[Geoserver-devel] Build failed in Hudson: geoserver-trunk #345
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/345/changes
Changes:
[aaime] Added copyright notice
[aaime] GEOS-806, Add watermarking (e.g. show copyright notice, logo, etc) to wms output
[...truncated 2392 lines...]
  <td>
three
  </td>
  <td>
3
  </td>
  <td>
3.3
  </td>
  <td>
[GEOMETRY]
  </td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.412 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.148 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.544 sec
Results :
Tests run: 48, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.0-SNAPSHOT/wms-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.0-SNAPSHOT/wms-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/1.7.0-SNAPSHOT/wms-1.7.0-SNAPSHOT-sources.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Web Application Module
[INFO] artifact org.geoserver.maven:config: checking for updates from mortbay-repo
[INFO] artifact org.geoserver.maven:config: checking for updates from refractions-plugins
[INFO] artifact org.geoserver.maven:config: checking for updates from central
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from mortbay-repo
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.geoserver.maven:config:1.7.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-war-plugin: checking for updates from central
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 109 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 4 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/surefire-reports
T E S T S
Running org.geoserver.filters.BufferedRequestWrapperTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.221 sec
Running org.vfny.geoserver.jetty.SpringContextTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.288 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
     [copy] Copying 14 files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
     [copy] Copied 12 empty directories to 9 empty directories under http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/src/main/webapp/data
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.0-SNAPSHOT/web-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.0-SNAPSHOT/web-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/1.7.0-SNAPSHOT/web-1.7.0-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web] in [http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[680 msecs]
[INFO] Building war: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/target/geoserver.war
[INFO] Building Test Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target
[INFO] No sources to compile
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/surefire-reports
T E S T S
Running org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest
Feb 26, 2008 2:43:07 PM org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest testUserSpecifiedRule
INFO: testing single rule dirt_road from style Default Styler
Feb 26, 2008 2:43:07 PM org.vfny.geoserver.testdata.AbstractCiteDataTest assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.792 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest
Feb 26, 2008 2:43:07 PM org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest testSimpleGetMapQuery
INFO: about to create map ctx for BasicPolygons with bounds ReferencedEnvelope[-2.0 : 2.0, -1.0 : 6.0]
Feb 26, 2008 2:43:07 PM org.geotools.map.DefaultMapContext setAreaOfInterest
INFO: USing a deprecated method!
Feb 26, 2008 2:43:08 PM org.geotools.map.DefaultMapContext setAreaOfInterest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.964 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.SVGMapProducerTest
Feb 26, 2008 2:43:08 PM org.vfny.geoserver.wms.responses.map.svg.EncodeSVG encode
INFO: SVG generated in 8 ms
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.024 sec
Running org.vfny.geoserver.wms.responses.GetMapResponseTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReaderTest
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/test-classes/org/vfny/geoserver/testdata/test-data
Feb 26, 2008 2:43:09 PM org.vfny.geoserver.global.Data loadFeatureTypes
INFO: Loading feature type 'cite:::BasicPolygons' (layer 1/11)
INFO: Loading feature type 'cite:::Bridges' (layer 2/11)
INFO: Loading feature type 'cite:::Buildings' (layer 3/11)
INFO: Loading feature type 'cite:::DividedRoutes' (layer 4/11)
INFO: Loading feature type 'cite:::Forests' (layer 5/11)
INFO: Loading feature type 'cite:::Lakes' (layer 6/11)
INFO: Loading feature type 'cite:::MapNeatline' (layer 7/11)
INFO: Loading feature type 'cite:::NamedPlaces' (layer 8/11)
INFO: Loading feature type 'cite:::Ponds' (layer 9/11)
INFO: Loading feature type 'cite:::RoadSegments' (layer 10/11)
INFO: Loading feature type 'cite:::Streams' (layer 11/11)
Feb 26, 2008 2:43:09 PM org.geotools.referencing.factory.PropertyAuthorityFactory <init>
WARNING: Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295], AXIS["Longitude", EAST], AXIS["Latitude", NORTH]], PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","900913"]]
Feb 26, 2008 2:43:09 PM org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReader getRequest
SEVERE: Application Context is null. No producer beans can be found!
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.228 sec
Running org.vfny.geoserver.wms.responses.map.GIFMapProducerTest
Feb 26, 2008 2:43:09 PM org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest testSimpleGetMapQuery
Feb 26, 2008 2:43:09 PM org.geotools.map.DefaultMapContext setAreaOfInterest
Feb 26, 2008 2:43:10 PM org.geotools.map.DefaultMapContext setAreaOfInterest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.148 sec <<< FAILURE!
