver.security.DataAccessRuleDAO loadRules
WARNING: Invalid security mode foobar acceptable values are [HIDE, CHALLENGE, MIXED]
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.072 sec
Running org.geoserver.config.GeoServerImplTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.security.decorators.ReadOnlyDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.logging.LegacyLoggingImporterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureSourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.033 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.063 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
16 Dec 19:37:32 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
16 Dec 19:37:32 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
16 Dec 19:37:32 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.252 sec <<< FAILURE!
Running org.geoserver.security.SecureCatalogImplTest
Dec 16, 2010 7:37:33 PM org.geoserver.security.DataAccessRuleDAO parseDataAccessRule
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.203 sec
Running org.vfny.geoserver.crs.OvverideCRSTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.035 sec <<< FAILURE!
Running org.geoserver.config.GeoServerPropertyConfigurerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.066 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.077 sec
Running org.geoserver.security.decorators.ReadOnlyDecoratorsTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.041 sec
Running org.geoserver.security.DataAccessRuleDAOTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.catalog.SchemaMappingTest
16 Dec 19:37:33 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
16 Dec 19:37:33 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
16 Dec 19:37:33 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.167 sec <<< FAILURE!
Running org.geoserver.catalog.ResourcePoolTest
Tests run: 6, Failures: 0, Errors: 6, Skipped: 0, Time elapsed: 0.422 sec <<< FAILURE!
Running org.geoserver.security.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.catalog.impl.CatalogBuilderTest
Dec 16, 2010 7:37:34 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won't be enabled.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.308 sec <<< FAILURE!
Running org.geoserver.security.DefaultDataAccessManagerTreeTest
Dec 16, 2010 7:37:35 PM org.geoserver.security.DataAccessRuleDAO parseDataAccessRule
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.security.DataAccessRuleTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.026 sec <<< FAILURE!
Running org.geoserver.security.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.012 sec <<< FAILURE!
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.01 sec <<< FAILURE!
Running org.geoserver.catalog.impl.CatalogImplTest
Tests run: 56, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.111 sec
Running org.geoserver.security.decorators.ReadOnlyFeatureCollectionTest
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
Tests run: 4, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 0.027 sec <<< FAILURE!
Results :
Tests in error:
  testCascadeLayer(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
  testCascadeStore(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
  testCascadeWorkspace(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
  testCascadeStyle(org.geoserver.catalog.impl.CascadeDeleteVisitorTest)
  testAddWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testRemoveWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testAddDataStore(org.geoserver.config.GeoServerPersisterTest)
  testRemoveDataStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyDataStore(org.geoserver.config.GeoServerPersisterTest)
  testChangeDataStoreWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testAddFeatureType(org.geoserver.config.GeoServerPersisterTest)
  testAddCoverage(org.geoserver.config.GeoServerPersisterTest)
  testAddWMSLayer(org.geoserver.config.GeoServerPersisterTest)
  testRemoveFeatureType(org.geoserver.config.GeoServerPersisterTest)
  testRemoveWMSLayer(org.geoserver.config.GeoServerPersisterTest)
  testModifyFeatureType(org.geoserver.config.GeoServerPersisterTest)
  testAddLayer(org.geoserver.config.GeoServerPersisterTest)
  testRemoveLayer(org.geoserver.config.GeoServerPersisterTest)
  testModifyLayer(org.geoserver.config.GeoServerPersisterTest)
  testAddStyle(org.geoserver.config.GeoServerPersisterTest)
  testModifyStyle(org.geoserver.config.GeoServerPersisterTest)
  testRemoveStyle(org.geoserver.config.GeoServerPersisterTest)
  testAddWMSStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyGlobal(org.geoserver.config.GeoServerPersisterTest)
  testDefaultWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testAddCoverageStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyCoverageStore(org.geoserver.config.GeoServerPersisterTest)
  testRemoveCoverageStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyCoverage(org.geoserver.config.GeoServerPersisterTest)
  testRemoveCoverage(org.geoserver.config.GeoServerPersisterTest)
  testModifyWMSStore(org.geoserver.config.GeoServerPersisterTest)
  testRemoveWMSStore(org.geoserver.config.GeoServerPersisterTest)
  testModifyWMSLayer(org.geoserver.config.GeoServerPersisterTest)
  testAddLayerGroup(org.geoserver.config.GeoServerPersisterTest)
  testModifyLayerGroup(org.geoserver.config.GeoServerPersisterTest)
  testRemoveLayerGroup(org.geoserver.config.GeoServerPersisterTest)
  test(org.geoserver.template.GeoServerTemplateLoaderTest)
  testRemoteType(org.geoserver.template.GeoServerTemplateLoaderTest)
  testContextStartup(org.geoserver.vfny.global.TolerantStartupTest)
  testMissingFeatureTypes(org.geoserver.catalog.impl.util.LegacyCatalogImporterTest)
  testMissingCoverages(org.geoserver.catalog.impl.util.LegacyCatalogImporterTest)
  testCRSPrefix(org.geoserver.catalog.impl.util.LegacyCatalogImporterTest)
  testCatalogUpdates(org.geoserver.config.UpdateSequenceListenerTest)
  testServiceUpdates(org.geoserver.config.UpdateSequenceListenerTest)
  testChangeWorkspace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeNamespace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeDefaultWorkspace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeDefaultNamespace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testChangeNamespaceURI(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
  testBasic(org.geoserver.ows.CustomManglerTest)
  testKVP(org.geoserver.ows.CustomManglerTest)
  testRemoteType(org.geoserver.template.GeoServerTemplateLoader2Test)
  testRelativeToFeatureType(org.geoserver.template.GeoServerTemplateLoader2Test)
  testRelativeToStore(org.geoserver.template.GeoServerTemplateLoader2Test)
  testRelativeToWorkspace(org.geoserver.template.GeoServerTemplateLoader2Test)
  testOverride(org.vfny.geoserver.crs.OvverideCRSTest)
  testNoMapping(org.geoserver.catalog.SchemaMappingTest)
  testXsdMapping(org.geoserver.catalog.SchemaMappingTest)
  testXmlMapping(org.geoserver.catalog.SchemaMappingTest)
  testFeatureTypeCacheInstance(org.geoserver.catalog.ResourcePoolTest)
  testAttributeCache(org.geoserver.catalog.ResourcePoolTest)
  testCacheClearing(org.geoserver.catalog.ResourcePoolTest)
  testDispose(org.geoserver.catalog.ResourcePoolTest)
  testLRU(org.geoserver.catalog.ResourcePoolTest)
  testGeoServerReload(org.geoserver.catalog.ResourcePoolTest)
  testForce(org.vfny.geoserver.ProjectionPolicyTest)
  testReproject(org.vfny.geoserver.ProjectionPolicyTest)
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest)
  testWithRename(org.vfny.geoserver.ProjectionPolicyTest)
  testFullAccess(org.geoserver.security.SecureCatalogIntegrationTest)
  testCannotRead(org.geoserver.security.SecureCatalogIntegrationTest)
  testCannotWrite(org.geoserver.security.SecureCatalogIntegrationTest)
  testProxyBase(org.geoserver.ows.URLManglersTest)
  testCascadeLayer(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeStore(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeWorkspace(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
  testCascadeStyle(org.geoserver.catalog.impl.CascadeRemovalReporterTest)
Tests run: 259, Failures: 0, Errors: 78, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 1 minute 9 seconds
[INFO] Finished at: Thu Dec 16 19:37:35 UTC 2010
[INFO] Final Memory: 53M/211M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3386/changes&gt;
