See <http://hudson.opengeo.org/hudson/job/geoserver-trunk/3452/changes>
Changes:
[jdeolive] removing restconfig artifact descriptor as per GSIP-59
[...truncated 12654 lines...]
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:521)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:712)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1155)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1174)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1115)
at org.geoserver.test.GeoServerAbstractTestSupport.putAsServletResponse(GeoServerAbstractTestSupport.java:637)
at org.geoserver.test.GeoServerAbstractTestSupport.putAsServletResponse(GeoServerAbstractTestSupport.java:625)
at org.geoserver.catalog.rest.DataStoreTest.testPutNameChangeForbidden(DataStoreTest.java:305)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:141)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
14 Jan 04:43:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock3826133259266982534data>
14 Jan 04:43:42 ERROR [geoserver.rest] - Can't change workspace of data store.
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.DataStoreResource.handleObjectPut(DataStoreResource.java:132)
at org.geoserver.rest.ReflectiveResource.handlePut(ReflectiveResource.java:195)
at org.restlet.Finder.handle(Finder.java:298)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:77)
at org.geoserver.catalog.rest.DataStoreTest.testPutWorkspaceChangeForbidden(DataStoreTest.java:312)
Tests run: 20, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.648 sec
Running org.geoserver.catalog.rest.StyleTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock7203836134223420343data>
14 Jan 04:43:43 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock6115834981921846312data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock869921698782604378data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock8724561116262667286data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock3874942825794478230data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock7068191408303283775data>
14 Jan 04:43:44 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock2194196311054837311data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock3738679177409300534data>
14 Jan 04:43:45 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock179744680048467919data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock1350572614882236931data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock740822685658348381data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock4902180754297086213data>
14 Jan 04:43:45 ERROR [geoserver.rest] - Can't delete style referenced by existing layers.
at org.geoserver.catalog.rest.StyleResource.handleObjectDelete(StyleResource.java:210)
at org.geoserver.rest.ReflectiveResource.handleDelete(ReflectiveResource.java:226)
at org.restlet.Finder.handle(Finder.java:300)
at org.springframework.web.servlet.FrameworkServlet.doDelete(FrameworkServlet.java:531)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
at org.geoserver.test.GeoServerAbstractTestSupport.deleteAsServletResponse(GeoServerAbstractTestSupport.java:740)
at org.geoserver.catalog.rest.StyleTest.testDeleteWithLayerReference(StyleTest.java:168)
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock4829552191430566877data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock612521338964964481data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock2134804981773177804data>
14 Jan 04:43:46 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock3715902731188660064data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock6764263489559839139data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/./target/mock669329094620350062data>
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.756 sec
Results :
Failed tests:
testShapeFileUploadIntoExisting(org.geoserver.catalog.rest.DataStoreFileUploadTest)
testShapeFileUploadWithTarget(org.geoserver.catalog.rest.DataStoreFileUploadTest)
Tests run: 188, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/restconfig/target/surefire-reports> for the individual test results.
[INFO] Total time: 6 minutes 38 seconds
[INFO] Finished at: Fri Jan 14 04:43:46 UTC 2011
[INFO] Final Memory: 62M/231M
