[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3407
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3407/changes&gt;
Changes:
[simboss] adding licenses
[simboss] various improvements related to rendering for the raster path
[...truncated 6994 lines...]
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1090)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1109)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1050)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:663)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:610)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:590)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:799)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:782)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:52)
  at java.lang.reflect.Method.invoke(Method.java:592)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:132)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor172.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
sf
cdf
cgf
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.25 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot; xmlns:cdf="http://www.opengis.net/cite/data&quot; xmlns:cgf="http://www.opengis.net/cite/geometry&quot; xmlns:cite="http://www.opengis.net/cite&quot; xmlns:gml="http://www.opengis.net/gml/3.2&quot; xmlns:gs="http://geoserver.org" xmlns:sf="http://cite.opengeospatial.org/gmlsf&quot; xmlns:wfs="http://www.opengis.net/wfs/2.0&quot; elementFormDefault="qualified" targetNamespace="http://www.opengis.net/cite/geometry&quot;&gt;
  <xsd:import namespace="http://www.opengis.net/wfs/2.0&quot; schemaLocation="http://localhost:8080/geoserver/schemas/gml/3.2.1/gml.xsd&quot;/&gt;
  <xsd:complexType name="PolygonsType">
    <xsd:complexContent>
      <xsd:extension base="gml:AbstractFeatureType">
        <xsd:sequence>
          <xsd:element maxOccurs="1" minOccurs="0" name="id" nillable="true" type="xsd:string"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="polygonProperty" nillable="true" type="gml:SurfacePropertyType"/>
        </xsd:sequence>
      </xsd:extension>
    </xsd:complexContent>
  </xsd:complexType>
  <xsd:element name="Polygons" substitutionGroup="gml:AbstractFeature" type="cgf:PolygonsType"/>
</xsd:schema>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot; xmlns:cdf="http://www.opengis.net/cite/data&quot; xmlns:cgf="http://www.opengis.net/cite/geometry&quot; xmlns:cite="http://www.opengis.net/cite&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:gs="http://geoserver.org" xmlns:sf="http://cite.opengeospatial.org/gmlsf&quot; elementFormDefault="qualified" targetNamespace="http://cite.opengeospatial.org/gmlsf&quot;&gt;
  <xsd:import namespace="http://www.opengis.net/gml&quot; schemaLocation="http://localhost:8080/geoserver/schemas/gml/3.1.1/base/gml.xsd&quot;/&gt;
  <xsd:complexType name="PrimitiveGeoFeatureType">
        <xsd:sequence>
          <xsd:element maxOccurs="1" minOccurs="0" name="surfaceProperty" nillable="true" type="gml:SurfacePropertyType"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="pointProperty" nillable="true" type="gml:PointPropertyType"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="curveProperty" nillable="true" type="gml:LineStringPropertyType"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="intProperty" nillable="true" type="xsd:int"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="uriProperty" nillable="true" type="xsd:anyURI"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="measurand" nillable="true" type="xsd:string"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="dateTimeProperty" nillable="true" type="xsd:dateTime"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="dateProperty" nillable="true" type="xsd:date"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="decimalProperty" nillable="true" type="xsd:double"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="booleanProperty" nillable="true" type="xsd:boolean"/>
        </xsd:sequence>
      </xsd:extension>
  </xsd:complexType>
  <xsd:element name="PrimitiveGeoFeature" substitutionGroup="gml:_Feature" type="sf:PrimitiveGeoFeatureType"/>
  <xsd:complexType name="GenericEntityType">
        <xsd:sequence>
          <xsd:element maxOccurs="1" minOccurs="0" name="attribut.geom" nillable="true" type="gml:GeometryPropertyType"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="boolProperty" nillable="true" type="xsd:boolean"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="str4Property" nillable="true" type="xsd:string"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="featureRef" nillable="true" type="xsd:string"/>
        </xsd:sequence>
      </xsd:extension>
  </xsd:complexType>
  <xsd:element name="GenericEntity" substitutionGroup="gml:_Feature" type="sf:GenericEntityType"/>
</xsd:schema>
21 Dec 17:39:18 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: Streams.
Strict WFS protocol conformance is being applied.
Make sure the type name is correctly qualified
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:138)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:97)
  at sun.reflect.GeneratedMethodAccessor210.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy13.describeFeatureType(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor209.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:624)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:478)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:459)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:733)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:695)
  at org.geoserver.wfs.v1_1.DescribeFeatureTypeTest.testCiteCompliance(DescribeFeatureTypeTest.java:179)
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.394 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.248 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.1 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.239 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Feature type cite:InvalidTypeName unknown
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.604 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.049 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.374 sec
Results :
Tests run: 229, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.1-SNAPSHOT/wfs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.1-SNAPSHOT/wfs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.1-SNAPSHOT/wfs-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms&gt;
[INFO] Copying 1 resource
[INFO] Copying 8 resources
[INFO] snapshot org.geotools:gt-svg:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-svg:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 162 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/src/main/java/org/geoserver/wms/map/RenderedImageMapOutputFormat.java&gt;:\[72,41\] package org.geotools.renderedimage.viewer does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/src/main/java/org/geoserver/wms/map/RenderedImageMapOutputFormat.java&gt;:\[857,20\] cannot find symbol
symbol : variable RenderedImageBrowser
location: class org.geoserver.wms.map.RenderedImageMapOutputFormat
[INFO] Total time: 2 minutes 34 seconds
[INFO] Finished at: Tue Dec 21 17:39:26 UTC 2010
[INFO] Final Memory: 54M/266M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3408/changes&gt;