Results :
Tests in error:
  testSimpleGetMapQuery(org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest)
  testDefaultStyle(org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest)
  testBlueLake(org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest)
  testSimpleGetMapQuery(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest)
  testDefaultStyle(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest)
  testBlueLake(org.vfny.geoserver.wms.responses.map.GIFMapProducerTest)
Tests run: 15, Failures: 0, Errors: 6, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/test/target/surefire-reports for the individual test results.
[INFO] Total time: 6 minutes 21 seconds
[INFO] Finished at: Tue Feb 26 14:43:10 EST 2008
[INFO] Final Memory: 35M/63M
Updating GEOS-806
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/346/changes
[...truncated 2376 lines...]
<tr>
  <td>
three
  </td>
  <td>
3
  </td>
  <td>
3.3
  </td>
  <td>
[GEOMETRY]
  </td>
</tr>
</table>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.264 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.144 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.52 sec
Results :
[INFO] [jar:jar]
clean:
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.192 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.284 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.24 sec
Results :
[INFO] [jar:jar]
config:
[INFO] Webapp assembled in[504 msecs]
T E S T S
Feb 26, 2008 3:39:20 PM org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest testUserSpecifiedRule
Feb 26, 2008 3:39:21 PM org.vfny.geoserver.testdata.AbstractCiteDataTest assertNotBlank
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.836 sec
Feb 26, 2008 3:39:21 PM org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest testSimpleGetMapQuery
Feb 26, 2008 3:39:21 PM org.geotools.map.DefaultMapContext setAreaOfInterest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.984 sec <<< FAILURE!
Feb 26, 2008 3:39:22 PM org.geotools.map.DefaultMapContext setAreaOfInterest
Feb 26, 2008 3:39:22 PM org.vfny.geoserver.wms.responses.map.svg.EncodeSVG encode
INFO: SVG generated in 4 ms
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Feb 26, 2008 3:39:22 PM org.vfny.geoserver.global.Data loadFeatureTypes
Feb 26, 2008 3:39:23 PM org.geotools.referencing.factory.PropertyAuthorityFactory <init>
Feb 26, 2008 3:39:23 PM org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReader getRequest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.184 sec
Feb 26, 2008 3:39:23 PM org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest testSimpleGetMapQuery
Feb 26, 2008 3:39:23 PM org.geotools.map.DefaultMapContext setAreaOfInterest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.128 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 6 minutes 33 seconds
[INFO] Finished at: Tue Feb 26 15:39:23 EST 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/347/changes
<tr>
  <td>
three
  </td>
  <td>
3
  </td>
  <td>
3.3
  </td>
  <td>
[GEOMETRY]
  </td>
</tr>
</table>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.14 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.508 sec
Results :
[INFO] [jar:jar]
clean:
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.177 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.272 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Results :
[INFO] [jar:jar]
config:
[INFO] Webapp assembled in[592 msecs]
T E S T S
Feb 26, 2008 3:45:44 PM org.vfny.geoserver.wms.responses.DefaultRasterLegendProducerTest testUserSpecifiedRule
Feb 26, 2008 3:45:45 PM org.vfny.geoserver.testdata.AbstractCiteDataTest assertNotBlank
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.856 sec
Feb 26, 2008 3:45:45 PM org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest testSimpleGetMapQuery
Feb 26, 2008 3:45:45 PM org.geotools.map.DefaultMapContext setAreaOfInterest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.98 sec <<< FAILURE!
Feb 26, 2008 3:45:46 PM org.geotools.map.DefaultMapContext setAreaOfInterest
Feb 26, 2008 3:45:46 PM org.vfny.geoserver.wms.responses.map.svg.EncodeSVG encode
Feb 26, 2008 3:45:46 PM org.vfny.geoserver.global.Data loadFeatureTypes
Feb 26, 2008 3:45:47 PM org.geotools.referencing.factory.PropertyAuthorityFactory <init>
Feb 26, 2008 3:45:47 PM org.vfny.geoserver.wms.requests.GetLegendGraphicKvpReader getRequest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.172 sec
Feb 26, 2008 3:45:47 PM org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest testSimpleGetMapQuery
Feb 26, 2008 3:45:47 PM org.geotools.map.DefaultMapContext setAreaOfInterest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.124 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 6 minutes 13 seconds
[INFO] Finished at: Tue Feb 26 15:45:47 EST 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/348/changes
