See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3419/>
[...truncated 13430 lines...]
at java.lang.reflect.Method.invoke(Method.java:592)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.621 sec
Running org.geoserver.wms.wms_1_3.GetFeatureInfoIntegrationTest
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.631 sec
Running org.geoserver.kml.KMLTransformerTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.845 sec
Running org.geoserver.wms.decoration.MapDecorationLayoutTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.wms.WMSServiceExceptionTest
04 Jan 00:25:03 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer foobar
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1154)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:197)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:73)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1144)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:482)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:226)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1090)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1109)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1050)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:478)
at org.geoserver.wms.WMSServiceExceptionTest.assertResponse111(WMSServiceExceptionTest.java:25)
at org.geoserver.wms.WMSServiceExceptionTest.testException111(WMSServiceExceptionTest.java:17)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:132)
at sun.reflect.GeneratedMethodAccessor202.invoke(Unknown Source)
at org.geoserver.wms.WMSServiceExceptionTest.testException110(WMSServiceExceptionTest.java:21)
at org.geoserver.wms.WMSServiceExceptionTest.assertResponse130(WMSServiceExceptionTest.java:41)
at org.geoserver.wms.WMSServiceExceptionTest.testException130(WMSServiceExceptionTest.java:37)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.976 sec
Running org.geoserver.wms.capabilities.CapabilitiesXmlReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.wms.map.GIFMapResponseTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.012 sec
Running org.geoserver.wms.RenderingBufferTest
04 Jan 00:25:04 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.187 sec
Running org.geoserver.wms.capabilities.GetCapabilitiesTransformerTest
04 Jan 00:25:06 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
04 Jan 00:25:07 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.276 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.556 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
04 Jan 00:25:07 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.259 sec
Running org.geoserver.kml.GeoSearchKMLTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.279 sec
Running org.geoserver.wms.WMSDisabledTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.391 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.777 sec
Running org.geoserver.wms.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.179 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.155 sec
Running org.geoserver.kml.KMZMapProducerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
04 Jan 00:25:11 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.142 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.182 sec
Running org.geoserver.wms.capabilities.CapabilitiesKvpReaderTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Results :
Failed tests:
testValidateCapabilitiesXML(org.geoserver.wms.wms_1_3.CapabilitiesSystemTest)
Tests run: 231, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 3 minutes 30 seconds
[INFO] Finished at: Tue Jan 04 00:25:13 UTC 2011
[INFO] Final Memory: 58M/249M
