[Geoserver-devel] Build failed in Hudson: geoserver-trunk #3415
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3415/changes&gt;
Changes:
[aaime] Rename the builder panel so that it's possible to make more builder panels, one per service, without doubts about which one is which in the i18n files
[aaime] Adding explicit support for CRS params and removing tabs from the request builder sources
[...truncated 23197 lines...]
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1090)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1109)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1050)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:663)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:610)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:590)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:799)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:782)
  at org.geoserver.wps.GetCapabilitiesTest.testUnsupportedVersionHighPost(GetCapabilitiesTest.java:93)
  at java.lang.reflect.Method.invoke(Method.java:592)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:132)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor201.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
29 Dec 18:48:20 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find any matching version
  at org.geoserver.ows.util.RequestUtils.getVersionOws11(RequestUtils.java:174)
  at org.geoserver.wps.GetCapabilities.run(GetCapabilities.java:65)
  at org.geoserver.wps.DefaultWebProcessingService.getCapabilities(DefaultWebProcessingService.java:54)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:624)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.geoserver.wps.GetCapabilitiesTest.testUnsupportedVersionLowPost(GetCapabilitiesTest.java:108)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:478)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:459)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:733)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:695)
  at org.geoserver.wps.GetCapabilitiesTest.testUnsupportedVersionGet(GetCapabilitiesTest.java:115)
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.686 sec
Running org.geoserver.wps.gs.AggregateProcessTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.536 sec
Running org.geoserver.wps.gs.SimplifyProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.289 sec
Running org.geoserver.wps.gs.ImportProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.197 sec
Running org.geoserver.wps.gs.CountProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
Results :
Tests run: 98, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps-core/2.1-SNAPSHOT/wps-core-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps-core/2.1-SNAPSHOT/wps-core-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/wps-core/target/wps-core-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps-core/2.1-SNAPSHOT/wps-core-2.1-SNAPSHOT-sources.jar
[INFO] Building Web Processing Service GUI
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/web-wps/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/web-wps&gt;
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/web-wps/src/main/resources&gt;
Downloading: http://oss.sonatype.org/content/repositories/snapshots//com/googlecode/jaitools/zonalstats/1.0-SNAPSHOT/zonalstats-1.0-SNAPSHOT.jar
Downloading: http://oss.sonatype.org/content/repositories/snapshots//com/googlecode/jaitools/utils/1.0-SNAPSHOT/utils-1.0-SNAPSHOT.jar
Downloading: http://oss.sonatype.org/content/repositories/snapshots//com/googlecode/jaitools/rangelookup/1.0-SNAPSHOT/rangelookup-1.0-SNAPSHOT.jar
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/web-wps/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java&gt;:\[38,4\] cannot find symbol
symbol : class WPSRequestBuilderPanel
location: class org.geoserver.wps.web.WPSRequestBuilder
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/WPSRequestBuilder.java&gt;:\[46,22\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/ComplexInputPanel.java&gt;:\[46,51\] cannot find symbol
location: class org.geoserver.wps.web.ComplexInputPanel
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java&gt;:\[15,14\] cannot find symbol
location: class org.geoserver.wps.web.SubProcessBuilder
<http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wps/web-wps/src/main/java/org/geoserver/wps/web/SubProcessBuilder.java&gt;:\[15,51\] cannot find symbol
[INFO] Total time: 11 minutes 9 seconds
[INFO] Finished at: Wed Dec 29 18:48:25 UTC 2010
[INFO] Final Memory: 78M/292M
See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3416/changes&gt;
